Question about Whirlpool Washing Machines
I'm experiencing a Kenmore Elite Oasis HE model 110.27082601 washer problem. The washer is displaying a digital code of LR. I have not idea what this code mean. I don't have a copy of the user manual and have searched the internet and can't find a thing. I understand that 110 identifies the manufacturer of the washer and this washer is very similar to Whirlpool's WTS6600S, 6700T and 6400S models. Realizing that Whirlpool manufactured the Oasis to meet the specifications of Kenmore.. I wonder whether or not Whirlpool would be able to provide the answer to my concern.. What does LR mean? I'm willing to purchase the user guide; but contacting service support at Sear/Kemore is a joke. They was to charge $65 to send out a service tech.. Your assist would be appreicated. Cliff
  • cliffco433 Jul 05, 2008
    You have not answer my question? What does the error code LR means? You gave me a global answer that wasn't in the ballpark.
    Cliff
    My question was not answered. My specific question was 'What does the error code LR means?' Kenmore Elite Oasis HE model 110.27082601 manufactured by Whirlpool to Sear(Kenmore Specifications). The Oasis is similar to Whirlpool models WTW6600S,6700T and 6700S.
  • 413 Answers
LR indicates the machine control can not detect the motor rotating (Locked Rotor) when commanded to. This could be a failure of the RPS (Rotational Position Sensor) located at the motor that monitors the rotational speed of the motor or the motor controller has failed.
If you can't manually rotate the basket, then the motor controller has probably failed which in integrated into the machine control. Check your owners manual for limited warranties on this part.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 05, 2008
    Sergeant:
    Champion:
  • 417 Answers
LR Replace switch, linkage, lock solenoid or control board.
may get one from your manufactur
Posted on Jul 04, 2008
    Genius:
  • 3,422 Answers
Lr means locked rotor. this is a normal problem and you need to replace your motor and motor control board.
This problem requires a physical presence of a tech so that it can be fixed.
    Genius:
  • 1,665 Answers
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Hello.. I don't have a lot of time.. to work on this.. but wondering what the dl error codes is on a kenmore elite oasis washer model 110.27086603 serial #CT4070587
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.27086603&pathTaken=partSearch
The DL code points to a Door Lock problem.
See the Whirlpool Service Manual for their Cabrio washer (basically the same as the Sears Oasis).
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
It has troubleshooting and testing procedures.
Apr 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Why is my kenmore elite (top loader) oasis washer HE is displaying a code of HC
The water inlet hoses are probably removed and reconnected in reverse, and then trigger the HC error code to flash indicating the hot and cold water inlet hoses are reversed. Reconnect the water inlet hoses properly and start a cycle then let us know what happens next.
Apr 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Elite King Size Capacity Washer and it displays an F code. It will not go through a full cycle. What could be the problem? Thanks.
in the back panel you will find a tec sheet with f codes . like f1 f2 f3 f4 f5 and so on but just a F ??? hope this will help mm
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore, Elite Oasis washing machine, apprx. 2 yrs. old has display code F-50 with continuous beep. Technician unable to come out for 1 week. Any ideas?
problem with the RPS(rotory positon sensor)sensor.wait for the manufacturer for repair.make suer the washers not in use as it might lead to F51 error code.
Dec 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
145 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
