Back to:
Tags:
Washing Machines
Generic problem for all Washing Machines
What is the easy way
posted by georged47 on Jul 04, 2008
what is the easy way to put on the belt for a kenmore stylemaster 902202?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 04, 2008
Not Rated (0)
Richie_asg1
Rank:Guru Guru
Rating: 86%, 181 votes
If this is the one I think it is, I think "two people" is the best answer. or one person with 3 hands. Your choice.
If you can wedge the tensioner back, this helps.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on what is the easy way:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
Washing Machines
Model: LSQ9564MQ0 The transmission coupler was replaced...
Washing Machines
Frigidaire (ATF6000ES) Front Load. My machene motor is...
Frigidaire (ATF6000ES) Front Load Washer
My washer is a little over two years old and we've never...
Estate TAWS800JQ Top Load Washer
Washer not spinning, not drainin. Started making whirring...
Kenmore 43142 Front Load Washer
The washer runs threw all the cycles perfect until it is...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
