Question about IBM ThinkPad T23 2647 Notebook
Motherboard IBM T23 THINKPAD
Ive replaced the motherboard w/ a not know good one- now everything works but screen comes up white-no word - not attempting to boot up
    Genius:
  • 2,028 Answers
Double check to see if you got everything on the board connected properly.
Posted on Jul 04, 2008
Ibm thinkpad t23, will not come out of sleep mode even when manually turned off and on. Cooling fan comes on, only blank screen.. I have removed battery and let it sit for a while, and then restarted it,...
Please press F8 at boot up and boot in safe mode. Restore to a previous date given in bold numerals.
Alternatively, after F8 select Last Good Boot up.
Mar 16, 2010 | IBM ThinkPad T23 2647 Notebook
ThinkPad T23 white screen
1. your issue may be a bad hard, a damaged or loose flex cable to the LCD screen, a defective CPU (central processing unit, a cmos battery that needs replacement ( this is the battery that retains the information for the motherboard), a bad power supply regulator on the mother board.
2. this is just a few of the issue that have caused a white screen.
3. Laptops are mostly disposable and are usually good for 2to 3 years of service depending on the care taken.
Your friend probably thought he was helping by giving this to you to see if you could use it or part it out.
Not worth the work unless you are into PC repair or project work.
2.
Mar 03, 2010 | IBM ThinkPad T23 2647 Notebook
Ibm thinkpad t23 shutting off after 10 minutes or so
Your CPU is overheating and the solution is a laptop cooling pad which will save you the cost of another motherboard.
Apr 13, 2009 | IBM ThinkPad T23 2647 Notebook
How to repair ibm thinkpad t23 laptop screen no light
Yes you have no backlight. The screen is all dark but in the back you can barly see it. You inverter is bad on you thinkpad. You need to replace it. I have a IBM thinkpad 600e and i got one for $9.95 so they can be cheap. They are located under the lcd. When you open it up it is there or can see that it is attached to the light dimmer swicth so you will know that is it. Thats your problem
Sep 20, 2008 | IBM ThinkPad T23 2647 Notebook
T23 no sound at all...
HELLO. SOULD'S LIKE U NEED TO INSTALL YOU DRIVER'S FOR YOUR SOUND CARD. YOU CN GOT TO THE IBM.COM SUPPORT AND THERE U WILL FIND WHAT U NEED TO HELP YOU. U WILL NEED TO CLICK ON .!!! LENOVO SUPPORT& DOWNLOADS-DRIVER & SOFTWARE-THINKPAD. THERE . YOU WILL FIND ALL YOU NEED TO FIX YOUR THINK PAD & AND ALL IT'S PROBLEM'S IT HAS. THAT'S WHAT SUPPORT IS ALL ABOUT. !!! HOPE THIS HELP'S U. LET ME KNOW OK.!!! GOOD LUCK.!!!
Jun 19, 2008 | IBM ThinkPad T23 2647 Notebook
No video on Ibm Thinkpad T23
hi
i also have a t23, and i have messed around with the display a lot...
there are several things to consider:
1) your operating system. i would assume you are using windows xp, and that you dont get video even before the OS starts up in the first place, but its just something to consider: i have heard of some video bugs with the t23 under linux
2) you should check to see if the laptop display and the video out problems are related in the first place. to be honest, i dont know why they would or would not be related. the display not work because a) its just plain broken (although in this case there are usually some somewhat obvious cracks) b) the ribbon cable from the display to the motherboard could have ripped (they do so very easily). if the ribbon cable is ripped in its usual place, you MIGHT just not have a backlight. make sure that there is nothing on the screen, not just a normal display extremely dark. if theres definitely no picture, then you have to take the laptop most of the way apart, but you can start with just the screen casing. its fairly easy to figure out how to take apart, but you might want to look it up. behind the screen casing you can see the ribbon cable and whether or not its ripped. oh, but before you do that, try turning the led light on thats built into the top of the screen. its also part of the ribbon cable. you can do this by pressing the fn key and page down or something next to the brightness buttons. if that doesnt work then your ribbon cable is either ripped, or of course it could just be a motherboard problem in which case all of what ive said is fairly useless information. if you want you can also take off the keyboard and top casing from the screws in the bottom and look at where the ribbon cable (and maybe the video out too) meets the motherboard, just in case theres an obvious problem or disconnect. it probably wont be very obvious. however, if you do discover fairly surely that it is the ribbon cable, then you can get them for very cheap. search "ibm thinkpad lcd video cable t23"
hope i could be of some help
Mar 17, 2008 | IBM ThinkPad T23 2647 Notebook
White screen Ibm t 23
Have you tried switching the LCD monitor from teh good thinkpad to the ones with white screens? Sometimes its the actuall LCD.
Mar 16, 2008 | IBM ThinkPad T23 2647 Notebook
T23 wont boot
I would unplug it and remove the battery. Plug it back in and try without battery, if it still doesn't work, unplug the power again and remove the memory (RAM). Plug it back in and try again without RAM, if it beeps then the motherboard is probably good. If you had more than one piece of RAM, try one at a time and see if you get it to boot with one of them.
Jan 11, 2008 | IBM ThinkPad T23 2647 Notebook
Does'nt come on at all
Can you access the bios? If you are able to get a bios screen, the problem is not the processor unless it's overheating really fast. See if the vent for the fan is clogged with dust/hair/etc. Also, the memory is a possibility. Instead of swapping it out tho, just put pressure on it in such a way that it's pushed down on the motherboard. These ram slots are known problems. Try it, you may be surprised. Good luck
Oct 08, 2007 | IBM ThinkPad T23 2647 Notebook
IBM ThinkPad T23 2647 Notebook Logo
205 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
