Question about Dell Dimension 3100 PC Desktop
Wireless lan card
Hi, we had a power cut the other day. when my pc was turned back on the internet didnt work. i have a wireless connection. spoke to my isp who went thru everything and got me connected but wired not wireless. they said my wireless lan card was faulty. i have looked up some info tonight and i think they meant my pci nic card. i want to fix the problem myself and i'm not sure how to go about it. what card do i have and where should i buy it, is it easy to replace? i have a dell dimension 3100 and i'm in the uk. cheers if you can help, james.
    Scholar:
  • 161 Answers
Your nic card could be on board and part of the board which doesn't come out. if so just make sure you have an extra PCI slot on your board and go to a computer place and buy one.
If there is a Walmart over there you can get one there for about $20 or more. Try to make sure that it will install the drivers with your operating system. Other wise if it doesn't come with a cd you may have to download from the net.
this should solve your problem.
you could buy a USB type also. Office supply stores around $40.
Posted on Aug 03, 2008
The wireless internet connection wont work. we previously had a wireless connection and now it wont register. we lost the connection completely and it doesnt show up on the list of internet connections....
Try turning off the router for 30 secs, then power it up again.
Then try connecting a LAN cable from the computer to the router and see if you can connect to the Internet.
If you can connect to the Internet then -
With the LAN cable open a browser and type in the configuration URL and check the Wireless settings, then check and/or the wireless card settings (it should have the router's SSID and encryption settings etc.)
Also install the latest wireless card driver.
Then test the wireless and Internet connection. If this doesn't work -
Next connect the computer with a LAN cable to the cable or DSL modem to see if you can connect to the Internet.
If you cannot get an Internet connection with the LAN cable, contact your ISP and get them to test the connection to your modem.
If the modem and Internet is OK and you still cannot get a wireless connection then the problem could be a faulty wireless router.
Dec 25, 2009 | Dell TrueMobile 2300 Wireless Router...
Router cannot connect to the internet
I assume you are following my instructions.
Did you connect the LAN cable from the DSL or cable modem to the WAN or Internet port on the wireless router?
To test if the modem is working properly, connect the LAN cable from the modem to the LAN network card on a computer and see if you can access the Internet.
If if doesn't connect to the Internet, contact your ISP and they can check the connection to your modem to determine if it is working properly.
Dec 03, 2009 | Linksys WRH54G Wireless Router
I own a HP DV9000 my wireless quit working
Check the Device Manager to see if the Wireless LAN device is working and enabled. If not reinstall the Wireless LAN driver.
If the Wireless LAN is OK and enabled then sometimes when you bootup the Wireless LAN card doesn't get an IP address from the wireless router. This usually has a red X on the wireless connection icon and sometime you get an error message "Limited or no connection".
To get the router to issue the wireless LAN card with a new IP address, righr click on the Wireless icon and click on Repair.
You can also power down the router wait 15secs and power up the router again then reboot the computer.
If it still doesn't work you could have a faulty wireless card, see it your friendly computer shop can test it for you.
Jun 30, 2009 | HP Pavilion dv9000z Notebook
My laptop used to connect to the wireless connection , but one day it stopped working and now i can only connect to internet using a lan cable
go into the device manager and uninstall the wireless adapter. Then click scan for hardware changes and let windows resinstall it. It sounds like a corrupt driver. Before doing so make sure you didnt hit the wireless button that shuts off the connection on the computer. :)
Joe
May 26, 2009 | HP Pavilion Tablet Notebook
Lan card toshiba wireless no working
Check this Tip for an overview
  1. Connect your PC to your router using LAN Cable: be sure you can browse internet
  2. If you cannot browse check router config with your ISP
  3. Connect to your router using IP address you find for gateway in Network status
  4. Configure your router wireless section to match with your PC card
  5. Start removing security, broadcast radio signal, create a simple SSID as network name
  6. Check if router network is seen by your PC card (when you disconnect the LAN cable and activate the wireless card)
  7. If connection is established ( near the router) try different location
  8. Reconnect cable and reconfig adding security protocol (WPA-PSK recommended) use parameters compatible with your lan card
Jan 15, 2009 | Toshiba Satellite 5105-S501 Notebook
Dection of wirless lan pci adapter
see if there is a updated wireless driver for your wan!
Dec 15, 2008 | ASUS A8N-SLI Motherboard
Wireless adapter
check the ettings on the router have not been altered. the chance of 2 wireless cards failing in the same time, on different pcs is very small, more likely the settings that allow connection in the router, the item common to both, have been changed, reinstalling the router has no effect on user settings,
WEP, encryption, MAC controls are all possible suspects, if there has been any change
lock down the router,
many wireless networks are unsecured at the router so that any person driving past can access your router and alter it, default security settings should be changed the day you turn it on
Jun 28, 2008 | Computers & Internet
Belkin mimo G network card
I think in your Pc Wireless lancard is disable,Pls enable the wireless lancard,
1. just check the lan card is enbled
example:my network place --right click---properties---wireless lan card,
2. check the R u getting ip address,
example: start---run---cmd----ipconfig
May 20, 2008 | Belkin Dual-Band Wireless A+G Desktop...
Lan Problem
Goto control panel and work your way through the network Set-up Wizard.
If this is not a separte Icon in control panel then look under "network Connection" Icon.
Feb 26, 2008 | D-Link DFE-530TX+ Ethernet ED100W Network...
Unable to connect via LAN with wireless router NETGEAR WPN824
I recently experienced this on laptop and desktop, using a lynksys wireless. I was able to go into each system to network connections, and tell it to connect. I haven't had a problem since........hope this helps you!
Dec 24, 2007 | Computers & Internet
Dell Dimension 3100 PC Desktop Logo
50 people viewed this question
Alun Cox
