Question about Haier Washing Machines
Every cycle on my haier washing machine leaves my clothes soaking wet, whats wrong?
    Genius:
  • 1,036 Answers
Listen for the pump working near the end of a cycle, and make sure it is pumping the water out.
Check the outlet hose is not kinked, blocked or pushed too far into the outlet pipe.
Check and clean the filter if accessible.
If there are no problems with the pump, and you can see/ hear water being added near the end of a cycle, then the control board needs replacing as the cycles are wrong.
Thanks for using Fixya! If this enables a solution, please rate as such. Thanks.
Posted on Jul 04, 2008
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Manf# MAV5000AWW My toploading washing machine goes through all cycles but the last spin cycle the clothes are still soaked and i have to sring the excess water out by hand
If the machine is not pumping out completely, it could mean a blocked drain hose or a faulty/blocked pump. This would explain wet clothes However if the mache is not actually spinning it will leave the clothes wet,as well. Check and ascertain which function is not working.........Nomess
Apr 17, 2010 | Washing Machines
Will not do final spin cycle leaving clothes
Your drain pump has something lodged in it. Remove drain motor, open it up and inspect for obstruction. remove it then reassemble.retrywashing cycle.
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
Dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Jan 27, 2009 | Haier Washing Machines
1999 Maytag Neptune front loader
Have you replaced your 12002535 door latch wax motor if you have a MAH3000, MAH4000, MAH5500A or the 2000 stacker? These wax motors will eventually fail on every Neptune shipped. When the wax motor fails the upper machine control board be damaged and you will lose your spin function which leaves your clothes soaking wet. There is a website that offers a repair kit to see if your control board is useable again. Don't keep starting machine because you might cause further damage to control board and the motor control board located near the floor until you see if R11 is burnt on the upper machine control board located behind the timer.
See www.neptunewaxmotor.com for more details and step-by-step disassembly photos.
Sep 21, 2008 | Washing Machines
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
Washing Machines Logo
122 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
