Question about Maytag Refrigerators
Maytag side by side fridge freezer. no ice and no cooling - compressor sounds normal. caBINET LIGHTS WORK
  • PEAKMAN42 Jul 09, 2008
    Thankyou for your advice. After examining the unit more thoroughly I can report further symptoms which may help your experts.
    1) The ICE cube maker dispenser is not filling. (water from tap ok)
    2) My report that compressor was wkg probably wrong. I was misled by fan noise - the compressor is not vibrating or making any noise.
    Be grateful for advice
  • PEAKMAN42 Jul 12, 2008
    Thankyou again, I need to clarify one point to complete the picture. Your message reports the ice-maker and freezer as independent systems but your observation that the icemaker may not work if the freezer temperature is too high fits my own situation (assuming a symptom of the icemaker turning off is shutoff of the water supply)
    After reading the responses, I think the symptoms I report indicate something wrong with the freezer/defrost control/thermostat. However I have no experience/knowledge in this area - please put me out of my misery.
    thanks in anticipation
  • 105 Answers
This problem may occur when the compressor is not working.it maybe also due to when the fluid circulation is improper or it may have some blocks somewhere in it .this may affect the cooling purpose.try to check whether there is any leakage of the gas like material filled in the tubes in the back of the fridge.if the gas circulation is improper refill the gas or the fluid whichever used in the tubes and then switch on it.try to replace the compressor if necessary.thank you
Posted on Jul 12, 2008
  • Maytag Master
  • 19,396 Answers
  • 813 Answers
    Genius:
  • 1,011 Answers
Sir,
Step: 1) Make sure you didn't knock anything loose while changing the filter.
Step: 2) You most likely have a defrost problem. Check the back wall of the freezer for frost. If there is frost on the back wall that is why the fresh food section is not getting cold. All of the cooling is done behind the back wall of the freezer and the evaporator fan that you hear running must circulate the air throughout the entire refrigerator. If the frost builds up on the evaporator coils there is little or no air flow.
The most likely reason for the frost is the adaptive defrost control not working properly. This is not a simple thing to change and should be left to a pro to handle as things can be damaged in the removal and installation of this control.
Step: 3) Try to defrost your fridge for 36 hours and then restart it. The cause of that noise comes from the blade of evaporator fan motor. Ice form in the fan shroud, maybe the moullion heater is busted or it also happens if you accidentally left the door open for a long time.
The compressor motor runs to keep the collant circulating but it should not be loud and it should not run continuously.
Make sure the door seal is not leaking by having a close look around the door seal for any deformity or any sign of mold growing at one spot. If you find a suspect spot get the door seal replaced as the compressor motor will wear out otherwise.
If the door seals look OK then, if you are able, check or have checked, the thermostat to ensure that the sensor which shuts the motor down when it reaches the desired temperature is working.
A process of elimination really but the motor definitely should not be running all the time.
Thanks
Good Luck
"Don't forget to rate the solution"
Posted on Jul 09, 2008
    Genius:
  • 1,665 Answers
Http://www.repairclinic.com/0100_1.asp
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
    Master:
  • 788 Answers
See here: http://www.applianceaid.com/frig_notcold.html
It would seem that it is most likely that there is ice around the coils behind the panel in the freezer section which is stopping the fan from blowing the air around.
Posted on Jul 04, 2008
  • Dean Joly
    Dean Joly Jul 09, 2008
    Seems like power is not getting to the compressor or to the water line solenoids/valves. In that case there may be something wrong with the control board in the unit. Could you provide the exact model number of your fridge so that we may point you toward finding the problematic part.
    Guru:
  • 1,342 Answers
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
My maytag msd2657heb i could hear it running but the fridge and freezer not cold at all
It can be faulty compressor or issue with defrost.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Maytag msd2641kew fridge side is not cooling its warm . freezer is still cold notice some of the ice look like it was starting to melt a litte. turned freezer up acouple of hours ago stuff is staying...
Sounds like a defrost problem, is there ice on the back wall of the freezer? If so the defrost system has failed. The most common repair is a Part# 67004757 defrost thermostat and adaptive defrost board Part# 67004704. Even with the parts in your hand, you will need to de-ice the freezer to replace the thermostat in the freezer section, then unplug unit to replace the adaptive defrost board located in the controls of the refrigerator section. Normally it can take about an hour to complete.
Good Luck
Jul 13, 2011 | Maytag MSD2756G Side by Side Refrigerator
The refrigerator has quit working. Lights come on and fan appears to be running. Not cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Oct 12, 2010 | Maytag MSD2756G Side by Side Refrigerator
We keep having to "defrost" our refrigerator. It is five years old. A repairman came out and showed us how to take the inside back panel off of the refrigerator part and de-ice it. Why does ice keep...
A lack of refrigerant or a compressor problem might be the cause of freezer low efficiency but that is unlikely to blame for the buildup of ice in the refrigerator.
A certain amount of ice is normal and initially in the evolution of the fridge there was a need for routine deicing, typically just a few times each year. Later a heating element was included to ease the task of defrosting.
These days the heating element is now automatically switched on briefly every time the cooling cycle finishes and the resulting water drained into a cup mounted on the compressor. The heat from the compressor evaporates the water and the fridge remains frost-free.
I expect your fridge should be frost free and clearly the auto defrost is not working. This shouldn't be a great problem and if everything else was good it would just mean routine deicing like the early days. Clearly everything else is not good and the buildup of ice is much more than normal.
Assuming it isn't caused by an elementary mistake like placing hot food in the cabinet there are two main causes of excessive ice buildup - one is a defective door seal and the other is failing cabinet insulation, the latter marked by the compressor needing to run longer to maintain a low temperature and parts of the outside of the cabinet feeling "chilly".
Oct 05, 2017 | Samsung 26.1 Cu. Ft. Side-by-Side...
Maytag wide by side not cooling. just prior to this frost build up on top of freezer. Compressor not running.
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. My coil was solid ice.
Apr 05, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag side by side slowly getting warmer
I have actually been having the same problem. We have a Maytag MTB2156GEQ and it hasn't been cooling well at all lately. Temp in the fridge is about 52 degrees even on the highest setting. The freezer seems to be fine. I pulled off the back panel and vacuumed out the condensor coil and everything else under there. I then pulled out the control panel on the ceiling of the fridge. The channel between the freezer and fridge was almost completely blocked with ice. I cleaned it out by taking out the back panel of the freezer and pouring hot water down through the hole until it was clear.
that seem fix the issue.
Aug 10, 2008 | Maytag MSD2656G Side by Side Refrigerator
Maytag fridge
Without knowing the type of fridge(side by side, freezer on top etc.) all I can offer is this: Somewhere between the freezer and the fridge there's an opening thermostatically controlled to transfer cold air from freezer to the fridge. Most have a fan to move the air. So either the fan (if so equipped) stopped, and need to replace, or opening is stuck closed, or plugged.
If freezer is working fine, this is the only problem I can think of.
Hope this helps
Dec 15, 2007 | Maytag MTB1504A Top Freezer Refrigerator
Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
Refrigerators Logo
185 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
