Question about Fagor Dishwashers
Fagor Dishwasher FI-48w Replacement Parts
Is therer anywhere on the web where I can purchase replacement parts? I have searched and come up empty handed.
-Angelo
  • vickie
    vickie Mar 31, 2017
    partstown.com
Angelo,
We are the manufacturer; Fagor Commercial, Inc. We have a network of parts distributors for our products. contact us to provide you with the most convenient one for you.
305 779 0170 or 1-866 GO FAGOR
Thanks
Posted on Jul 09, 2008
THe dishwasher is not draining and runs out onto the floor. What should we do?
Drain is plugged between the sink and dishwasher. It has to be unclogged. best advice call a plumber. other tricks fill up the sink with water and use a plunger to pull the sludge through.
Feb 25, 2014 | Fagor 24 in. FI-48W Dishwasher
Fagor F1-48W dishwasher won't fill
this must be a water flow problem to machine , id look real carefull at valves under sink or under floor of machine to see that there open and there are no kinks in hose connecting to it , other than that the one only other reason that it would not add water is that it thinks there's water in it already
Dec 21, 2012 | Fagor Dishwashers
How long should the dishwasher take to heat the water for wash and rinse to the required temperature after the dishwasher has been turned off for a week? Thanks, Mark
typically a general rule of thumb is 2degrees fahrenhiet per minute so if if its 72 dergees (22C) (normal room temp) it would take 36 or so minutes to reach 145 f (62c)
Aug 08, 2011 | Fagor 24 in. FI-48W Dishwasher
My undercounter commercial Fagor FI-48W dishwasher is not cleaning dishes even when the scraped and rinsed. Does anyone have a recommended commercial detergent. I also need information concerning hardwater...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
;l';l;l
Sep 26, 2010 | Fagor 24 in. FI-48W Dishwasher
No instruction manual
The instructions are available in
http://www.fagor.com.au/manuals/dishwashing/versionw/FI-48W,%20FI-64W.pdf
Hope this helps. Please post a comment to say if you found this useful or not.
Apr 20, 2010 | Fagor 24 in. FI-48W Dishwasher
Need to replace door spring
I have a similar, but not identical, model. The method is to remove the plastic lower moulding and the relevant side using a star-type screwdriver, then the spring is visible and a replacement easily slipped into place.
Apr 07, 2009 | Fagor 24 in. FI-48W Dishwasher
Fagor f1-48w
The machine won't go into rinse if the rinse isn't hot enough. Check the thermal trip hasn't operated and that the thermostat bulb us fully inserted into the pocket in the front of the boiler.
Jul 02, 2008 | Fagor 24 in. FI-48W Dishwasher
The correct way to start the wash cycle
we have just purchased a Fagor dishwasher also - the instruction manual is worthless.
in regards to the 2 thin tubes, we just inserted them in the gallon jugs that the soap/rinse agents comes in and it works fine. just make sure the clear tube without the label goes in the rinse agent and the labeled tube goes in the soap jug. we did drill a hole in the top cap of the jugs and pushed the line thru and that helped keeping the tubes in the jugs and minimized the mess if the jugs fell over.
in regards to the temperature problem, we found that running it thru a couple of cycles before you start the actual dishes helped get the water temperature up faster. it seems to like to start with normal tap hot water first, so the 1st couple of cycles get the cold water out of the line.
Dec 29, 2007 | Fagor 24 in. FI-48W Dishwasher
Dishwashers Logo
2,498 people viewed this question
Top Fagor Dishwashers Experts
dannydoesita
ray gallant
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
