Wireless with no cable to wireless laptop
Please help me - I have purchased a Belkin Wireless Router and brought home and it had to be wired to a PC to work - went back to store got a Linksys Wireless G router as the cheaper Belkin was out of stock. The clerk assured me I would not have to connect an ethernet cord to my laptop. The disk tells me to connect the blue wire from the router to the laptop - - -do I have to connect this to a computer with a wire in order to be wireless????
  • browe1956 Jul 04, 2008
    If this is just the first step, what is the next step?
  • 137 Answers
This is just the first setup step for you to access the router interface page to setup your wireless network name or SSID, encryption type, encryption key, etc ....
Posted on Jul 04, 2008
  • nsindian
    nsindian Jul 08, 2008
    connecting, wirelessly, using the settings from the first step.
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
Wireless connection
On your computer, click "view available networks".
Click to select the SSID that you created for your router.
Nov 06, 2009 | Belkin (F5D7231-4) Wireless Router
Have wireless signal but no IP
Starting from the obvious, check that the cables are installed correctly.
You have to have a cable that brings the internet to your place.
Connect that cable into the router's jack labeled Connection to Modem.
Then get another network cable and plug it into any other jack form the back of your wireless router, and the other end into your laptop, just to make sure you are getting connected.
Once you are sure you can surf the net, unplug the wire from your laptop, and you should be able to surf wirelessly.
And if you still can't connect, let me know to perform additional steps.
Please don;t forget to rate this answer if helps.
Jun 28, 2009 | Belkin (F5D7230-4) Router (587009)
Have you configured the Belkin wireless router?
You need to configure the Belkin using a 10baseT network cable first before you configure the wireless card.
To make your wireless router secure you need to use your browser and type in the Belkin IP configuration address.
Then you need to change the Admin password, change SSID and turn off SSID broadcast, setup the encryption (use WAP or WAP2 if your wireless card supports WAP) and for added protection use MAC address filtering.
Apr 12, 2009 | Acer Computers & Internet
Two pcs running vista home edition wired to router ok. laptop wireless ok. advent pc running windows xp wireless cannot see belkin router but can see outher router in my area. router is a belkin N wireless...
Check the router settings, if the router is set to only use 802.11N wireless it won't pick up a computer that is using 802.11G or 802.11B wireless.
Good luck
Nov 14, 2008 | Belkin Computers & Internet
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin n router.
change the wire less channels use 1 or 11>and always keep teh wire less pc close to teh router>and disable the fire wall in the router rate me solved if its helps thx
Nov 15, 2007 | Belkin (F5D7231-4) Wireless Router
Network problem- Router setup cd cannot get past stage 1- No access to router
Do you have DHCP enabled on your PC? Sounds like you are not getting the IP address.
Oct 05, 2007 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
