Kenwood KA895 Amp and get no sound through left speakers. Checked wires and swaped with right seems issue is in the amp
  • Anonymous Oct 20, 2008
    I've got no sound coming from any of the speaker ports. did you find a solution?
techman
  • 3130 Answers
SOURCE: Volume turned up, kenwood shuts off briefly...
If this is in a boat, I would check the amp unit for moisture damage, as a marine items is a specially built units that fends off water as well as moisture damage exposture. it does not mater if the amp is enclosed inside the hual or cabinet. The problem you are encountering is most likely because of a bad main amp unit, as if you disconnect the speakers and turn uo the unit, and it still goes into protection or shutdown mode, something is wrong with the amp. Like I said before, the fault is most likely due to water damage or moisture damage to the main printed circuit board. Good Luck.
Posted on Mar 24, 2007
  • 231 Answers
SOURCE: Right side speakers don't work
if you are using RCAs as inputs to your amp.Swap the R to L @ RCAs to see if its comming in okay from radio.If both RCAs have audio then amp is bad ,If amp has any type of switches , move swithces to see if it comes back .Also if both RCAs inputs have audio .Move the RCAs when connected on amp to see if amp has bad connection in board to RCA jacks..If audio comes back on bad side when jack is moves .Then you have bad solder joints on board..If not then you must have bad outputs on amp..
Posted on Dec 24, 2007
  • 979 Answers
SOURCE: have a kenwood a85 amp
Make sure that you have Speaker A or B selected...accordianman
Posted on May 01, 2008
SOURCE: Kenwood KAC-8103D 1000 watt issues
Apparently it won't let me log in. Anyhow... I'm pushing voltage. The light is flashing, not flickering. How can I replace the transistors?
Posted on May 15, 2008
tech48
  • 624 Answers
SOURCE: Denon AVR-3802 Front Left and Centre channel not working right
I work at an authorized Denon service center and have repaired lots of Denon receivers including this model. So bare with me, and trust that I really do know what I am talking about.
The first thing you need to do is find out if those two speakers may be at fault. You can do it very easy by disconnecting them and connect two of the known good speakers into the channels that the bad sound is coming from and then connect the suspected bad speakers in where those good speakers were connected to.
If the same speakers still sound bad, you know that you have a couple of bad speakers. I think that it is likely that the speakers are OK, but it is a good idea to make sure.
If the sound from the suspected bad channels is now still bad with the two good speakers, you have an internal amplifier problem or you have a problem on the digital board.
For your sake, I hope it is the amplifier that is giving you this problem, if it is, that can be fixed by a good audio technician.
If the problem is the digital board, you may be in for some real headaches. Not that many audio techs are very good at troubleshooting a digital board, its not their fault, it is just a very difficult job.
In either case, it will need to be looked at by a qualified technician.
I hesitate to tell you this, but the problem sounds like a digital board problem. In some rare cases, a technician with excellent soldering skills can reflow a couple if the memory IC's on the digital board and restore proper operation. If the technician is top notch and isolates the problem to a specific IC on the digital board, they can replace that IC and you are good to go.
But in most cases, the technician will not even bother trying to troubleshoot the digital board because it can take hours of troubleshooting, and just order the board if it is available. Most of them are available from Denon, but they are very expensive. Normally the part alone is $200 to $300 and I have seen many times where it takes months to get it.
You can also send it directly to Denon's factory service center and that will get your unit back much quicker. They have direct access to the boards, where-as the authorized service center must order it thru one of the Denon parts distributors and they do not always have them in stock. so you end up waiting for a long time.
If you need to send it to the Denon factory service, let me know and I will email you a return authorization form, this must be faxed or emialed to Denon with the proper information and then they will fax or email it back to you with the RA number which must be written on the outside of the box before shipping it to them.
I hope that this information wasn't to overwhelming, but if you found it helpful a good rating would really be appreciated. It helps to keep the experts on FixYa motivated and willing to answer the questions people have even it the answer is not very good news.
I received an "inappropriate" rating from somebody who just wasn't happy with the truth, and most people never even bother to rate our answers. But that's another whole subject.
let me know if you need more help.
Posted on Jun 22, 2008
Need a stereo wiring diagram
Hiya,
Here's the wiring connections for the Kenwood KDC-3025.
Black: Car chassis (-) ground wire
Yellow: Battery (+) wire (must connect to retain memory settings)
Red: Ignition/Accessory wire
White (w/black stripe): Front Left speaker (-)
White: Front Left speaker (+)
Gray (w/black): Front Right speaker (-)
Gray: Front Right speaker (+)
Green (w/black): Rear Left speaker (-)
Green: Rear Left speaker (+)
Purple (w/black): Rear Right speaker (-)
Purple: Rear Right speaker (+)
Blue (w/white): Power Control wire (used with ext. amp only). Do not expose this wire, if no amp is used.
Blue: Antenna Control wire
Brown: Telephone Mute wire (used with handsfree carkits).
