Question about Integra DPS-8.3 DVD Player
Integra DPS 8.5
Hi,I turned off my DVD without thinking as I was running out of the house instead of the main power button on our Creston remote box. It is part of a whole integrated tv/stereo system. Now I come back to the house to resume playing music again with DVDs and the DVD player will not respond. The button for Standby is lit but when I press on nothing happens and the usual routine I go through to get DVDs to work doesn't work anymore. It appears that the DPS 8.5 is stuck in standby mode. How do you get it out of standby mode? The receiver or whatever it is called is also Integra DTR 6.6. Can you help? Thanks. Stephanie
The Integra DPC-8.5 changer (as opposed to the DPS-8.3 single-play unit -- not sure which you have, as you mention DPS-8.5, a non-existent model) and most of the integra line of players, will sometimes be thrown into brainlock by out-of-step shutoffs. They will usually respond to the Integra/Onkyo instruction manual's directions to turn it off (you're already done that), then unplug the power cord from the back of the machine, wait a few seconds (make it 30 to be safe), then plug it back in and turn it on via the standby switch. The screen should display its welcome message, cycle through startup, and being working again. It is very much like rebooting a PC. In fact there is little difference.
If this doesn't work then something has gone wrong inside and probably has nothing to do with your shutdown method on the way out the door. These things do happen. Hopefully by now you've already figured this out. If not, give it a try. It usually works.
Posted on Jul 29, 2008
Unit model D-C350/XSA only opens region 4 need to also to open region 2 DVD's
When I was with Samsung NZ, the following was how we multizoned our DVD (Region 4) players:
1. Turn on your player, but ensure no disc in machine - screen should show "No Disc"
2. Turn on your TV and select your DVD input (as if you were to watch your DVD).
Using your factory supplied remote, press the following buttons:
3. Press the Repeat (or Repeat A-B) button
4. Press the following button sequence: 7, 6, 8, 8, 4, 9 (you should see the number '9' appear on screen - this means 'Region Free').
5. Press the Open/Close button (to open the tray)
6. Press the Open/Close button again (to close the tray)
7. Press Power OFF (to shut down your DVD player)
8. Press Power ON (to turn on your DVD player)
9. Insert Region 2 disc and wait (up to 1min) for firmware to respond and read your disc
If this fails, try procedure again, except for Step 4: change the last number (instead of 9) to '2'.
Let me know how you get on.
Cheers,
Scott
"If this has helped you, please be kind enough to leave a testimonial rating"
Jul 09, 2011 | Samsung DVD-C350 DVD Player
I am unable to play DVD from different region on my Samsung ht-c655w??
Hi!
Follow this:
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and unplug from power. wait 30 seconds (this clears RAM)
4. Reconnect to power.
5. Turn on player with remote.
6. Press ENTER (middle button of the arrow keys) on remote. (ignore message on screen)
7. Press 8, 4, 2, 6, 9 using keys on remote.
8. Press ENTER on remote.
9. Wait until player finishes processing. (approx 15 seconds)
10. Player will turn itself off, otherwise turn off player with remote.
11. Turn power back on with remote.
Player is now Region Free.
Regards,
Pelu.
Mar 21, 2011 | Samsung Black DVD Player DVDC350
Hi, I have a problem finding a code for my motorola DCX3200 with my universal remote control(cox.) All the other televisions in the house worked, but I can't get this one to respond at all. I have an LCD...
Here is the user guide for the Motorola DCX3200 in PDF format just in case you need it.
Now then here are some Codes for your Cox Universal remote. I understand you have tried some already but just in case you missed any.
Samsung 0060, 0030, 0178, 0019, 0056, 0032
Also give this a try.
  1. Turn on the TV, VCR, DVD, or entertainment center that you want the remote control to control.
  2. On the remote control, press the appropriate mode button for the device once.
    Television TV
    Stereo amplifier or receiver AUX
    DVD, PVR, VCR DVD
  3. Press and hold the SETUP button until the selected mode button blinks twice, then release the SETUP button.
  4. Using the number keys, enter 9 - 9 - 1.
    Result: The selected mode button blinks twice.
  5. Aim the remote control at the device, and then press the POWER button once.
  6. Press the CH+ (or CH-) button one or more times until the device turns off.
    Notes:
    In search mode, the remote control sends IR codes from its library to the selected device, starting with the most popular code first.
    If, while pressing the CH+ button, you inadvertently pass the code, press the CH- button one or more times until the TV turns on.
  7. Press the SETUP button once to lock in the code.
  8. To search for codes for other devices, repeat steps 1 through 7.
Hope this helps, give me thumbs please!
Aug 23, 2010 | Televison & Video
The reciver dosnt get a signal from the hdmi inputs both ps3 and blu ray have the same problem it is a dtr 5.9 integra
what you should do is make sure that your HDMI is cord is not in an awkard position, which like mine i have to unplug and plug back in to get a signal
Mar 01, 2010 | Integra DTR-5.1 Receiver
Help with new universal remote.
Hi There,
The All for One Remote has a "Magic" button, instead of entering a code press the magic button and then press stand by, if the box does not turn on/off, then repeat the process (magic button and stand by) until it does. when it eventually goes off, store the code(i think you press ok).
Hope this helps..
Jun 03, 2009 | Daewoo DVDRW11 DVD Recorder
Pioneer plasma 42 inch tv won't turn on. power runs thru dvd. remote is sending signal and dvd has power.
There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
Jan 23, 2009 | Pioneer PDP-425CMX 42 in. Plasma...
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Scanner turning itself on and off??
I do not think u should try to fix it as it would void the warranty since your scanner is only 8 months old. Get it fixed by returning it to the vendor.
May 24, 2008 | Microtek ScanMaker i800 Film Scanner
Insignia NS PDVD8 Rgion unlock codes
I found a fix to my problem. This worked for me.
1) Power On.
2) Without a disc inside of the DVD player and using the remote control, press the setup button.
3) Press the right key on the remote 3 times and the preference page will appear.
4) Press 9653.
5) Use the up and down keys to select the Region.
6) Select 0 for all regions. 0 might look like a box.
7) Press the enter button.
8) Insert DVD.
9) If it works for you, then you're very welcome.
Dec 09, 2007 | Insignia NS-8PDVD
Integra DPS-8.3 DVD Player Logo
259 people viewed this question
Top Integra Televison & Video Experts
Are you an Integra Televison and Video Expert? Answer questions, earn points and help others
