Question about Brother XL-5130 Mechanical Sewing Machine
Need help I just need to know what to set the knobs on for just regular sewing, it was my grandmothers machine and we don't have any way of knowing what to set it on
  • gginny Aug 04, 2008
    Which if the top three knobs adjusts tension.
    I have a Brothers Pacesetter PS 1950 which also has three top knobs
    GK
  • Brother Master
  • 1,388 Answers
Just found this rather old posting, so hope this is of some value....
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
Thissolution is for tension problems...if you cannot form any sort ofstitch, the issue is quite different, so please let me know if you needa different problem solved.....
It is quite long, but just work through each section in order.
The"knotting up" can reveal a lot. If you have loose threads on one sideor the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
Ifthe looping threads are on the underside as you sew, it is the toptension. Top tension ought to be between 4 & 6 (this variation toallow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Makesure that when you thread the machine the presser foot is up so thethread goes between the discs and not to one side, top tension between4 and 6, and that you have threaded through all the guides, includingthe last one, usually on the needle arm, just above the needle clamp.
Itmay be there is lint trapped between the discs, this will keep themslightly apart and reduce the actual tension, sometimes dramatically.
Iftensions appear correct, and the thread is definitely in the channelbetween the discs, but still too loose and looping, try raising presserfoot and remove your thread.
Now, with a 2" (50mm) wide strippiece of fabric 8 - 10" (20 - 25cm) moistened with methylated ordenatured spirit, gently insert the fabric strip and clean between thediscs with
a see saw / to and fro action.
In the worstcases, gentle use of a needle to pick & remove the jam may benecessary, but be very gentle and make sure the tension is set at Zeroand the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Farless common, but if the loose threads are on the top, it is bobbintension that is loose, it too may have lint in the spring and be givinga "false" tension.
I would not recommend fiddling with bobbintension without good reason, it may end up with missing small screwsand spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
justtake it out and clean the bobbin case and the fixed metal hook racewith a small brush to remove lint. If there is a significant amount oflint, use a vacuum and small brush to get the worst.
Then wipeall this area with a cloth or cotton bud (Q tip) moistened (not soaked)with methylated spirit, especially if there appears to be fine dirtydeposits....oil and lint combine to conspire against you.
If itseems likely that you ......really ....do .....actually .....need.....to adjust the bobbin case, first check there is no lint trapped inthe metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
Need help - 4c76dc1.jpg...the other screw at one end is holding it all together, sobeware....it is not a tragedy to undo the whole lot and clean it, butvery gingerly and lay the bits out in sequence and orientation, or yourisk tearing your hair out !
FRONT LOADER:
....this is abobbin case from a front loading machine and works in a very similarfashion to the top loader with drop in bobbin, again, if you dismantleit, take care so you can put it all
back properly.
FINISHING UP
GETTING THE BALANCE RIGHT:
Whenyou are certain there's no trapped lint in top tension or bobbin, setthe top tension to 4 and the bobbin tension to a point where you justbegin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Setyour zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5etc) and sew a sample for a few inches and check the result.... adjustthe bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
Youmay find you are playing with this balance for some little while and ifyou are putting the needleplate on and off each time begin to think itcannot be correct to do this.....BUT....it is,
and eventually, youdo get a "feel" for the correct tension and then it happens quitequickly.....as a user you won't be doing it very often unless there islint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
Ifyou live near the ocean as we do, salt air can play havoc withmetalwork inside and out, so to help minimise this, keep a few smallpackets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budgetfor a proper full service every couple of years (more often if heavilyused) and if you don't use your machine for a few years, be aware thatold oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
Ifit is worth spending the time, energy and money on making somethingthat you would like to give lasting enjoyment......use quality thread,.......it may seem to cost a little more at the
time, but theresults, ease of use and added longevity will be worth the extra, andas a bonus, your tension troubles may be fewer and further between,because there is a more consistent diameter with good thread, and lesscompensating to be done by your tension plates and less thread breaks !
bargainbox.com.au
Posted on Jul 23, 2008
What is the tension for this machine?
You need to provide the make & model of your machine. A purple and green knob does not help us help you. We don't even know whether this is a sewing machine or serger.
Most machines, the standard factory tension setting is the midway point between high & low number.
Jun 26, 2016 | Sewing Machines
I need to know how to change the pressure between the foot and the sewing plate. I have no problem doing regular sewing but when I try to do several layers (such as quilting) the pressure is too much and...
The rotary control on the left-hand end of the sewing arm controls the foot pressure. You shouldn't normally need to vary this, except when quilting thick materials. The control is normally set with the 'bar' in the middle of the knob straight up-and-down, but you can reduce the pressure by turning it - the markings on the head cover correspond to increasing and decreasing the foot pressure.
Aug 04, 2011 | Bernina Artista 170
I inherit a Singer 281-21 sewing machine from my grandmother, and I know nothing about it. She was a seamstress by trade, and brought this one years after she retired. Can you point me in the right...
You have a high speed (for the time) industrial Singer sewing machine. If you click here you will find a free download of the servicing manual for your machine: it's very comprehensive and includes the operating instructions, but as it's aimed at professional users it assumes the user already knows a bit about sewing machines. Note that on the 281-21 regular maintenance and correct lubrication is even more vital than on their domestic machines from the same period.
I hope that you are pleased with the speed and content of my free answer, if so then please take a brief moment to rate my reply. Good luck with your machine, it's a bit of a heavyweight but should give many more years of faultless use if looked after.
Oct 04, 2010 | Singer Sewing Machines
How do you sew on the singer futura 250. I am
Pull out the embroidery unit. Raise the feed dogs. Change the feet. disconect from computer. It should be good to go.
Dec 13, 2009 | Singer CE-100 Futura Computerized Sewing...
The thread tension knob came off. I don't know in
The tension knob came off and I need instruction on the order in which it goes back together.
Oct 29, 2009 | White Sewing 1409 Mechanical Sewing...
Bobbin Info and threading!
Take your machine to any sewing store that sells parts and accesories and they will be able to match the bobbin case to your machine. I am still using the bobbins that came with mine but you can pick up the metal bobbins at Walmart for under $4 for 6 of them.
May 19, 2008 | White Sewing 1632 Mechanical Sewing...
Changing stitches on a White 1418 sewing machine...
I have a White 1418. Here's how you do it:
1. Attach the buttonhole presser foot (should have come with your machine) and place the fabric underneath.
2. Set the stitch length knob to 0, the zigzag width knob to 5, and set the needle position to center. Sew 3-5 stitches.
3.Change the stitch length to 0.5, the zigzag width to 2, and the needle position to left. Sew to the entire length of your buttonhole.
4.Set stitch length knob to 0, zigzag width knob to 5, and needle position to center and sew about 3-5 stitches
5. Set the stitch length knob to 0.5, zigzag width to 2, and set needle position to the right. Pressing the R button (reverse button), sew up to the top stitches.
6. Remove the fabric and open the button hole with a button hole cutter.
Sounds complicated, but it's really easy. I love this machine, you just have to know how to use it!
Sep 18, 2007 | White Sewing 1418 Mechanical Sewing...
Brother XL-5130 Mechanical Sewing Machine Logo
78 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
