Question about ASUS A7S333 Motherboard
I can't get to the Setup utility
We i hit delete to get to the setup page it dose not open the computer was giving to me it dose not have a windows install and I'm trying to boot from CD drive and i can not get it don. can some 1 help me thank you
    President:
  • 2,351 Answers
At boot up its suggested to press the delete key every two seconds untill the bios main menu loads.
If you have a hard drive connected & video display but can not get into the bios screen, clear the bios jumper on the board keep in clear mode for at least 15 seconds. Remove the battery too.
Check the battery for the correct voltage (3volt). Than move jumper back to normal & reseat the battery.
As shown in this pic.
I can't get to the Setup utility - 88439af.jpg If you press & hold the delete key chances are you'll get a keyboard error beep & have to restart the system.
You can download driver software, bios & manual from Asus web site below.
http://support.asus.com/download/download.aspx?modelname=A7S333&SLanguage=en-us
Once in the bios go to Boot menu. Page 72 in manual. Set system boot cd-rom before the hard disk drive. You should be able to get windows CD to load.
Good Luck!
Mike
Posted on Jul 04, 2008
    Guru:
  • 859 Answers
What you have is truly unusual. This is the sort of thing some viruses are only capable of pulling off.
Within your setup pages, prior, did you have bios protections enabled? Asus, in general, is pretty good at protecting itself from infection, but that doesn't mean it can't happen.
In any case, I'll tell you how to defeat this, get back to your setup pages, at which time you will need to find the currently language being used to protect your Bios from changes. This used to be called onboard anti virus, why it was changed is beyond me. I've been building computers with Asus board for more than 10 years and what happened to you is rare, my friend... rare indeed.
You will want an Anti Virus program that can examine 'memory' on startup, schedule a bootup virus scan and thus scan for viruses before a Windows environment has loaded. The anti virus program I will suggest you download is free for home use is made by Awil. This program can run side by side with many other Anti Virus programs but not all. For this exercise, we need to scan your bootup sectors and this program is exceptional at doing this. Once you are virus free, or confirm you are virus free you can choose then whether to keep it or not. One of its selling points is that it is truly hands off. It updates itself and gives you a voice message each time it is updated.
You can get the software from Avast.com as your download begins go back to the Avast pages and register your copy. They will email you a key. Copy and paste this key into a Notepad document and save it to the same permanent location as your Avast installer location, such as c:\software\avast .
During install you may receive a message or two about some elements of Avast not being compatible with what you may be running now. Select OK for these, which are usually email scanners.
The first thing Avast wants to do after you install it is reboot of course. Choose 'no'. You will notice a new pair of icons in your system tray. One is your avast Virus Recovery Data Base. This is the reference set for comparing file sizes during a scan and thus identify some clever infections. Later, right click it and tell it to update VRDB when idle.
Right click the blue globe with the A on it and choose "Start Avast Anti Virus", you will be prompted for a license key or continue in demo mode. Copy the license key emailed to you and paste it in now. You will get a confirmation message. Allow the program to startup, it may take some minutes as it examines everything sitting in RAM and your Virtual Memory Page File.
Once it up and running click on the arrow on the interface near the top left, this drops down a menu of options, one of these is "Schedule Boot-Time Scan".
Once this is scheduled shut off (important) and once it has been off for a minute start your computer up and you can casually follow the bootup scan process. You will be prompted on what to do with an infection when found. You can choose Always for some of these but put everything in your virus Chest.
Now, this is how to get back to your bios setup screens. Remove the left side cover. Unplug the power cord to your PC and if there is a LED lit up wait for it to go out. Now, find the button battry for your system board, a shiny flat object smaller than a quarter larger than a nickel. You want to pop this out, leave it out for a minute and then reinsert the battery. Normally there is a press to eject point that isn't all that noticeable for its purpose. You can crimp on this with some needle nose pliers or you may also choose to slip the end of a sharp knife under the battery and pop it out that way. Either way, be prepared for the possibility for the battery to really pop free and go flying into your comptuer's case area. Once you have it in hand just set it aside while battery held settings are reset. Then, reinsert the battery by putting one edge in and then pushing down on the battery to seat it in place.
Reattach the left side of the case, stand your PC up and then insert the power cord. When your machine starts up press and tap the Del key until you get your bios pages. At the bottom is a legend that will tell you what F key to push to set system defaults, so press F9 if that is the one, check that bios protection is enabled and your boot up order of devices is floppy, CD Rom, Hard Disk, save your changes and restart. The anti virus program will run if you haven't run it yet.
If you have any questions, ask using the comment box and I or another will get back to you as soon as we can.
Regards,
Worldvet
How do I exit Aptio Setup Utility ?
Try running the System Configuration Utility.
- press windows logo + R and type "msconfig"
-go to the startup tab and uncheck the application
-click apply, then ok
-restart your computer
Dec 16, 2013 | Acer Aspire 5100 Notebook
I got a Motorola wired modem and it dosn't let me play xbox live why?
you may have to open a port that you xbox can use to connect to xbox live
    • 1 Connect only your Xbox and computer to the Internet. Disconnect all other devices. This is done to easily determine the Xbox's IP address, which is used in the Port Forwarding process.
