Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis Electric Dryer, Model #110.6708*, 6709*
My dryer continues to beep and shows code "CF01,02 & 03 then repeats itself. I cannot locate this code in my owners manuel. Please help
  • 3 more comments
  • Anonymous Oct 08, 2008
    I am having the same problem. Constant beeping CF 01, 02, 03. It will heat and dry but constant beeping since the dryer was unplugged and plugged in again.
  • Anonymous Oct 28, 2008
    I have the same problem! Has anyone figured this out?
  • Anonymous Nov 04, 2008
    Help please, it seems to be a common problem. I have the same problem and I can't find any source on the internet to help. Can anyone help?
    Thank you
  • laura a Jan 02, 2009
    I have the same problem where the dryer beeps and the light for the cycle signal volume goes back and forth from loud to soft. A technician checked and said the board for that button(cycle signal volume) needed to be replaced and the button is out. What has anyone done about this? Can I replace this myself? It is really expensive to get fixed. Thanks.
  • Scott Giles Mar 13, 2009
    Have had both problems. Cycle volume light alternates and beeps. Unplugged and plugged it back in, then started with the CF, 1, 2, 3 cycle. Took the control panel off and found an actual technician manual. According to the manual, this means the machine control board needs replaced. Haven't found it online yet, but hoping to so I can avoid the service visit fee.
Hi, my Kenmore Oasis Elite electric dryer has a poor fitting lint screen which allows for a large build up of lint in the bottom of the motor housing. This lint has also become blackened as if exposed to high heat. Some electric wires also show evidence of the plastic coating turning black and over heating. I get the feeling this unit is a fire hazzard. Model # C6704 A few days ago there was a distinct odour of electrical burning. This unit was purchased new in Dec. 08. Anyone else have this experience?
Posted on Apr 27, 2010
  • 107 Answers
These are known for elect. problems. I see about 2 or 3 a week. Without looking up the code, I'll tell you need a user interface board.
Posted on Mar 14, 2009
Once you locate the tech sheet, it will give you steps to enter the machine's diagnostic mode. If the steps taken do not get you into diagnostic, it will lead you to recommendation that the "machine control panel" needs to be replaced. The part # is - w10118243 and is available from several online stores. Appears to be an easy fix for anyone who feels at least moderately mechanically inclined. I'm getting ready to order mine. Hope this helps.
Posted on Mar 13, 2009
    Sergeant:
    Champion:
  • 324 Answers
This is not where the tech sheet is.I will get these codes for you.
Posted on Nov 05, 2008
    Genius:
  • 1,028 Answers
Ck behind bottom panel if it has one or in console if it is mounted on top rear for tech sheet with codes (can tell from image where your console is ..sorry)
Posted on Jul 05, 2008
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
My Kenmore Elite Oasis dryer has a CF code and continuously beeps. Running or not.
The CF error is a communication failure between the main computer and the touch panel...you may have a bad or weak connection or a bad computer..I wold recommend that you contact your local Sears and ask them about recalls, and for service should this happen again.
May 07, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Elite Oasis 6806 Electric dryer with burning smell
you must disassemble the unit and clean the lint out of the heating unit area, it is lint catching fire and could be dangerous to continue using your unit in this condition. a vacuum cleaner should do well to clean the lint and the drum must be removed to do a proper cleaning
Apr 15, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore elite oasis dryer model #110.6708
not much more than a service call for 1 hour work.
Rates vary depending on location.
Expect $60-$80 plus parts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 10, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
about $10.00 for the thermal fuse and 1 Hr Labor (my rate is $30.00 per hour) and a service call,rate depending on where you live
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
Kenmore elite oasis dryer model #110.6708 will not operate. flashes f-40. what does f-40 mean?
F40 = thermal fuse blown.
If the fuse is OK the error points to a communication problem between the machine control board and motor control board (check connectors).
Drum light goes on and off kenmore elite oasis dryer
repl user interface ,, it has a stuck button,, order inter face
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
KENMORE ELITE OASIS HE CANYON CAPACITY DRYER
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. This model is manufactured by Whirlpool, so maybe you can locate your model's failure codes.
http://www.repairclinic.com/0078.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 21, 2008 | Kenmore 67082 Electric Dryer
Cycle Signal Beeping
The user interface button panel has failed and will need to be replaced.
Apr 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
1,044 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
