Sony FD Trinitron WEGA KV-32HS510 32" TV Logo
Posted on Dec 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a sony trinitron kd-32fs170....all i get is 4 red blinks no picture
Anonymous
Level 3:
Brigadier General:
  • Master 8,909 Answers
  • Posted on Dec 23, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
8909
Questions
Helped
1541465
Points
28391
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
No frame in other words.
1helpful
Our Trinitron KD-27FS170 Tv will not turn on. It sounds like it is turning on/off but no picture or sound. The Stand-by/Timer red light is flashing 4 times, pause, then 4 times, etc.
This typically means you have a bad capacitor, you can inspect for any swollen or bulging capacitors however unless familiar with desoldering boards best leave it to a repair technician.
Sony trinitron blinks 11 times
Google Jestine Yong. he is an authority on these. he is very good.
2helpful
Sony KD-34XBR960....problem is that screen is black; LED light blinks 7 times in a row pauses and then starts blinking again. Have powered off and no improvement.
This tv have two power ICS left side of the FBT-The Flyback Transformer.The big black block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced those 2 power ICS,tv will solved this LED power light flashing,tv will have stable power again,tv will work.
My son stepped on a remote control for a DVR. The Sony Trinitron Wega KD 32FS130 went blank. Now it won't come on, goes into standby mode, with the red light blinking four times. Any suggestions?
It is possible that the button your son stepped on is stuck. If so, remove the batteries form the DVR remote control and see if the TV works. Unplug the TV from the wall for a few minutes to clear its memory to be sure. Some times remote controllers can have cross-talk, meaning it can affect other equipment,
1helpful
Have a sony kd32fs130 and after limited viewing the picture goes out. I still continue to have sound but no picture and the red light blinks. Which part I need to change?
How many times red light blinks when TV lost picture? There would be interval of 3 seconds in red light blinks so count pause to pause and let me know.
1helpful
My sony kd32fs130 red light blinks 5 times
your video circuit is not working that is why you are not getting picture
Sony trinitron tv
If you have sound but no picture it means that your power supply and tuner are working correctly. The number of times the timer LED blinks is the code for the problem with the picture. The computer will stop the picture and blink the timer LED if the vertical circuit stops working, if the picture tube is too weak or if the horizontal sweep has stopped. The set should be serviced by a qualified tech familiar with Sony sets.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
