Question about Miele CVA4070 Coffee Maker
Miele cva4070 coffee system
My system is stuck on cleaning. The display says cleaning and will not change. Any ideas?
  • EP Hoagland
    EP Hoagland Aug 07, 2008
    Recycled everything per unit readout...Removed power for 1/2 hour, etc. No help as the unit returns to CLEANING readout when on/off is pushed. I plan to leave unit unplugged over night!
The above solution will not work when the machine is stuck on the cleaning cycle. You can plug and unplug it all you like but it will still come back and be stuck on "Cleaning" when you turn it on. I called Miele service and was guided through the steps to access program mode in order to cancel the mode. This is how you do it:
First turn it off using the switch inside the machine (top left with door open)
Note, the four following steps have to be completed within 10 seconds:1 Press the Clear button and hold2 Then press the On/Off button3 Release both buttons at the same time4 Press the clear button 5 times in a row
This gets you into Programming Mode (may take a second or two to pop up if you complete the above in less than 10 seconds
Keep pressing the "More" button (bottom right) until you get to the last page where it will give you the option of reseting the three cleaning modes. Just push the right one ("Cleaning" for e.g.)
That will do it but if you have an underlying fault that interferes with Cleaning then the same problem will happen again when the unit needs cleaning. You should get a service call to address this.
Posted on Dec 15, 2011
  • tbjuliandds
    tbjuliandds Jan 09, 2013
    Just make sure you hold the clear button down until the program starts...wasn't clear in the instructions.
    Habit-Forming:
  • 5 Answers
I called Miele hot line & we fixed the problem... 800-999-1360
When you start the cleaning cycle, Don't stop same by pulling the plug! Turn the unit off from inside wait 5+ seconds & turn back on and the cleaning cycle should restart... If you do not use a cleaning TAB..Open & shut the LOOSE coffee Door under the drawer (Top Left) and the cycle will continue.
Posted on Aug 07, 2008
Stuck while cleaning
If your Miele appliance requires service, please contact our Technical Services Department at:
Phone:
(800) 999-1360 (appliances)
Jan 16, 2008 | Miele CVA4070 Coffee Maker
The grinder is not working
Likely causes are grinder has burnt out or temperature cut-out for Grinder has blown. Either can be replaced as a spare from Miele.
May 13, 2014 | Miele CVA4070 Coffee Maker
IT STUCK IN CLEANING MODE. AND WONT RESET. WHAT DO I NEED TO DO.
This is normal behavior for a Miele machine, it is a safety feature. You have to clean it.
Use the cleaning tabs you have that came with your machine, if you don't have anymore, get them here http://www.amazon.com/Miele-05626080-Cleaning-Tablets-Packet/dp/B001BNV3GK
Clean the machine normally by opening the machine up, removing the storage tray, and dropping the tablet down the ground coffee shoot and letting the machine lead you through the cleaning.
Hope this helps.
May 31, 2011 | Miele CVA4070 Coffee Maker
The ew 3000 iem (brand new) is stuck on mute. Tried everything to no avail. Ideas????? Please Help!!!???!!!!
To get your transmitter out of mute press the standby button and hold it briefly until "RF Mute Off" appears. Your display should change from red to orange and the transition icon will also be displayed again. This indicates your transmitter is transmitting.
Regards, Tony
Mar 24, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
I have two types of descalling tablets in my package, 2 large and 10 small, where do I add them to my Miele coffee system CVA4070, and how many
The large ones are your descaling tablets. they go in your water container when the machine tells you to put them in there. Your small tablets are brew unit cleaning tablets. they go in to the flap door under the ground coffee storage container in the top left of the machine. One cleaning tablet at a time when it tells to to start cleaning. Two descaling tablets at a time during descaling.
Nov 20, 2010 | Miele CVA4070 Coffee Maker
F17 fault
Try posting your question in the oven section as opposed to the coffee maker section. You might get more responses
Feb 06, 2010 | Miele CVA4070 Coffee Maker
My Nuvi 200W stuck in boot process
This most likely means that a part of the software on your gps system is corrupted and unreadable. You will need to update it/re-install the software on it. To do that, you can download this software which will automatically search for the latest updates: http://www.tomtom.com/services/service.php?id=16&tab=87
Oct 31, 2009 | Garmin nuvi 200W GPS Receiver
I'm looking for a manual for my KXT7735 phone I
The second part is easy, try pressing either * or TRANSFER until the display reads what you want. It has 3 displays. The phone instructions are particular to the phone system the phone is connected to. Try to find the Panasonic system number (the box where all the wires go) and comment back.
Carl
Jul 24, 2009 | Panasonic KX-T7735 Corded Phone
What is F81 on a CVA4070 Mieled coffemaker??? the owners manual addresses F10-17 and F73, but no F81 any ideas???
F81 means that the steam heater does not work properly....(possibly a blown fuse or a broken heater..could also be the main power board TRIAC) good luck!
May 31, 2009 | Miele CVA4070 Coffee Maker
Miele CVA4070 Coffee Maker Logo
892 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
