Question about Nintendo Video Game Consoles & Games
When new batteries have been put in both controllers of the wii, indicator lights supposed to indecate power level of batteries instead of which all blue lights flash then stop and nothing happens, no controls at all
    Sniper:
  • 55 Answers
If all the lights are coming on then going off again the controller needs to be synched with the wii. Once it is synchronized after all the indicator lights flash one should stay on indicating which player you are (1 -4)
To synch a controller to the wii:
Make sure the wii is in
Open the battery cover on the wiimote
Open the front panel of the wii
Press the synch button on the console
Press the red synch button on the wii mote
Should work for you.
Posted on Jul 04, 2008
I have a Wii game system model No. RVL-101 (USA) how do u get it to work
ok so u start to plug all the wires in the TV.theres a sensor that u need to put in middle of the tv.the sensor is like a rectangle and very lite its supposed to have a wire that has to be plugged in the wii not the TV.
after that its time for your controllers.you need to have at least one controller to play wii.you need to put two batteries at the back of the controller.then click the power button and you'll see the 4 lights light up,but then after seconds there supposed to be 1 light lit up.when your done than click the power button for the wii.for the controller to work u should turn on the wii before the controller.Then the easy part take the cd(game)and put it in the wii.
Dec 06, 2013 | Nintendo Wii Console
How do you charge your wii console
The Nintendo Wii is an innovative video game system and much like other video game systems within the Wii's generation, the controllers are all wireless. Because of the wireless technology, the controls must function on batteries in order to operate. Instead of having the game pause in the middle of the action, there are plenty of methods you can test to make sure your Wii remotes are fully charged.
instructions:
  • Charge you're the batteries to your Wii remote by opening the back clip and pulling out both AA batteries. If the batteries are the standard set that came with the Wii, you should upgrade them to rechargeable batteries to save time, money, and garbage waste.
  • 2
    Let the batteries charge for as long as the charger says. In most cases a full charge could take 6 to 12 hours, but fast chargers can fully charge batteries for an hour. Check the charger's manual detailed times.
  • 3
    Use a Wii Charging station for easier charging access. These stations avoid the process of opening and closing the Wii remote every time you need to charge the batteries and they work as a Wii remote stand as well.
  • 4
    Place the batteries back into the Wii remote once the charging has completed. With both the charging stations and rechargeable batteries, lights should indicate when the charging has completed.
  • 5
    Power up the Wii and press any button on the Wii Remote in order to turn it on and connect with the Wii.
  • 6
    Press the "Home" button the Wii Remote control. This button is in the center of the controller and features a small picture of a house on it. A pop-up menu will appear over the screen.
  • 7
    Look at the menu and find your controller number. Right next to the assigned number is a remote battery meter. It will feature 1 through 3 bars to indicate battery level. If it has 3 bars, then the Wii remote is fully charged and ready for use. If it has any less bars then the remote can be used, but is not fully charged. If the battery meter is in red, the remote will shut off soon because there is not enough battery power.
  • Dec 06, 2011 | Nintendo Wii Console
    I have 3 wii remotes was using one that had batteries it died so i replaced all remotes with new batteries and now none of them will sync or work they just turn off right away
    After replacing the batteries, you may have to do a hard sync by pressing the sync button beside the SD slot on the Wii and the sync button on the back of the Wiimote underneath the battery cover. Both buttons are a kind of dark reddish-brown colour.
    Mar 25, 2011 | Nintendo Wii Console
    I just put new batteries in my Wii controller & it won't turn on. The Wii itself is on, but the controller won't turn on. How do I sync it back?
    1. Press the Power button on the Wii console to turn it on.
    2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
    3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
    4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through
    Nov 30, 2009 | Nintendo Wii Console
    My wii remotes wont pick up signal blue lights flash then just go back out again
    Hi, check the batter level and then try re-synching the remote's.
    Here's instructions for both:
    f4bc8924da.gif A fresh set of alkaline batteries should last, depending on amount and type of use, up to 35 hours. This can vary greatly based on certain factors, such as Wii Remote Speaker Volume, Rumble, battery quality and age, and type of game being played.
    Important Note: If you are using rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
    There are two ways to check the Wii Remote's battery levels:
    • Remove the battery cover and press the Red "Sync" button. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength, with one light flashing indicating the lowest level.
      or
    • Use the HOME Menu to check battery level of each Wii Remote:
      1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
      2. Select the Wii Remote Settings option from the Home Menu.
      3. The battery level of all synced Wii Remotes is displayed along the bottom. Four bars indicates a full charge, with one being the lowest charge.
    55851daefd.gif Note: Make sure you have placed batteries in the Wii Remote.
    2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
    3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
    4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
    This procedure must be followed for each additional Wii Remote added to your system.
    I hope this helps
    Mike
    Jul 30, 2009 | Nintendo Video Game Consoles & Games
    Slot Light
    The disk slot comes on briefly when:
    -You turn the power on
    -You put a disk in or take one out
    And it pulses when you have a new message on your Wii message board. It does not stay lit while the Wii is on.
    Jan 17, 2008 | Nintendo Wii Console
    Wii consoles not working
    Hold in the power button on the Wii console for about six seconds until it powers off. The light on the power button should turn red after you do this, not amber. Press the power button again to boot the Wii.
    9 out of 10 times this fixes all weird issues. If you simple power it down to the amber light, it's not actually off, so you really aren't getting a "cold" reboot.
    Good luck.
    Dec 27, 2007 | Nintendo Wii Console
    Gamecube controller [suddenly] not working with Wii
    logic 3 controllers are not good, return the logic 3 controller to the store and buy a NINTENDO wavebird instead, i bought mine used and it is perfectly fine. you might have the controller plugged into port (....[4]) instead of port ( . [1]) so try that or buy a wavebird instead ( if you ask me , buy the wavebird). I think my sister's friend's brother had the same problem. But he gave up on it. Probably faulty. Third party gamecube and wii accessories (excluding nyko) are bad or do not last very long.
    Sep 19, 2007 | Nintendo Wii Console
    Remotes
    When the lights are blinking like that, it's indicating the battery level, and also indicates that the wiimote is not connected to the wii. Replace the batteries in the one with the left light blinking and see what happens. Try turning off the wii, and pressing the power button on one of the wiimotes. It should turn on the wii and then the far left light will turn solid. Then press a button on the second wiimote and it should connect. If it doesn't, press home on the first wiimote, go to the settings at the bottom, and click Reconnect. Then follow the onscreen instructions and the problem should be solved. Note: my account name is supposed to be ryanriopel28..
    Aug 09, 2007 | Nintendo Wii Console
    Video Game Consoles & Games Logo
    107 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