Hope this helps,
Cheers,
Scott
Feb 01, 2013 | Kenwood Sirius KDC-3025 CD Player
Rowe r92 sound problem
Moving the wire indicates the speakers are OK. Try reversing the 3 pin plug from the cartridge. If the problem stays on the same channel, it is probably a preamp board issue. If the problem switches channels, you have a bad wire to the cartridge or a bad cartridge.
Nov 16, 2011 | Audio Players & Recorders
Trying to find a wiring diagram to install my kenwood kdc-mp342u into my 2001 grand am. any ideas?
Please let me know if you have any questions, and thanks for using FixYa.
2001 Pontiac Grand Am Car Audio Wiring Diagram kenwood kdc-mp342u
Car Radio Battery Constant 12v+ Wire: Orange yellow
Car Radio Accessory Switched 12v+ Wire: none
Run a wire to the fusebox for switched power. red
a 14 gauge wire will do--use a 15 amp fuse
Car Radio Ground Wire: Black/White black
Car Radio Illumination Wire: Gray (tape this wire off) none
Car Stereo Dimmer Wire: Brown (tape this wire off) none
Car Stereo Amp Trigger Wire: Pink blue
Left Front Speaker Positive Wire (+): Tan white
Left Front Speaker Negative Wire (-): Gray white/black
Right Front Speaker Positive Wire (+): Light Green gray
Right Front Speaker Negative Wire (-): Dark Green gray/black
Left Rear Speaker Positive Wire (+): Brown green
Left Rear Speaker Negative Wire (-): Yellow green/black
Right Rear Speaker Positive Wire (+): Dark Blue purple
Right Rear Speaker Negative Wire (-): Light Blue purple/black
Amplifier Mounted behind trim in the left side of the trunk.
May 19, 2011 | Kenwood Car Audio & Video
Which is the separation wire for the left and right speaker for Kenwood HDC222?
Function Typical Wire Colors Constant 12V(+) Yellow Ignition Switch Red Ground Black Illumination Orange/White Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Purple Right Rear (-) Purple/Black
Feb 16, 2011 | Kenwood Car Audio & Video
When playing records on my turntable, the right speaker often cuts out, almost completely (big dip in volume and a bit fuzzy sounding). It will then come back sometimes, when tapiing, fiddling with a the...
Check the wires to the cartridge, they can come lose and need to be tight. If that doesn't solve the problem check or replace the connecting cables. You can confirm it's not the pre-amp of your amp by just swaping the cables. Then the left speaker should play up. If it is still the right, then there's a fault on the pre-amp. But it could be just bad soldering somewhere. Also take the bottom of the turntable and check the soldering of the cables inside it.
Dec 08, 2010 | Sony PS-LX250H Turntable
I have no sound coming out of the speakers
Does the stereo have a switch in the back that switches between Amp and Pre-Amp ? Some units mute the high level speaker output if it's switched to pre-amp mode in the case where you would use the RCA jacks to route the low level audio to external amplifiers. I can you further if you give me the make and model. Also, good info could be found on details of your unit at www.crutchfield.com.
May 27, 2009 | Kenwood KDC-MP205 CD Player
My wife bought a kenwood z828/uf4. there are wires in the back but none of them are labeled. can anybody help me
red - 12v ignition
yellow - memory 12v cont.battery
orange - illumination
black - ground
white- front right speaker +
white/black stripe - front right speaker -
gray - front left speaker +
gray/black stripe - front left speaker -
violet - rear right speaker +
violet/black stripe - rear right speaker -
green - rear left speaker +
green/black stripe - rear left speaker -
blue - remote, amp
blue/white stripe - power antenna
if you don't have a blue/white strip wire than the solid blue wire goes to power antenna, amp and remote...........
hope this helped you
Feb 26, 2009 | Kenwood Car Audio & Video
Kenwood KDC-MP538U - no sound.
My issue was that I didn't have the blue "amp" wire hooked up and I had a factory amp.
Jan 06, 2009 | Kenwood KDC-MP538U Car CD/ MP3 Player
Radio on but no sound
i have a 1994 eagle vision, with the premium sound system (infinity) and yes you do have a amp in your car if you have that sound system and its in the trunk of your car to the left while looking at your trunk from the back of the car :) also if you tryed putting in diffrent speakers other then stock thats your problem you have to rewire new speakers cant use old wiring because it goes threw the stock amp and for some reason the stock amp only works with the stock speakers :P
Oct 01, 2008 | 1995 Eagle Vision
No Sound out of my speakers
The last Kenwood that I had witnessed with a flashing power light was defective. It also caused the subwoofers to move slowly back and forth. More than likely, you have an internal issue with the amp. Call Kenwood, and see how much they would charge to have you send the amp in for repair. Or pick up a new amp.
May 11, 2008 | Kenwood KAC-959 Car Audio Amplifier
96 people viewed this question
 Grubhead
Grubhead
