Question about GE Refrigerators
Our refregiator/freezer came with new house from Ryland, in Telfair sub-division in April 2007. Its not geting cold, and its look like its frozing in the back, or may thermostate is not working, please help
  • 481 Answers
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 04, 2008
I need to wire in a new freezer light for sub-zero 680 wires are just hanging
Refer to the wiring diagram located in service compartment.
Sep 12, 2014 | Sub-Zero 680 / F
Ondesit fridge fridge freezer biaa134fh fridge not cold
It seems lots of people have the same problem with this appliance....including myself......I took the drawers out of the freezer.....removed the iced up plastic cover which houses the fan assembly.....some water had settled in the bottom and froze, therefore stopping it from turning.....just spin it and it with start up again.....hope it helps ;)
Mar 13, 2014 | Indesit BIAA134F White 9.5 Cu Ft Fridge...
Freezer and refrigerator to cold...everything is freezing on fridge side
check for a faulty thermostat that tells the board when to run or not . If it is still under warranty have a service inspection done .
Jun 13, 2013 | Whirlpool Refrigerators
Lrtp1231w refrigerator is not geting cold but freezer works good what part should i change
I don't know how your unit works but most have a thermostat that opens a vent between the freezer and the fridge allowing cold air into the fridge compartment. you probably need a new thermostat
which looks like a wire with a tube on the end, check for a service manual on the manufacturers website to find part numbers and diagrams
Oct 20, 2011 | LG LRTP1231W Top Freezer Refrigerator
Sub-Zero 650 freezer (bottom) too cold. Tried to
probably bad control board. check this. push the on/of key. the whole ref and freezer nedd to stop. if you hear the compressor in the upper part of the unit or the fan. your contol board need replace.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
My refrigerator or freezer is not geting that cold.
unplug unit and let sit overnight evap coil is froze up
Oct 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
It is very cold on the top freezer section but not cold at all in the lower refrigerator section
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 23, 2009 | Avanti FF511W Top Freezer Refrigerator
System works but air is only cool not cold,
It is absolutely possible, it will need to be evacuated, and pressurized or traced to locate the leaks. Then, you will have to pull a vacuum on the line and pull a new charge. Hope that helps.
Apr 06, 2009 | Heating & Cooling
Refrigerators Logo
166 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
