Question about Sony PlayStation Portable (PSP) Console
I have a pandoras battery for my psp. I used it a couple of months ago and it worked perfectly. Then i just left it in my room. Today i went to try and use it and found out it wasn't working. I went and plugged it in to charge... It said 0%. I left it about ahlf an hour then went back to have a look. after the half an hour it was still 0%
    Sergeant:
    Champion:
  • 417 Answers
Needs New Battery Cells Have Frozen Up Or Just worn out
Posted on Jul 04, 2008
I have psp 3004 and
well ur asking a lot here. 3004 arent that easy. sony is making sure people like me.. or us and my friends cant use the handy software provided by coders and hackers[thank them] well from my expertise i was lucky in that the person who first modded my psp 1001 had to turn my psp phat battery into a pandoras battery. His slim psp was already modded with a method he claimed and showed me that he cut one corner of a chip in the battery case which let him run the update software to mod it.. so with his software on his slimn psp and a computer program that installs pandora files threw usb connection he made my battery into a pandoras which i still have.
So know i can use it to mod psps!!!!!! and i have software that can turn phat psp batterys into pandoras no problem. i just put that batterty in mine phat psp 1001 and run the program pandora installer providedby ppdv1.0 and usedbattery options and hit pandorize battery. i tryed using a slim battery on my phat and that damaged the battery and had to buy my friend a new one..
So what im trying to get to is if you can get a pandoras battery then i can help you,.
my friend has a Slim psp 2001 and i put the same modded software and the same process with my phat and it worked! so as long as you get a pandoras battery then you can run the software!!!
http://forums.afterdawn.com/thread_view.cfm/688507 this site showed me how to mod a psp with a pandoras batterty i already had. its worked on every psp i have installed the software[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[warning WHEN INTSALLING MODDED SOFTWARE OR ANY UPDATE SOFTWARE FROM SONY YOU MUST HAVE YOUR PSP PLUGED IN AND A FULL BATTERY IF YOU DONT THE PSP MAY DIE AND MAY HAVE NO BRIAN{BRICKED} YOUVE BEEN WARNED}}}}}}}}}}}}}}}} but also just start the update program
ok so i did this 1. got "net framework version 2.0" and run it! find it by using google! 2. I then installed the psp pandora deluxe version 1.0 like stated in the website 2. find the Officail firmwares OFW 1.50 OFW and 4.01 OFW.. there are plenty of good sites just google each firmware.
then start psp pamdora deluxe and make sure ur psp is connected threw usb connection and make sure you know the drive name of the psp and select the it and then go to 1.50 and chose the eboot file and then 4.01 eboot file and then check them and then check 1.50 noonz downgrader and the despertar cemtrenio v6 [4.01 mm33 2] and then set dcv6 to the left button and the others as you plz and then check format memory stick and then hit other options and check add 4.01 m33 1.50 addon and then check suppot tolls for pandora and then support for xmb and the chose to run and hit yes and wait and now you have a magic stick which now needs a pandoras battery like mine to use
so you need to find out how to make a slim battery into a pandoras batterty without help from a phat battery. try looking up ways to make a pandoras batterty using a program that runs while ur psp is in usb connection and then the program asks for what drive your psp is and you selct it and then run it accordling .. sorry so much info
Jul 08, 2009 | Sony PSP-3000 Black Console
My psps firmware is 5.50 and i want to downgrade it to 5.0 without pandora battery..
There's various methods of doing this to be honest.
The best one I have is one I used a couple of years ago here...
http://pspupdates.qj.net/Tutorial-How-to-unbrick-your-PSP-via-Pandora-Battery/pg/49/aid/100693
It tells you step by step what to do. It will take a while so make sure you set aside a couple of hours for it!
I will also email you the link just in case it doesn't work on here.
Best of luck dude.
Craig
May 27, 2009 | Sony PlayStation Portable (PSP) Console
PSP black screen
IF PSP is being disturbed or power went off by any means while upgrading system software. It is sure that your PSP is bricked and now you had the only option to get repaired by a technician and it is done with the help of Pandora's Jigkick Battery. If you required any more info please write.
Sep 08, 2008 | Sony PlayStation Portable (PSP) Console
PSP
Try replacing the battery. Alot of times when anything thats rechargeable have not been recharged for that long then the battery cells weaken to the point it won't hold a charge. GOOD LUCK!!!
Aug 09, 2008 | Sony PlayStation Portable (PSP) Console
I have a sony 2001 PSP, and I've had it for less than a month and just recently I tried to use it, when i attempt to turn it on I press the power button and the green light (which shows that the PSP is on)...
For how long have you NOT been using your PSP? and did anything happen before you even tried using it AGAIN? Do you have others in your area who has a PSP? if nothing happened to your psp before you tried using it again e.g.accidentally fell or something like that, then just try to use a different WORKING psp battery...if it didn't work, then prolly your PSP went brick and the only solution for that is a pandora kit...
Jul 22, 2008 | Sony PlayStation Portable (PSP) Console
My PSP wont turn on
your psp entered a stage called a brick it happens to alot of people for very different reasons let me just tell you what to do look up on google or somthing the pandoras battery look at it admire it then ask everyone you know if they have the pandoras battery this happened to me today i asked the friend about the pandoras battery he had it and used my psp came back from the dead!! so ask everyone you know about the pandoras battery!
please comment on my answer
Jan 02, 2008 | Sony PlayStation Portable (PSP) Console
PSP no power
Try taking the battery out and plugging it into the wall with only the charger and see if it turns on. does The green light came on?.
Jan 01, 2008 | Sony PlayStation Portable (PSP) Console
New psp wont turn on!
IT IS BRICKED use a pandora battery go here for more info: www.console-crazy.com
May 07, 2007 | Sony PlayStation Portable (PSP) Console
PSP Bricked?
Brick has two signs
A. semi bricked - your are able to go in the recovery menu (open your psp and hold the right trigger in 5 seconds)
B. fully brick - u can't go to the recovery and not charging
A.semi- brick
  • Things you will need:
  • A psp and a pandora Battery
  • 1.first download this padora file http://www.megaupload.com/?d=U4I65Q7F
  • 2. go to recovery mode of your psp
  • 3. then press toggle usb
  • 4.format the memory stick
  • 5.put the padora files root of the psp
  • 6.put the pandora battery in the psp
  • 7.press the x button when you see a menu
  • 8.then follow the instructions shown on the screen on psp
  • 9.your done you can now delete the files!
  • congratulations!!
B.Fully bricked
  • Things that you will need:
  • Card reader/writter
  • Pandora battery
  • 1.download the pandora files that use in semi bricked
  • 2.use the card reader/writter
  • 3.fomat the memory stick
  • 4.place the pandora files in the root of the memory stick
  • 5.put the memory stick in the psp
  • 7.press X button when u see a menu
  • 8.follow the instructions
  • 9.done u can now delete the files!
THATS ALL!!
Dec 04, 2006 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
27 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
