Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
Whirlpool Duet Sport Front Load Washer Model #H7HB41OB (3B)
My new machine seems "off balanced", it makes a lot of noise and rocks around during the spin cycle so much that I had to turn it off during it's first load and have not been able to use it. How can I remedy this problem?I bought this machine new from my local Sears. They sold it as a floor model and someone had already purchased the dryer so I got a pretty good discounted price. When the machine was delivered it was brought to my attention that all floor models were sold "as-is". This is a problem because there were only two stabilizing bolts that didn't really fit for the move and no user manual to let me know how to properly care for and use my new machine.
  • 1 more comment
  • headcasesoft Aug 23, 2008
    I have had the same problem, lots of noise and vibration. the machine walks all over. I cant leave the machine while it washes , because it will move to far .
  • Tman_apex Mar 25, 2009
    How can I get to the tub and basket for a Whirlpool Duet Sport 3.8cu. ft. washer?
  • Anonymous Apr 26, 2009
    what does error code F-21 mean
    Genius:
  • 1,036 Answers
The User manual and warranty guide are available for downoad Click HERE
Make sure you keep the receipt with the warranty, as your 1 year guarantee starts the moment you bought it.
If you think there is a material/ manufacturing defect - phone the number on the warranty and get it repaired FREE. You have as much right to this as someone buying mail order.
Sort out any issues you have now while it is covered.
It does not matter who sold it to you or that it was unwrapped and on display - this shop is not a customer. You are.
Thanks for using Fixya! If this solves your problem, please rate as such. Thanks.
Posted on Jul 04, 2008
Washer balancing load, during spin cycle wasker shakes and walks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Mar 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Balance, washer shakes and walks across floor
Have you checked to make sure the supports are OK? Is your washer making loud noises during spinning? If so, the basket drive may be broke.
My Whirlpool front load washer is out of balance when spinning. It makes a loud noise. How do I get the tub back in balance? GHW9200LQ is the model.
Whirlpool front load washers have shock absorbers that helps them in moving the washer around the place. Due to regular usage of the washer it may tend to break.This will result in drum hammering sound . To clear this problem pull the bottom front off and check the shocks. Typically the rings where the pins go through are where they will break. You have to grab them and should have a complete check by moving them to see that whether they are broken.
Thank you !!
May 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer that is making very
It sounds like basket support failure. How old is the machine? They usually **** at around 5 to 6 years. Unless you are going to fix it yourself or it's under extended warranty, junk it.
The repair requires a complete teardown of the washer. two to six hours labor depending on tech skill level.
Jun 12, 2009 | Whirlpool GHW9200L Front Load Washer
Front loader is making funny noises. It was
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
340 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
