Question about SanDisk Sansa e250 MP3 Player
Sansa e250 Freezes at "SanDisk" screen.
  • denjoe Jul 05, 2008
    Did not work. The "solution" didn't accomplish anything that I couldn't already do...power the mp3 on & off. The point was that the player would freeze at the "SanDisk" screen.
  • Anonymous Jul 05, 2008
    Mine is doing the exact same thing, and when I plug it in the computer doesn't even recognize that it is plugged in.
  • 8,596 Answers
First, the player has to be reset - see your manual for details
Second, if it freezes after reset, then your firmware has to be upgraded - the upgrade was at the Sandisk website, but I've heard rumors that they have taken it down - which will require you to make a phone call to Sandisk
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jul 05, 2008
Sansa freezes
try inserting a microSD card when player is turned off then put it on...work most of the times...
Sep 10, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250 Freezing
Reset the player, then get the Sansa Recovery Tool from Sandisk's website
Sep 01, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250R - Will pwr up but only freezes on screen that says..."Sansa Rhapsody"
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Jul 28, 2008 | SanDisk Sansa e250 MP3 Player
Sansa sandisk
LOOK AT THESE WEBSITE FORUMS...THEY ARE FOR THE SANDISK SANSA PLAYERS
http://forums.sandisk.com/sansa/search?submitted=true&q=E250
Feb 21, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 freezes!
This should take care of it;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 05, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
