Keyboard Typing Several Characters
I have a Toshiba R100 laptop that has suddenly started typing several characters whenn a single key is depressed. The PC was OK when switched off but developed the problem at power on.
I've plugged a USB keyboard in which works perfectly. I think it may be a virus and have done a complete sweep of the disk using Norton and found nothing.
Any help you can give will be greatly appreciated.
    President:
  • 173 Answers
There could be a couple of options here: 1. The keypad is defective in which case you need to replace it. 2. The keys are sticking which will cause this problem and is quit frequently what happens (unless all your keys are doing this in which case it will not be the problem as not all keys stick at the same time unless something has been spilled on the keyboard) 3. You might need to update the drivers for the keypad which you can download from the manufacturer's website. I do not think you have a virus because you would notice other things happening to your operating system or hardware. Since you plugged the usb keyboard in and it worked just fine, I think your keypad needs replaced, which you can order from the manufacturer as well and they are not that expensive. You can try downloading the drivers first and see it that corrects the problem or try removing your laptop face plate and cleaning your keypad, just be careful with the plastic tabs that hold the face plate on and not break them. I am pretty sure your keypad is bad. Please let me know if this helps or you need further assistance.
If you would not mind rating my help, I would really appreciate it. Thanks
Posted on Jul 07, 2008
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    When typing certain letters or numbers other letters and/or numbers automatically appear. Example when i type the "p" a space automatically appears; (p ap er). When i type the number...
    Well it could be several things, not the least of things is radiated electrical noise. Seriously, I had several customers get hit with this problem. One test was to hold your hands just over the keyboard. If random characters appear, you sitting within the radius of a strong transformer.
    Look around the area you are in, do you see any type of antenna nearby? If you do, rotate your lap top 90 degrees.
    Also, the keyboard may be starting to fail. From your description I would suspect that the scan code for the key you pressed is not getting reported back to the CPU properly.
    Replacing the keyboard on a Satellite is fairly straight forward. The replacement part from Toshiba only cost $35. and that included shipping.
    Don
    Nov 17, 2010 | Toshiba Laptop Keyboard for Satellite L10,...
    My toshiba laptop is typing wrong characters but my wireless tevion keyboard is o k. Is there a solution to this ?
    Sounds like the laptop keyboard went bad and thats why its typing wrong characters. Best way to verify this is to use a USB keyboard on the laptop, if the USB keyboard is typing the correct keys then you know the laptop keyboard is bad. If the USB keyboard is typing the wrong keys as well then you know its a setting in windows that is causing the keys to type wrong characters.
    Apr 28, 2010 | Toshiba Satellite P105-S9312 Notebook
    My Logitech S510 keyboard is not typing all of the characters I key or repeats one character several times. It is as if there's a delay between keystrokes and what appears on the screen. Same thing happens...
    Try running connect MANY times. it may sound goofy, but come to find out I had a new set of cordless phones which used similar freq's. so try to do connect several times.
    Nov 09, 2009 | Logitech Cordless Desktop S 510
    Typing any key on the keyboard produces multiple
    hi Jeff.
    go to this link should show you how to do a reset of your laptop.
    How to Reset Your Computer .
    or this link.
    laptop basic reset Google Search
    Nov 18, 2017 | Toshiba Portege M205-S810 Tablet PC
    Toshiba Satellite A45-S250 non-numeric keys locked
    Your keyboard logic chip is in need of therapy.
    Replacement of keyboard warranted.
    Now, I thought that it might be a redesignation of your language code, but that proved not to be the case.
    Mar 29, 2009 | Toshiba Satellite A45-S250 Notebook
    Extra characters display when key pressed
    Check the NumLock Key. If your keyboard isn't typing the correct characters, you may have the incorrect input language selected. Many laptops will convert most of the keyboard into a number pad if NumLock is enabled. Press Num Lock + Function or Function then NumLock to make sure its disabled.
    Cheers!
    J the Guru
    Aug 12, 2017 | Microsoft Visual FoxPro Professional...
    Toshiba tecra s2 keyboard starts skipping typed characters and stalling
    there may be a pressed key in your key board, but pls chcek the key board with keyboard tester free software to identify pressed keys.
    pls remove the key board cap carefully and clean
    Apr 29, 2017 | Toshiba Tecra S2 Notebook
    Toshiba Satellite Latop - Keyboard problem when entering password
    my email add is kant_rai@yahoo.co.in
    i need to driver for my laptop model no.is
    A60 satellite
    can you suggest on my email add.
    Mar 31, 2008 | Toshiba Satellite A60 Notebook
    Keyboard typing wrong characters
    turn off the keylock on boot- this is an option in the bios. also you might be able to use the fn key and turn it off manually
    Nov 22, 2007 | IBM ThinkPad R50e Notebook
    Computers & Internet Logo
    113 people viewed this question
    David Payne
    David Payne
