Question about Tascam Audio Players & Recorders
Tascam x-48 hard disk recorder error message (cant find host!) What does this mean?
3 Suggested Answers
marsrover
  • 682 Answers
SOURCE: I HAVE A TASCAM DIGITAL
http://www.manualnguide.com/download/manual-guide/tascam-dm-24-digital-mixer-automation-manual.html
setup information in manual above-i think cable will be found in a music equipment store near you.
Posted on Jul 18, 2008
SOURCE: I recently got the TASCAM
Hey Corey I am getting the same error on my new DP004. Did you hear of a solution yet.
Posted on Jan 11, 2011
Error code recording stopped. Problem with record buffer
I've done some searching this seems very proprietary, I would first try contacting the manufacturer directly to see if t hey can shed some light on this issue.
Jan 23, 2015 | Tascam X-48 48-track Hybrid Hard Disk...
I have the tascam 2488neo and it showed and error code 01 and ever since then it won't boot up it goes to the disk detection and freezes up and the (overload, input, record, and mute solo) lights light up...
I had
System error code:01
on my Tascam 2488 neo
Turns out it was a hard drive error. I tried everything. I used the "Quick Routing/Shift/Send/ShutDown" trick where you press all four buttons at once and keep them pressed down throughout while you power on the unit util you see a message saying "System Reset Complete. Now Power Down". Numerous times it came on and said stuff like "creating partition," "creating song" and "now working" but it always ended with "System Error Code:01". That trick is upposed to reset system par?meters to default and erase everything from the hard drive and reset the hard drive. I even removed the hard drive, hooked it up to my Windows 10 PC and used Windows utils to reate and/or delete partitions and both "quick" and regular format. I also tried all the hard drive utils from the manufacturers like a formatting and a scrubbing util etc.,.nothing ?orked until I downloaded, inst?lled ?nd used a low level format utility called "Hard Disk Low Level Format Tool," its installation file is called "HDDLLFsetup.4.40.exe" which is available from mul?iple internet sites, just search for it. Here is how to repair your Tascam hard drive or prepare any new hard drive for installtion or upgrade that is giving endless problems and system error codes on the Tascam:
1. Open your recorder and remove the hard drive from the Tascam. If you're unsure about doing this there is a YouTube video av?iable about how to replace your Tascam 2488 hard drive.
2. Connect that drive by any means available to your laptop or PC. I used a USB to SATA ad?pter and connected it to my laptop, I also successfully did this using my desktop PC.
3. Run the "HDDLLFsetup.4.40.exe" application and install it.
4. Now use the newly installed "Hard Disk Low Level Format Tool" utility.
5. Select your hard drive then the low level format tab and don't sele?t the "quick" option, make sure it does a full low level format. It'll be slow and t?ke some time. Any hard dive prepared like this will ?ork in the Tasc?m except incompatible or damaged hard drives.
6. Reinstall hard drive into Tascam and simply power on the Tasc?m. Do not use any special boot up tricks with any key combinations, just turn it on.
7. Select "yes" when asked if you want to form?t the drive. W?it a few seconds until it completes cre?ting and working. It should boot up to normal use mode and be ready for recording within 3 minutes. If yours takes longer your hard drive may be damaged and need replacing. I tried other hard drive utilities from Hitachi, Seagate, S?msung and Western Digital but none worked. O?ly the "HDDLLFsetup.4.40.exe" was able to fix the problem.
Apr 03, 2013 | Audio Players & Recorders
Tascam 2488 system error code 1
I had
Dec 15, 2012 | Tascam 2488 Portastudio Multitrack...
Is there a driver for tascam dp-01 for windows7 operating system
Unfortunately no such driver is available, because tascam have discontinued that particular model.
Here is a way to get your recordings off the device
On the Tascam main menu, select "Wave." 2) On the Wave menu, select "Export Master." This saves your mastered song to the correct folder. 3) Connect the Tascam DP-01 to your computer. You will get a message telling you your USB device has malfunctioned. 4) On the Tascam menu, select "Disk." 5) On the Disk menu, select "USB OPN/CLS." Your computer should detect the DP-01 as a hard drive & be visible in "My Computer" on Windows.
Apr 03, 2011 | Computers & Internet
I have a tascam dr7 with a device error 2 code...I used a 5v power supply not from tascam for quite a lot of time.....it eats batteries like crazy. Device error 2...what is it?
Device Error [2] is "memory bus error". There is nothing that you can do to fix it. There are two PCBs in Tascam DR-07. This is the bigger one that has LCD display and all control buttons. Your best bet is to find a broken one that does not power up at all (the smaller PCB - which host the CPU - is bad) then swap the PCBs.
Dec 16, 2010 | Tascam DR07 Digital Voice Recorder
My tascam dp 02 started up with this mount error message I bought a tascam dp 02 for my son for christmas. When I plug it into the mains the display shows ' mount error :oc /please pwr off'. my email is...
The TASCAM DP-02 Owner's Manual has no reference to a mount error in it. There are many people online complaining about mount errors on their computers, mac and win, when hooking the tascam up via USB, but your post suggests this error was on the DP-02 itself, is that correct?
I get less than a dozen hits of people asking this question online, and absolutely no useful answers or responses.
Do you have the DP-02CF model? If so, it may be a faulty CompactFlash Type I card that it is trying to mount. If there is a disk in the drive, I'd remove that cd in case it is trying to mount a bad disk.
I can most likely help troubleshoot a troublesome USB-to-computer connection, but otherwise I'm going to have to refer you to TASCAM customer service, (although I must say the forums I've perused have little positive to say about them.) TASCAM support in the UK (a guess, but you did use the term 'mains' in your post) is provided by TEAC UK Limited at +44-8451-302511 or www.tascam.co.uk.
Best of luck & I hope that helps.
Dec 26, 2009 | Tascam Dp-02cf Digital 8-track Recorder
I cant record
You'll see this message if you try to create a song but there's not enough disk space on the partition to create a song. Free up some disk space and try again. The manual is at http://www.tascam.com/products/dp-01;9,16,33,19.html under resources.
May 30, 2009 | Tascam DP01 All-In-One Recording Package...
Memory poor
This is an error in Tascam's code that usually means 'out of disk space'. Try using 'delete unused' to free up some space first within the song you're on and after that you might consider backing up some songs to your PC and then deleting them from the DP-01 to free up more disk space.
Hope this helps.
bd.
Dec 04, 2008 | Tascam DP01 All-In-One Recording Package...
I HAVE A TASCAM DIGITAL MIXER TYPE DM-4800. I NEED IT TO CONTROL MY TASCAM HARD DISC RECORDER TYPE X-48. I NEED CABLE CONNECTION AND SETUP INFORMATION
Jul 18, 2008 | Tascam Audio Players & Recorders
Tascam dp-01fx system 50 error
what the above guest said is exactly what you need to do. Make sure of course there is nothing on your FAT(previously exported songs/masters) because they will be erased. just go to menu->disk->fat reform, then press enter
Nov 07, 2007 | Tascam DP01FX All-In-One Recording Package...
172 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