    • 2 Open the Windows Command Prompt from the Start Menu. Click "Start > Run...," then type in "cmd" and hit "OK."
    • 3 Enter "ipconfig" n the command prompt. A list of IP addresses pop ups. Write down the IP address of your computer.
    • 4 Open your router setup utility through a web browser. Use the given directions from your router manufacturer to do so. Generally, the configuration page is opened by inputting the router IP address into the URL in the following format: http://123.456.7.8/ (where the IP Address number is unique to the router manufacturer).
    • 5 Open the "DCHP Client List" section of the router setup utility. This lists the devices currently connected to the Internet through the router, which is your computer and Xbox. Write down your Xbox's IP address (in this case, the one that is not your computer's IP address).
    • 6 Navigate to the "Virtual Servers" or "Port Forwarding" menu in your router setup utility. Most manufacturers have a side menu on their router setup utility, which is generally a section under your "Firewall" settings.
    • 7 Input the following port numbers and your Xbox's IP address into your router's port forwarding configuration:
      TCP 80
      UDP 88
      UDP 3074
      TCP 3074
      UDP 53
      TCP 53
      Placing these numbers in the port forwarding menu opens up the required ports that your Xbox needs to connect to the Xbox LIVE network. Save this configuration.
    • 8 Start up Xbox LIVE to check your connection. If you have no problem connecting, then you have successfully forwarded the required ports.
Jun 04, 2011 | Video Game Consoles & Games
Page counter=85621. What I do?
1. In the Finder window, click on Go on the Title Bar and select Utilities.
2. Open the Printer Setup Utility.
3. Click on Printer Setup Utility in the title bar.
4. Select Reset Printing System.
Jan 27, 2011 | Brother MFC-8460N All-In-One Printer
I recievced a dell pc desktop dont know what model it is but its set up for a corp network. cant get pass password would like to wipe drive and install xp have disks. how do i go about this. i think its...
The model name, and model number is usually on the back of the computer tower, next to the Windows Product key, or up on the side of the computer tower case.
Sometimes you have to open a door on the Front Panel, and it is located inside. (Not on the door. On the computer. The Front Panel is the plastic front of your computer)
You have XP Installation disk/s?
You are aware that Microsoft's User's License states,
"Only one genuine copy of Windows per one computer"
(Microsoft makes a Master disk of an Operating System. The copies made from it are bought by the consumer. These are GENUINE copies)
If the Windows XP installation disk you have is a fresh disk, I suggest you go to BIOS Setup, and in Boot Options change the first boot option to CDROM.
Windows doesn't 'like' having the same operating system installed over it.
Making sure that your optical drive, (CD or DVD. Player or burner, doesn't matter), is the first boot device, will override the above.
How to get into BIOS Setup for a Dell? (It's actually BIOS Setup utility)
Dell uses different keys on the keyboard for their different models.
A) The Dimension models usually use either the DELete key, or the F2 key.
B) The Inspiron models use the F2 key
C) The Latitude models (Desktop computer) use the F2 key
D) The Optiplex models may use either the F2 key, or the DELete key.
E) The Precision models use the F2 key.
Computer off, right after you press the Power On button, start tapping, (In 2 second intervals), on the appropriate key for your Dell model.
Note that I stated two different keys for some of the above models.
The procedure to find out which is the correct one, is to simply try one that is listed, and if it doesn't work, try the other one.
HOWEVER, you try using the first key.
Doesn't work?
Then you need to start all over.
You need to reboot the computer. (Restart)
Press the CTRL, ALT, and DELete keys at the SAME TIME.
This will restart, (Reboot), the computer, where you can try the other key.
Once you are in the BIOS Setup utility, you need to look for Boot Options.
There are many types of BIOS setup utilities, and Dell didn't/doesn't use just one.
You may see Boot Options in the top header of the BIOS Setup utility.
You may not.
If it isn't listed at the top, scroll down to the listing similar to,
Advanced BIOS Options, and open it.
[In the BIOS Setup utility you can no longer use your mouse.
You will use the Up/Down Arrow keys to highlight the area you wish to open, and then press the Enter key]
For questions please post in a Comment.
Sep 18, 2010 | Computers & Internet
My printer keeps on trying to install and configure hp2400 and hp2400tour. what is it trying to do that it cannot?
This pop-up is related to corrupted windows installer. We need to delete this entry from Windows installer. Please follow the below steps.
  1. Download the Windows Installer Clean-Up utility (see Resources for link). Click the link on the download page on the Microsoft website and save the file to your Windows desktop.
  2. Double-click the utility setup icon on the desktop.The icon is labeled msicuu2.exe. Follow the prompts and the installation wizard instructions to install the utility. Click the "Finish" button in the installation wizard when it is finished.
  3. Open the utility. Click Start > All Programs >Windows Installer Clean-Up. This opens the Windows Installer Clean-Up window.
