Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile refrigerator
Freezer temperature fluxuates -20 to +20 for a few days then thaws out gets warm till i shut it off for about 3 hours and defrost. then will repeat cycle. other side works good till just before it thaws out then the lower half of frig freezes ( veggie drawer).
  • Anonymous Jul 13, 2008
    my ge stainless steel refig. is not automatically turning off. The freezer side from the inside and out is very very HOT. I shut it down to cool it off for about a hour.
  • jeanfischer Dec 22, 2008
    Coils behind freezer rear panal completely freeze over then it gets very warm. I replaced the defrost timer but that did not fix it
    Champion:
  • 210 Answers
Sounds like a defrost or sensor problem. or the main P.C.board. probably the board and sensors.
Posted on Jul 22, 2008
2 Suggested Answers
SOURCE: ge profile refrigerator
I just read on another site that the fluctuation is a normal part of the defrost cycle. (Down to -15 first then up to 15+). I have this hapen in my side by side. Also notice that the -15 in the freezer seems to be cold enough to sometime freeze the lettuce. Also on when the freezer is at 15+ now my ice cream melts. This is sad, if this is normal?
Posted on Mar 22, 2009
Freezer and refrigerator are not keeping cold
the thermostat controler is most likley bad this is where you set the temp with the knobs you can find the parts online with the model number please rate- jeff
Sep 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Arctic Side x Side Refrigerator PSC23MGNA
if you were able to do the test... check the compressor unit, also the do check on the electrical relay of the ref.
Jul 01, 2008 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
GE GSS25QSTSS Side-By-Side temperature controls isn't working
I bought a GE profile Side by Side refrigerator PSS26NGPBB for $1,800. The temperature settings won't hold. We were gone for the day, came home and found our food all thawed in freezer. Inside temp both sides is now 70 degrees. Whats wrong???
Sep 17, 2010 | GE GSS25QSTSS Stainless Steel
GE Profile Refrigerator defrost cycle last hours
it;s probably not going through the defrost cycle or its getting stuck in defrost .. on the back of frig the is a metal cover plate . in side you will find the main board . replace it . it runs the compressor and defrost and controls tempt . this is a very common problem . the new boards are better . and they cost a litle more . mm hope this helped / feed back pls .
Feb 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer temperature is not consistent
No recall that I have on my listing for that model. Keep in mind that the refrigerator goes into a defrost mode that lasts up to 30 minutes. It happens anywhere from 10 hours to 60 hours of operational time. When this happens, it's not uncommon to see 20 ° temperature. If you check it again an hour later, it should be back under 10 °. Also, double check to be sure the condenser coils are really clean. That alone can also cause this sort of symptom.
Oct 24, 2017 | GE Refrigerators
Power is on but nothing is working, not cold ,no water, no ice
Sounds like the unit needs a reset of sorts, Get your food into another refrigerator or ice chests and unplug the unit. let it stand open for several hours (just in case the vents are iced) and then plug it back in.
Jan 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
154 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
