Question about Linksys Wireless-G Broadband Router
Setting up my wireless network
I have my router installed, I hope its right, at least I can get on the internet from the compuyer it is connected to. I need to know what to do so I can get on the internet from my 3 wireless computers, 1 is a mac.
  • 13,433 Answers
All 3 computers need a wireless lan adapter, then you need to configure eatch one to use your home wireless.
Posted on Jul 04, 2008
  • 1 more comment
  • Ekse Jul 04, 2008
    read here for the windows pcs
    http://helpdesk.coloradocollege.edu/inde...
    it is similiar on the mac.
  • Ekse Jul 04, 2008
    In the webpage you need to replace the details with your own home network info.
  • Ekse Jul 04, 2008
    Basicly if you haven't configured any security into your wireless, all you have todo is to get the wireless adapters working, then windows will report of a available network, you simply need to connect to it with the connect button if you have not made any changes.
    I would recommend seting up a wep encryption to it.
    Heres how to do that
    GetConnected - How To - Secure Wireless Router Set Up
    for spesific instructions on your model check your manual.
Manual for linksys e1000 how do I connect router to my compuyer?
You can either connect an Ethernet cable from the router to the built-in Ethernet jack that most machines have OR you can install a wireless (Wifi) adapter in your computer and follow the instructions to set up a wireless network...
May 11, 2011 | Cisco Linksys E1000 WirelessN Broadband...
My new Netgear WNR 1000v2 package does not contain an installation guide, only a Resource CD. Please take me through the installation procedure.
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Mozilla Firefox.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a username and password. By default, the username is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it is 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Feb 24, 2010 | Computers & Internet
I have VISTA 64
Here are some troubleshooting steps that I suggest you try:
a. Please open any web browser like Internet Explorer or Netscape Navigator.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
Jul 08, 2009 | NetGear WNR2100 Wireless-N Broadband...
Lost install cd for netgear wndr33oo
5. Power cycle.
Jul 08, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Trying to install wireless router but my laptop doesnt have a disk drive to install disk. is there any way of installing over the net
5. Power cycle.
Jul 01, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Netgear router
Here are some troubleshooting steps that I suggest you try: 1. Check physical connections. a. Connect the modem to the Internet port of the router. The Internet ?i? LED on the front of the router should light up. b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up. 2. Access the router's web-based utility. a. Please open any web browser like Internet Explorer or Netscape Navigator. b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password". Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default. To reset the router: a. Please push the reset button at the back of the router and release after 30 seconds. b. Unplug the power adapter for 10 seconds and then plug it back in. 3. Configure the router. If your Internet Service Provider is using a cable connection, please follow the steps below: a. Click on Basic Settings under Setup tab. b. Select No for Does Your Internet Connection Require A Login?. c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button. If your Internet Service Provider is using a DSL connection, please follow the steps below: a. Click on Basic Settings. b. Select Yes for Does Your Internet Connection Require A Login?. c. Select Other on the Internet Service Provider drop down box. d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply. 4. Configure the wireless settings. a. Click on the Wireless Settings under Setup. b. Change the SSID to any unique name. c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy). d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit". e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number. Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection. f. Click Apply button to save the changes. g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle. 5. Power cycle. a. Power off the modem, router and computers. b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking. c. Power back the router and the computers. Check if it will be able to get online. If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below: 6. Connect wireless computer to the router. If you are using Windows XP with Service Pack 1, please follow the steps below: a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Advanced tab. d. Please delete all the preferred networks then click on OK. e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key. f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router. g. Make sure not to enable IEEE and then click on Connect. If you are using Windows XP with Service Pack 2, please follow the steps below: a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Change Advanced Settings. d. Click on the Wireless Networks tab remove all the preferred networks then click on OK. e. Right click on the Wireless icon then click on View Available Wireless Networks. f. Select your network and click on Connect. g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router. If you are using Windows Vista, please follow the steps below: a. Click Start then select Connect To. b. Connect to a network window will show up. c. Select your wireless network and click Connect. d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect. From the above configuration, please check if you can now access the Internet.
Jun 16, 2009 | NetGear DG834G Router
My laptop finds wireless router but will not connect to internet
Hi there. You may need to connect to the wireless network manually. What is the operating system running on your computer? If XP, you may follow these. (This is also applicable in other operating system, it may just vary a little) Right click the monitor icon showing on the system tray near the clock. Point the mouse in the icon and it will display the name if it is wireless network connection or network connection. Right click the icon and look for view available wireless network. If it is not showing, look for network connection. Right click and select "open network connection". Right click wireless network connection and select "view available wireless network" . Look for the wireless network you're trying to access or have connection.Highlight and click connect. If encrypted, you need to supply the pass key or security key twice and hit connect. It should allow you now to go online wirelessly. Please remember these, you should be able to go online wired. Make sure that there are other wireless computer connected to the wireless network you're connecting with and can go online wirelessly.
Hope this help :)
May 16, 2009 | Dynamode (R-ADSL-C4-W) Wireless Router
I'm able to connect to the internet without my netgear router. However, when I plug my connection into the router I'm unable to connect. I've recycled the router, tried different ports on it, and have...
Hope this step by step router installation will help...
5. Power cycle.
Mar 16, 2009 | NetGear WGT624 Wireless Router
My installation disk is faulty..
Your router actually works better without the installation disk because the program on the cd is actually known to be very controlling. If it is setting up your router you are having trouble with, send me a message of call netgear.
Apr 23, 2008 | NetGear RangeMax WPN824 Wireless Router...
No internet access
disable the other adapters and try agan...
then use use the set up Home or small office networking wizard in the left to complete it
hope it worked !
Mar 10, 2008 | Computers & Internet
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
