Question about Video Game Consoles & Games
Failed to load DLL: FirewallInstallHelper By the Way Its For Gears of War (PC)
  • Anonymous Aug 04, 2008
    fire wall instal help
  • Anonymous Aug 09, 2008
    como corregir paso a paso error al cargar dll: firewallInstallhelper
1.) Put GOW CD in drive and allow to load.
2.) Exit out of the auto run window by clicking on “Exit.”
3.) Search the CD with the Window XP search tool for the “FirewallInstallHelper.dll” file. You should only get one result after a short while. Leave that window open.
4.) Now navigate to your System 32 folder in the Widows folder but do not open the contents of the System 32 folder.
5.) With your Search results still open click and drag the FirewallInstallHelper.dll file into the System 32 folder.
6.) Close all windows you have open.
7.) Run the GOW CD again and click on “Install.”
8.) You will get another prompt asking you if you want to uninstall all components. Click yes.
9.) You will get another prompt asking if you want to delete all other user content. Click yes.
10.) Game should install now and you should be free and clear.
Posted on Feb 24, 2009
  • 1 more comment
  • carlostorm May 30, 2011
    Thanks for your tip! But in my case, on W7 x64bits, I copied the “FirewallInstallHelper.dll” file to SysWOW64 folder in the Widows folder and, it worked. Finally, I got to completely uninstall all components of the game and run a new install.
  • caesar cesal Feb 12, 2013
    HI ! I have the same error with Skyrim... I have been trying to install it after accidently deleting it...But reinstalling it requires to uninstall it and when it begins removing i get the same error *Failed to load DLL: FirewallInstallHelper* ... I tried to do what you said step by step but I dont have FirewallInstallHelper.dll at all...is there any other solution for this? Any help appreciated.
  • clau_smoko
    clau_smoko Jul 20, 2013
    I had the same problem with cod 4 and i instaled the dll in the sys 32 and didnt work but when i installed it in the syswow64 folder it worked. tx a lot dude u made my day
Icuin36.dll wont load of can not be found
Download the file from this site http://www.dll-files.com/dllindex/dll-files.shtml?icuin36, unzip it and paste in into the system32 root folder. You'll have to do this using another pc. Mount your hard drive on another pc, locate the C:\windows\system32 folder and paste the unzipped file (icuin36.dll), turn off the Pc and remove your hard drive and again remount on your Pc, now Power on your system, it'll be ok. You can also do this without using another Pc, but you have to know how to use command prompt. Good luck.
May 22, 2010 | Computers & Internet
I need to reinstall my gears of war pc but i deleteed it piece by peice instead of putting the disk in and uninstlling it so now i put the disk in and it says play or unisntall so if i uninstall it then...
After doing a bit of searching on the web, I found a program called Revo Uninstaller.
This should work like a charm for you, as other people in similar situations who also partially deleted Gears have used it. You can download the program here:
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Hope this helps :)
Nov 29, 2009 | Microsoft Gears of War for Windows, Mac
Error: 0x80040702 Failed to load DLL :
It sounds like the uninstall files have been corrupted. The best option in
this case is to reinstall the game and then uninstall it.
Nov 17, 2009 | HP Pavilion dv9000z Notebook
Connection failed on gears of war 2
for whatever reason, you lagged out of the game... it may not be your fault, it may be the Hosts fault, your connections might not like each other...
the game may be invite only....
it happens, no worries, just connect to another game
Sep 09, 2009 | Microsoft Gears of War 2 for Xbox 360
Error code 0x80040702
Reinstall the game if problem stays repair ur operating system
May 17, 2009 | Microsoft Gears of War for Windows, Mac
Gears of War 2 Loads but says "disk unredable."
You have a problem with your Xbox. 3 Game discs arent all faulty.
Call a service agent and tell them your Xbox cannot read discs.
Jan 04, 2009 | Microsoft Gears of War for Xbox 360
Gears of war 2 won't load
this only happens with gears of war 2?? ...if so your unlucky and got yourself a faulty disc..or if you watch a copied dvd that messes it up and you'll need a new one.
Dec 25, 2008 | Microsoft Gears of War for Xbox 360
Can't start campaign in Gears of War for 360
Download game to Hard Drive it fixes these issues and reduces load times by a lot. on and off-line.
Nov 15, 2008 | Microsoft Gears of War for Xbox 360
Video Game Consoles & Games Logo
6,168 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
