Question about Kenmore 22422 Top Load Washer
Lid switch instructions on how to replace lid switch
    Genius:
  • 1,224 Answers
Pop the top of washer open the whole top this should go back with screw driver
under lid the switch is right there replace accordingly
Posted on Jul 07, 2008
Replace lid switch ffle1011mw2
Good Afternoon Friend,
I understand you want to know how to replace the lid switch on your Frigidaire laundry center, model# FFLE1011MW2. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been rained on your appliance, and should be able to replace the lid switch with ease. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire Washing Machines
It seems like the lid lock has maufunctioned. It will not lock so therefor it will not fill so our clothes will not get washed. It makes the clicking noise as it attempts to lock but the lid wont lock an...
Hi
Thanks for using FixYa. You can try to jump start the lid switch, if after doing this it works then it means the lid switch is bad and needs to be replaced. Please check this video as it provides you step by step instructions that will help you in lid lock switch replacement:
Please revert back for more help.
Rylee
Dec 23, 2011 | Whirlpool WTW4800XQ Washer
My Kenmore Washer model: 110.49962603 stops during the rinse cylce. All the buttons were turned off after one cycle except the time button. It displays F28 on Time Estimated Remaining button. How can I fix...
By what you have stated, it sounds like a lid switch failure. The lid switch has to be closed for the drain and spin cycle on your washer. If the lid switch is faulty, it will act as if the lid is not closed. On this model, make sure the lid hinge screws are tight. If the screws are loose, the hinge might not activate the lid switch.
A quick check you can do is to jump the lid switch and see if it will drain. If the washer operates, the lid switch needs to be replaced.
To jump the lid switch you need to unplug the washer and open the console. I have provided you with the instructions for opening the console below. Once you have the console open, locate the connector for the lid switch. Place an insulated jumper between the gray and tan wires. Not the green it is a ground and will cause a short. After inserting the jumper make sure it will not touch anything metal, plug the washer in. Start the washer in a drain cycle. If the washer drains and spins, you need to replace the lid switch. Do not leave the jumper in while you are waiting for the part. The jumper is only of the test.
To you replace the lid switch you have to remove the cabinet of the washer. The instructions for that are also in the image below. Once the cabinet is removed you can take the screws out securing the lid switch and remove the harness from the clips along the underside of the cabinet. Then reinstall the lid switch in the reverse order. Before you reassemble the cabinet, please read the instructions for installing the cabinet provided in the image.
I hope this is helpful. Please reply below if you need further assistance.
Jan 23, 2018 | Kenmore HE2 Plus Front Load Washer
Will not drain
Hi the likely problem here is the lid switch. This is normally located behind the left hinge in the control panel or half way down under the lid on the right. You will have to replace the lid switch. For instructions on replacing the lid switch click HERE These instructions come courtesy of JSROCKS. If you have any other questions please feel free to ask. Mike
Feb 14, 2010 | Kenmore Dishwashers
Replace lid switch assembly kaws850
The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
On the particular model you have listed, the lid switch should be located under the console near the right rear lid hinge.
You will need to use the steps in the link provided to remove the exterior case to access the switch to see how the actuator and lid hinge interface. You washer is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
This is a very simple repair, but if you have any questions along the way, please let me know. I hope this is helpful to you.
NOTE: If you have not pruchased a new lid switch yet, the part number is 8054980. It can be purchased at appliancepartspros.com for about $18.
Oct 30, 2009 | KitchenAid KAWS850L Top Load Washer
Kenmore Mod# 110.25842400 lid switch
The following link gives you step-by-step instructions on how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have any questions about this repair, please let me know. I hope this helps you.
Jul 15, 2009 | Kenmore 24032\24036 Top Load Washer
My washer stops in the middle of the cycle, it washes but stops before draining the water to go into the spin rinse cycle. Kenmore nodle 110 serial # ce1402638 Please asvise.
This problem is commonly attributed to a lid switch malfunction. I will need a more accurate model number to confirm (located under the washer lid along the tub rim). "110" is only the beginning prefix of the model number, which identifies the manufacturer. I will need the remaining numbers to determine how the washer is configured.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
A replacement lid switch can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. All three sites offer competitive pricing, so shop all three for the best price. For instructions on how to replace a lid switch, you can refer to my profile and look under my "Tips and Tricks" for links for Replacing a Lid Switch. If you still need assistance, please contact me and let me know. PS If the lid switch IS defective and you need instructions on how to by-pass it in order to drain the wash tub, let me know. In addition, if my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further.
Feb 26, 2009 | Kenmore 20172 Top Load Washer
My washing machine will not rinse
This is a common symptom of a lid switch malfunction. If the model number you have this listed under is correct, the lid switch is mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If your washer is not configured in this manner, please post back with your COMPLETE model number (located along the tub rim under the lid) so I can confirm how your washer IS configured.
Feb 17, 2009 | Kenmore 24032\24036 Top Load Washer
How to fix the lid sensor switch?
If you still require assistance, follow these instructions. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
I hope this helps you. If you require assistance in locating parts, or need further advice, please let me know.
Jul 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
194 people viewed this question
Sal De
fordexpert
Robert Rankin
