Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Error message: Printhead missing, not installed correctly or has come loose
I had a tecnician install everything yesterday, but I keep getting the above error message: Printhead missing, notinstalled correctly or has come loose. Install printhead and ink cartridges. If already installed, remove ink cartridges and printhead, then reinstall. See User's Guide.
We followed above directions over and over again. He went home. The printer is still showing the above message. I would really appreciate your help.
Thanks,
Amber-Dawn Cusack
adtaurusred@gmail.com
  • 7 more comments
  • adtaurusred Jul 16, 2008
    Hi! I felt I got the wrong information from one of your technicians in telling me the printer was broken and to pack it up and send it back. So I contacted Kodak and they have sent a replacement part that has fixed the problem. A lot easier and more sensible than having to somehow carry the complete boxed printer to the Post Office as I don't have any transport. A little tough to try at 73. As I said before, I feel my payment should be refunded.
    But thank you for followihng up.
  • wcmartin_wc Jul 21, 2008
    Please help if you can. I am getting the same message. . .Error message: Printhead missing, not installed correctly or has come loose problem, and notify you when a new solution is offered.
  • debib Aug 05, 2008
    What can I do to fix this on myKodak easy share ? Error message: Printhead missing, not installed correctly or has come loose problem, and notify you when a new solution is offered.
  • smallsa Aug 16, 2008
    Purchased an Kodak Easyshare 5500 All-IN-One printer in March, 2008. Replaced color and ink cartridges in July, 2008. This week without warning (August 14, 2008), the printer stopped printing black ink. The color ink continued to print fine, and I didn't receive any warning notifications to replace or reinstall the print head or either ink cartridge. After performing a basic, then a "deep" clean of the print heads, I replaced the black ink cartridge with a new one (even though it showed more than 3/4 full). With a fresh cartridge installed, and after recleaning the print heads, I was still unable to print with black ink.
    After searching online, I came across a link for Kodak Customer Service: http://www.kodak.com/global/en/service/c... I called the support line at 1-800-421-6699, and was connected with a live support technician. The technician asked me to explain the problem I was having (not able to print w/ black ink). He then had me remove and reinstall the black cartridge, then perform a basic printhead cleaning. When that didn't resolve the issue, the technician had me remove both the color and black ink cartridges, then remove the printhead. He then had me disconnect the power cable to the printer.
    While we waited for 2 minutes to elapse, the technician asked me to provide the serial number for the print head (which was located on the side of the print head just above the "Made in China" inscription), as well as the Kodak service number (which is found on a bar-coded sticker located just to the left of the printhead access area, and below the illustrated cartridge replacement guide sticker).
    After 2 minutes with the printer powered off, the technician had me reconnect the power cable, reinstall the printhead, and then reinstall both the black and color ink cartridges. He then had me perform a basic and a "deep" printhead cleaning. After that, he had me print a demo page, and asked me to describe the quality of the print job.
    When I explained to the technician that the black ink was still not printing, the technician explained that the printhead was defective, and that it would need to be replaced. Since my printer was still within the 1 year warranty, the technician offered to replace the print head, plus the color and black ink cartridges free of charge. He took my name, email address, and mailing information, then provided me with an "order ticket number" and explained that my replacement parts would arrive in 1-3 business days.
    I asked the technician how much the replacement parts would have cost had my printer been out of warranty. The technician dodged the question, assuring me that the printheads are designed to be functional "well beyond the normal life" of the printer. (I hope is printer life span is longer than the 1 year warranty!) At the time of this submission, I was awaiting the replacement printhead and ink cartridges. I'm hopeful that this will resolve my printing issue.
  • Matt D May 11, 2010
    Just wondering if this issue is solved yet?
  • Anonymous Mar 12, 2014
    Getting error: printhead loose, missing, or not installed correctly
  • Anonymous Mar 26, 2014
    When I press print I get the error code 3513 prinhead loose I went tru the cleaning cycle, removed and reinstalled it several times, but the error code keeps coming back
  • Anonymous Mar 31, 2014
    getting error messages 3802 & 3513 . tried changing ink cartridge still get error message
    new black cartridge installed but ink not coming through to paper
In regards to the error message with the printhead missing or come loose......I had that issue just shortly after I installed my printer. I was going crazy trying to fix it taking it out and reinstalling which was a pain, removing the cartridges and then the printhead to no avail. Finally I got smart and disconnected the power cord from the printer itself, not directly from the outlet. Once I did that and turned the printer back on the error was gone. It might have been a fluke, but it worked for me, so you might want to try it.
Posted on Aug 30, 2008
    Scholar:
  • 96 Answers
Ok...very good. If you have problems in the future, send me a message. Kodak Products are my specialty.
Posted on Jul 18, 2008
I am having the same problems with the printhead missing or loose. I have removed and installed..going crazy! This is my 3rd Kodak printer. Everytime something goes wrong they send me a new one or new part. I got this printer as a gift but am thinking of buying a different brand. What is a good printer or are they all junk?
Posted on Dec 29, 2009
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
My printer is showing error code 3802, I do I do?
Hello Dave,
The error that you are showing means Error: "Printhead is missing, not installed correctly, or has come loose" (105-3513) Please use the following link to help you trouble-shoot and fix this error:
Error Printhead is missing not installed correctly or has come loose 105...
Feb 26, 2015 | Kodak ESP5250 All-In-One InkJet Printer
Error message Printhead Missing or not installed correctly
The printhead is the device in which the ink cartridges sit. It may be mis-installed.
Take out the ink cartridges (carefully, you can get ink on yourself). Now using the gray latch on the right side of the carriage, remove and re-install the printhead. Jiggle it a little before lowering the latch to seat it.
Now, re-install the ink cartridges.
See if it works
Feb 26, 2011 | Kodak ESP 5 Printer
Error message, printhead missing or not installed or has come loose. The printhead is in place, I removed the cartriges and removed the printhead then replaced them with the same results
help! I am looking for the solution! I also have a broken arm and i keep gettin timed out. Error message, printhead missing or not installed or has come loose.The printhead is in place, I removed the cartriges and removed the printhead then replaced them with the same results. I you can respond please instruct me whay to do. i have had my printer out for 10 days. ps, my phone number is 931 993 8269 email is jiyoung@fpunet.com
Dec 23, 2010 | Kodak ESP 5 Printer
Kadak Easy Share 5300 printer. Screen reads "Please wait"-stuck
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Aug 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error message re printhead.
To resolve the error condition:
  1. Open the printer access door.
  2. Remove the color and black ink cartridges.
  3. Remove, then reinstall the printhead
To reinstall printhead follow the link.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Nov 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Newly installed and getting error on printhead and ink cartridges
If that error happens every single time you turn on the printer, that pirnthead is faulty.
But if the error only happens some times, try a firmware update from www.kodak.com/go/downloads
Jul 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
4,450 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
