Should I change the bulb?
I have a 52 DLP Toshiba TV, for about a week when I turn it on it makes a sound like it's got an open circuit (makes a arching electric sound) Now I pulled out the bulb, looked at it. No wear or tear that I can see on it, bulb is fog free. The only thing is it is 5 years old, and I do watch a lot of video and TV. Could the bulb have some internal circuit burned out or is the whole dang TV just a huge paper weight now?
  • 78 Answers
Hi MovieJunkie9,
I would first recommend having a diagnosis done by a Toshiba authorized technician. Bulbs for projection televisions are typically a costly part, so I would not advise replacing it if you are not sure it is needed.
Second, make sure that your product's manual lists the bulb as a user-serviceable part and gives specific instructions for you to change the bulb to make sure you do not do any damage to your unit.
So long as your manual gives you instructions for changing your bulb and the Toshiba authorized technician diagnoses that the bulb is the issue, you should be able to go ahead and change the bulb yourself.
Thank you,
Go Ahead. Use Us.
Posted on Jul 09, 2008
Toshiba 52" dlp has picture but no sound
audio circuit problem, you have ruled most of the simple things out.
Dec 16, 2012 | Toshiba 56HMX195 52" HDTV DLP Projection...
Periodically my 52HM95 would have some little electrical glitch where it would not come on when I turned the tv on. I would have to wait a little while before I tried again, or I could shut the power off...
I have a similar DLP TV. If you losing your new bulbs that quickly there is likely a problem with cooling. There is a fan that keeps bulb cool. Make sure the fan is working and there is nothing blocking the air passages. I have not had a problem with my fan but you should be able to find a replacement at Radio Shack or a computer/electronics store like MicroCenter. They come in standard sizes just make sure the voltage is correct typically 120 VAC or 12 VDC.
I have had the computer inside crash such that the sound would work, the bulb would come on, put no picture. Fixed by unplugging the TV for one minute then plug in and turn on.
The bulb repeatedly goes through its startup cycle but never comes on. It tries about ten times then stops. Fixed by removing the bulb housing and firmly tapping it on a counter top ten times. This was at Toshiba instructions over the phone and it actually worked.
Dec 31, 2010 | Toshiba 52HM95 52" HDTV Projection...
My Toshiba 52" goes dark. what can I do to fix it.Tried to ajust the brightness but still stays dark.
U replaced the bulb yet on this tv?U used this tv alot at lest two years or more?The bulb life span it over,bulb have limitted life span.
Apr 20, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
Toshiba DLP 60" TV not showing TV programs, sound ok
Have the tuner signal board replaced. HDMI does not use the regular tuner bands, it is bypassed when using hd inputs.
Aug 25, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
Toshiba 52" HM95 DLP green and red LED Blink>
If Fan behind Lamp is not running lamp will not come on,also CK blaster board.
Aug 09, 2009 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 52HM84 DLP TV with new bulb but the lights keep blinking
They exact way the lights blink are telling you what the failure is. If the tv is firing the lamp and the lamp is bad, you will hear a buzz sound for about 1 second. The tv tries 8 times before it gives up and spits out the lamp error. Check the user manual for led diagnostics. If you put in a new lamp but still have issues, you've likely got a bad ballast (most common on this model) or colorwheel (less common). Both are part of the optical block (light engine) and I don't believe they're available as individual components from toshiba.
Nov 28, 2008 | Toshiba 52HM95 52" HDTV Projection...
Toshiba DLP Model 50HM66
You, more than likely, need a new lamp
Jun 08, 2008 | Toshiba 50HM66 52" Television
Toshiba DLP 50HM66
The bulbs for this TV seem to go about every couple years. The price has dropped down a bit. I have found it for 118.00.
Feb 17, 2008 | Toshiba 50HM66 52" Television
Toshiba 52hm84 DLP buzzing sound after replace bulb?? no pic
You have bad capacitors in the power supply that took out the regulator, or the ballast circuit is defective. Not really a repair for the novice. Good Luck
Nov 06, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
