Question about Compaq Inkjet Ij1200 Printer
Paper is rolling through
Having trouble with printer - it appears that the paper isn't moving through the printer correctly and it comes out with the ink all bunched up at the top; this was preceded by the margins coming out all haywire even though I had them correct in the computer.
  • tricia_63108 Jul 05, 2008
    appreciate the effort but the printer is still not working correctly. The margins are correct on the computer but come out all wrong when the paper comes out of the printer. considering that the printer is more than 7 years old - it's probably time to get a new one.
  • 193 Answers
Clean the paper rollers with water...let dry, then send a sample page through..no print necessary. just print a blank page.
Posted on Jul 04, 2008
I get a warning message for a paper jam, but there is no jam and the paper will not feed through the printer.
Still you have to check all places paper has to move through. If only one sensor indicates the rolls are not moving correct you gat this message. Also make sure you closed all doors and flaps correct.
Jun 29, 2014 | Epson Pro Wp-4530 All-in-1 Inkjet Wireless...
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
When i turn on my printer it blinks a red light.
OK, more information is needed. What kind of printer? Is it out of ink? This may sound stupid, but is it plugged in to the computer? Let me know :)
Jun 19, 2011 | Computers & Internet
The roller does not roll. We can't print labels and we are open for business now.
hello tconnersvrve!
open cover - remove the paper roll and do a test print without paper. look if roller mechanic is working, if so, then re-insert paper roll correctly and do a testprint. if no move is detected, then motor or motor drive has problem - service issue.
regards
Feb 26, 2011 | Dymo LabelWriter 400 Turbo Thermal Printer
Out of paper error in Zebra 110XiIII plus
There is a small thumb screw under the paper guide that has an adjustable stop to hold the paper. If you load it correctly, you should have one on each side to guide the paper into the printer. Also, the machine has either a roller or a bar to hang the labels on, correct? The bar has an adjustable stop to keep the roll from moving around while you print. You may want to setup the media sensor about 1 cm from the left of the printer to make it less subject to this type of error. They come from the factory very close to the edge of the paper to allow for some card printers to work well out of the box. Most people use labels and this is not necessary. I hope I have given you some helpful information.
May 06, 2009 | Zebra 110Xi III Plus Thermal Printer
Paper feeds as if normal but no printing appears on paper
If it is now printing blank and was working before the paper roll change then you need to flip the roll over and print on the other side of the paper. This is assuming you have the correct thermal paper roll.
Dec 09, 2008 | Office Equipment & Supplies
My cash register is not printing.
Hi.
If it is a thermal printer, make sure you have the paper coming from the bottom of the roll, not the top. If you have the paper the wrong way around, it will come out blank.
If this is not the problem, please let me know the model number and any other information you can give.
Mark
Dec 08, 2008 | Casio Parts Cash Register PC Desktop
2410 Malunction
This problem always hits after a power interruption. On another site I read the solution is to open the back and roll or move the paper wheels back and forth a few times. This worked for me.
Apr 21, 2008 | HP Photosmart 2410 All-In-One InkJet...
Carraige Jam
maker sure the cleanout station is not stuck..it moves also...dont break it just see if it isn stuck...move the carriage back and forth. put paper in it and turn it back on.....if that does not work..take the paper out ..open the back and roll th big wheels a bit and try again.
Oct 13, 2007 | HP WanProbe V-Series Network Monitoring...
Frequent Paper Jams
The only suggestion I could make may be obvious but my experience has taught me that you need to make sure the paper is installed correctly, especially with double ply paper. We have learned that the yellow receipt copy ply must be attached properly to the green roller so that the double ply paper from the roll feeds correctly through the print roller. Also make sure the double ply roll paper is not loose coming off the roll that feeds to the print roller.
Nov 20, 2006 | Ithaca (93+PRJ11) Matrix Printer
Compaq Inkjet Ij1200 Printer Logo
73 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Soulvisitor
Soulvisitor
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
