Question about Bose MediaMate Computer Speakers
Loud whining noise
I tried to use my speakers with my laptop and when i plugged in the accessory speaker into the powered speaker, there was a loud whining noise coming out of the accessory speaker. The powered speaker works ok by itself. Only when the accessory speaker is plugged in that the whining noise occurs. Please advise. Thanks
  • racerice Sep 23, 2008
    I have the same problem. I used to pound on the top of the main speaker and the noise would go away sometimes for minutes, sometimes for weeks and even months. Where to send for repair.
    Scholar:
  • 135 Answers
Yes,,this is due to electromagnetic interference...
try to keep the accessory speaker as far as possible fro the powerspeaker..this would serve better
Posted on Jul 06, 2008
Why am I getting a alternate he whining when RCA plug is plugged in speaker RCA jack is plugged in
Good wiring practices and noise reduction accessories can help cut back on alternator whine and ignition popping sounds thru auto audio systems.
Typically, amplifiers and other high current devices work best when power leads are direct connected to the vehicle battery. The remote on signal should come from the head unit or other location of choice. Use only shielded signal cables between head unit and amp. Try to keep as much space as possible between the audio wires and power wires - including speaker wiring.
By connecting to the battery directly, it acts like a giant capacitor. It is also where the cleanest, level DC power in the vehicle is - the further away from it you go, the dirtier is gets. Even only a slight AC ripple on the DC level voltage can wreak havoc on the sound coming from the speakers. You can add a "choke input filter" to further reduce the AC ripple. There's a ton of data on these filters, so I'll leave you to determine how far you want to dig - here is the Google result page:
choke input filter Google Search
May 23, 2014 | Car Audio & Video
Humming noise
Possibly a bad cable or bad ground or bad outlet?. Easy solution, try a different outlet and see if the hum still exists. Also, make sure your speaker cables are NOT run parallel along with, or close to any power cables, Speaker wires can and will pick up AC "Humm" noise.
Apr 23, 2014 | Edifier Audio Players & Recorders
Whining noise Computer Speakers comes and goes
This is more likely a problem with your sound card than the speakers themselves. Next time it happens, try plugging in some headphones or other speakers into the same port on the computer. Most computer hardware is not designed for good ground isolation and digital artifacts can come through.
The other likely answer is a problem with the cables. Try wiggling the cables, especially near either end, and see if you can find a spot that makes the sound come and go. If there's a break in ground at a connector, or a short to ground in the cable, that can also cause unpleasant distortion in the speakers.
May 30, 2012 | Logitech Audio Players & Recorders
Just replaced a dead battery with a brand new one. Tried starting it and it makes a high pitch whining sound and wont start. Any suggestions of what the problem is? Does it need to sit to charge the...
The basics, your battery is used to provide power to the starter. Once the engine is running the alternator then provides current to recharge the battery and run all of your electrical components. so I would suspect the starter is not working to start the engine.
Feb 16, 2011 | Chevrolet Classic Cars & Trucks
I have a 4 month old Dell Studio 1535 laptop, with audio problems
Firstly check that the microphone level is down or turned off as this sounds like some sort of feedback that's being produced.
Check the microphone and try to play music again.
Please post back
Good luck.
Oct 02, 2009 | Dell Studio 1535 Notebook
Loud "MOTORBIKE" quality noise coming from laptop speakers
grounded, or some parts of your keyboard key pressing.. try to remove the keyboard.. then observe it if the sound still there open the board then check it..
Sep 12, 2009 | HP Pavilion dv6000z PC Notebook
Loud noise from speakers when laptop closed/standby
Hi there.
Your microphone is on, and when you close the lid it is closer to the speaker. It needs
a loud noise (like closing the lid faster) and it enters into a feedback loop.
We need to find a way to make the microphone not play back.
Try left clicking on the speaker icon in the bottom right of the screen, and click playback
options. Here mute the microphone, and see if it solves your problem.
Good luck
Jun 04, 2009 | HP Pavilion dv6000z PC Notebook
Static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Jan 01, 2009 | Dell A215 Computer Speakers
Constant loud muffled noise coming from the sub and speakers.
Try playing with the connection, sounds to me maybe the jack is going bad or has a shorted connection. Plug it in and out slowly to see if that's the issue.
Sep 25, 2008 | Logitech Z-5300 Computer Speakers
Powered sub
thats sounds like feedback. try giving your sattelites spacings. if they are near to each other, try to put them far from each other.
try also to turn of your microphone. that might work.
Jan 14, 2008 | Altec Lansing VS3251 Speaker
Bose MediaMate Computer Speakers Logo
595 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