  4. Click and highlight "hp2400 and hp2400tour" program from the list and then select "Remove".This will open a warning prompt window.
  5. Click the OK button in the warning window. The utility will remove the"hp2400 and hp2400tour" that you selected.
  6. After its done, restart the computer and the problem is no more.
Regards
Rizwan
Mar 02, 2010 | HP PSC 2410 All-In-One InkJet Printer
Tray app is persistant at star up and unwanted. no recollection of what warranted this to apear.
This popup is related to corrupted windows installer for tray app. We need to delete this entry from Windows installer. Please follow the below steps.
  4. Click and highlight "Tray app" program from the list and then select "Remove".This will open a warning prompt window.
  5. Click the OK button in the warning window. The utility will remove the"Tray app" that you selected.
Regards
Rizwan
Feb 13, 2010 | HP Pavilion dv4000 Notebook
RAM installation
Hi hunter555,
First off, you've done a lot of work for nothing. What you need to do is put back the new memory. When the Dell Bios boots, it confirming that it has detected the new memory. What you need to do is hit the F1 key to reboot and continue on to the XP installation. When you open the case, it will say the same thing. Don't worry about it, it's only confirming that the case was opened. Typically, I shut off the case intrusion detection, only because I'm always adding things to the machines and it's just a extra step I have to take to boot. However, it's good to know that your bios is confirming that you've opened the case, and that you've put in new memory. You want to make sure that the setup recongizes the entire memory in the banks. So, go to the system information page and make sure that it's reading the original and the additional memory 256k you added. Otherwise your done.
Good Luck
Mark
Jan 14, 2009 | Dell Optiplex GX150 Tower Computer - 1GHz...
Printer Won't Print
Step one: Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu. Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: Check the product cable, Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds. Reconnect the USB cable to the product and computer.
(NOTE: The product must be connected directly to the computer using a USB cable or a powered USB hub. If the product is connected to the computer through a non-powered USB hub, or if the type of hub is unknown, connect the product directly to the computer) after the product is connected to the computer, the product should start printing the jobs in the print queue. If the issue continues, proceed to the next step.
Step three: Determine whether the product is paused or offline, Click Start and click Printers and Faxes. The Printers and Faxes window appears. In the Printers and Faxes window, right-click the product icon and click Open. The Printers folder opens. On the menu bar, click Printer. Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it. If the menu includes Use Printer Online, click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: Stop the print queue, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder; Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs. (NOTE: If the queue was accidentally stopped, the print job will resume automatically. If the issue continues, proceed to the next step)
Step five: Delete the print jobs, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder, Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue, Click Start Jobs, Double-click the appropriate product in the product list to open the print queue.
When the print queue is empty, click Start Jobs. Try the print job again. If the issue continues, proceed to the next step.
Step six: Remove and re-add the product to the printer list, Double-click Macintosh HD, Double-click the Application/Utilities folder, Open the Print Setup Utility folder, Select the appropriate product.
Click the red X to delete the product from the computer, Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer, after the computer is restarted, double-click Macintosh HD.
Double-click the Application/Utilities folder, Open the Print Setup Utility folder, and Reconnect the USB or Ethernet cable to the product. If the product is not automatically added, click Add. Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 18, 2008 | HP DeskJet 5150 InkJet Printer
HP Deskjet F380 All-in-one Won't print
Solution:-
Step one: - Restart the computer
Click OK.
Step two: - Check the product cable
After the product is connected to the computer, the product should start printing the jobs in the print queue.
Step three: - Determine whether the product is paused or offline
In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens.
If the menu includes Use Printer Online , click that option.
Step four: - Stop the print queue
Double-click Macintosh HD.
Open the Print Setup Utility folder.
Click Start Jobs.
Step five: - Delete the print jobs
Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue.
Click Start Jobs.
Step six: - Remove and re-add the product to the printer list
Click the red X to delete the product from the computer.
Close all open windows and restart the computer.
After the computer is restarted, double-click Macintosh HD .
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
Can not clear the print que
Follow these steps to resolve the issue. Step one: Delete the print queue Open Print Setup Utility located in the Application/Utilities folder. Double-click your printer in the printer list to open the print queue. Click the Stop Jobs icon. Click to select the document, and then click the Delete icon. Repeat the steps for all the jobs in the print queue. When the print queue is empty, click the Start Jobs icon. A message appears: No Jobs Printing . This indicates that the queue is clear. When you have cleared the queue, retry your print job. If the procedure has not resolved the issue, repeat steps 3 and 4. If the issue still persists, continue to the next step. Step two: Remove the printer from the list Open Print Setup Utility , located in the Application/Utilities folder. Click to select the Photosmart icon. Click the red X to delete the printer from your system. Close all open windows, and restart your computer. Step three: Add the printer to the list Open Print Setup Utility located in the Application/Utilities folder. Click Add . Select the printer that you want to add, and click the Add button. After a few seconds, your printer appears in the printer list, and your printer is ready to print.
Sep 13, 2007 | HP PSC 1410v All-in-One Printer
ASUS A7S333 Motherboard Logo
245 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
