Question about Veo Cameras
My pictres are not in focus - Veo Cameras
    Guru:
  • 1,894 Answers
Use a auto mode to perform auto focus
Posted on Jul 05, 2008
    Sergeant:
    Champion:
  • 417 Answers
Try resetting the camera
In Samsung tv complaint<br/>in first time tv working in normal and after sometime picture is blinking and slowly no pictre. that time sound is also ok.<br/>after that am am change the capa
Check its solder terminal at the CRT board [Filament voltage]. It sounds like the filament do not glow after some time due to a loose contact at the CRT base connector sockets. Check it.
If this does not help, check the ABL circuit for any open resistor.
Oct 25, 2014 | Televison & Video
Poor pictre quality
This set has 3 CRT's (picture tubes)
Remove the back bottom cover
Clean the CRT's with windex and a soft cloth.
(Find the Screen/Focus block)----Remove front grill cover and panel which covers the Screen/focus block.
Cover 2 crt's and adjust the focus control for remaining crt---(using the convergence pattern in the menu for the set)
adjust for the best focus.
cover that crt and move on to the next crt using the same procedure.
After setting the focus on all 3 tube's you will have the best focus possible for this set. If picture is still bad, you have bad crt's and the set is junk.
Cost to replace the CRT's is enormous!
Craig
May 08, 2009 | Televison & Video
Help! My TV is turning red
It may be a problem in the picture tube of your TV set. It may be because of various problems such as you might have wiped your TV screen with a cloth or some thing very harshly or your TV is in a position that it receives direct air from an AC or a room cooler.
If u have a plasma TV which do not have any picture tube then u may have pressed the screen hardly.
The solution for a TV with a picture tube is that you may need 2 change your pictr tube or call an expert from the company from where u purchased you TV.
If its a TV with a LCD screen then u may need to adjust the contrast to a lower pictr quality or u may need to refill the liquid inside the screen.
Sep 26, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen pictre is to large
go control panel then click on appearances theme click on resolution the higher the resolution the smaller the picture
Jun 30, 2008 | Computers & Internet
Lines in every pictre ,
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free (for the S1 IS), including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Feb 18, 2008 | Canon PowerShot S2 IS Digital Camera
Many compact digitals (of all brands) use a Sony sensor and Sony had a bad batch go through and the sensor's contacts are failing.  If you are getting images corrupted with lines, bad/weird colour or severe noisy hash, you may well have a dud sensor.  Check the canon web site for a list of effected cameras and/or contact Canon service.
Canon is replacing effected sensors free of charge regardless of warranty status.
Jan 31, 2008 | Canon PowerShot S2 IS Digital Camera
Toshiba 42H81 Red Vertical bar on right side
The symptom suggest a faulty converge ic.you need to replace that ic ( stk392-110 ).
Aug 06, 2007 | Toshiba 42H81 42" Rear Projection...
Olympus fe-130
This need looking at - Check Olympus Tech Help- especially if it is a recent purchase
May 22, 2007 | Olympus FE-130 Digital Camera
Kd-avx1
no take it back
Apr 10, 2007 | JVC KD-AVX1 Car DVD Player
Cameras Logo
Top Veo Cameras Experts
Are you a Veo Camera Expert? Answer questions, earn points and help others
