Question about Kenmore 15218 Mechanical Sewing Machine
Bobbin in catching.
The bobbin is threaded, but tends to catch and then bunch up under the plate. Any solutions?
    New Friend:
  • 46 Answers
This really sounds like it is a simple top threading problem. Please check your threading path at the take-up lever #3 of the 4 steps. If the thread comes out of the take-up lever or it was missed during threading, the machine does not receive any top tension. No top tension means that the machine is being flooded with thread and wrapping around the shuttle hook.... jamming up.
If your machine is currently threaded, leave it threaded follow the thread from the spool through the first thread guide at #1 straight down to #2 and up to #3 (make sure that the thread is through the take-up lever (silver hook) at #3 from three you will bring the thread straight down to the thread guide that is to the left of the needle. Thread the needle from front to back.
Posted on Jul 29, 2008
Why does bobbin thread keep snagging?
increase the needle thread tension up a bit as it is too loose to pull the bobbin thread up properly
keep adjusting until both threads are at the middle of the materials being sewn
Mar 25, 2016 | White Sewing 1418 Mechanical Sewing...
Why does my thread keep bunching up?
That is called "thread nesting," and several things can cause it. The upper thread enters the bobbin area during sewing, catches the bobbin thread, and as the needle goes up, pulls the stitch tight. Something is catching the upper thread as it goes around. The most common reasons are the bobbin or bobbin case (or both) is improperly inserted; the bobbin is warped (roll it down a flat surface--if it wobbles, it's warped), either the case or the bobbin is not seated evenly, there is a rough spot on the bobbin case that is catching the thread, or your bobbin is loosely/badly wound. You need to rule out the possibilities step by step until you find the cause. First, review your threading procedures from start to finish, using your user's manual. Then, without fabric, turn the hand wheel by hand (ALWAYS towards you) to see if you can see it start to catch. The top thread should rotate smoothly in the bobbin area. You should be able to pin-point the cause that way.
Sep 24, 2014 | Singer 2517 Mechanical Sewing Machine
Thread tangling inside bobbin case catching on another part
1. thread machine correctly.
2. make sure bobbin case in spinning in the case in the correct rotation. If the bobbin is spinning off of the bobbin incorrectly, "bird nesting" is the result.
Jul 20, 2014 | Brother NX-400
How do I put cotton on machine
Paul... youtube it.... It's really not difficult. Have to load bobbin with thread first... install bobbin (under the needle plate in its holder) thread cotton from top of machine through the correct catch points to the needle.... catch the thread from the bobbin..... pull threads under pressure foot (but look in youtube... loads of vids)
May 16, 2014 | Janome Sewing Machines
Bobbin thread bunching and top thread breaking
After double checking your threading path, changing your needle, ensuring you have good quality thread, and cleaning under the needle plate and in the bobbin race area, if none of that helps your problem, check the hook that goes around the bobbin for a burr that could be catching and not releasing the upper thread on its trip around the bobbin. Remove the hook from the race if you can, and run your fingernail from the base to the tip of the hook on all sides, watching for it to catch on something. If it does not, let me know and I'll dig deeper. If it does, use a very fine emery board or cloth and just barely touch it to the hook, stroking from the base to the tip very very gently. That should knock the burr off, reassemble and test.
Apr 28, 2012 | Singer Sewing Machines
I have threaded up my machine and have started to sew. The thread on the back of the fabric keeps catching and bunches up. What's going wrong?
try a new needle
keep a check on the thread take up lever that the thread doesn't come off of it
rethread the machine to make sure that the thread isn't catching on anything
clean under the needle plate for loose thread or lint & in the bobbin area also
make sure the bobbin is inserted correctly
Aug 04, 2011 | Bernina 1008
Top thread won't catch the bobbin thread
First check the upper and lower tension adjustments according to link below and then check the knob (bobbin case) that makes the bobbin tension which lies inside the shuttle if it is too loose. Restricted it with the sheet metals around it so that it shouldn't move so freely up and down or back and forward. Be careful it should move freely a little but not too much.
Feb 24, 2010 | White Sewing W3300 Computerized Sewing...
Thread is bunching up unside of the material does not catch bobbin thread
This sounds like the tension is not set properly for what you are sewing.
Oct 23, 2008 | Kenmore 11206 / 11306 / 11506 / 11606
Singer 3962 Thread Catching Under face plate (catching on position finger)
I had a problem with the thread balling up under the face plate, too.
I have a Kenmore 385 16528000. I don't know if with other brands that this will pertain to them, but this was my solution:
I had the needle in the wrong way! The top part of the needle that is inserted into the machine needs to go in with the FLAT SIDE AWAY from you. So I hope that helps somebody!!
Jul 13, 2008 | Sewing Machines
Kenmore 15218 Mechanical Sewing Machine Logo
159 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
