This problem is generally caused by a bad wall control or the wiring going to it. You can easily eliminate both possibilities by removing the wire at terminal #1 on the rear of the motor unit. If the problem stops with the wire removed you can replace the wire at terminal #1 and remove it from the rear of the wall control. By a process of elimination you can find the culprit.
