Question about Dometic Rooftop RV Air Conditioner
RV air conditioning
My air will get down to the right temperature then shut off . It will go on again immediately for about 20 seconds and then shut down. I was told it was the high pressure switch. How do I remedey the situation?
Richard
  • 828 Answers
Your system does not have a high pressure switch. Look to a voltage supply problem.
Posted on Jul 07, 2008
At night its shuts down when the therm is satisfied,but trys to restart right away and when it does start it shuts down right away and just keeps doing this
The thermostat has a differential built into the temperature sensing operation. The differential is normally a degree or more. If the stat shuts down at 72 degrees it should not start the unit again until the temperature in the room reaches 73. If the AC runs and cools properly until it shuts down, I would check the thermostat. The AC can not restart immediately after it shuts off because the pressures in the system are too high at the compressor. It takes a few minutes for the pressures equalize allowing the compressor to start. If the stat tells the unit to start under high pressure, the compressor will shut down on overload. It will start and run after the pressure falls enough for the compressor motor to run.
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
I have a issue with my 2 Dometic DuoTherm air conditioners. The rv is a 2014 Palamuno Saber 50 amp fifthwheel. Ok. They cool very well but at different random times the compressor shuts off while the fan...
how long a power cord do you have and what size conductors are in it. when a a/c shuts down do to thermostat reaching its setting then trys to start back up shortly the pressures dont have time to equalize resulting in high amp draw. if fans runs all the time instead of shutting off with compresser it will call for cooling fast. i have a 2003 cardinal with 2 a/c's the smaller one has a continous fan & the larger one cycles fan with compressor. i have power cord rated for 50 amps. 110 to 115 is still a low vooltage condition.
Feb 21, 2015 | Dometic Heating & Cooling
Air conditioner turns on, then off, then on again immediately after
going out on safety or relay getting erratic connection from t-stat.
Nov 07, 2013 | Dometic Rooftop RV Air Conditioner
HP M7357c overheating problem
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Feb 03, 2012 | HP m7357c PC Desktop
Its on a 76 dodge coachman motorhome. Just bought it and went camping. Everything worked great till the second day. All of a sudden the external generator started bucking and shut down. Checked oil and all...
Could be bad compressor but I would change compressor start capacitor first, as these are a more common problem and I've seen many go recently due to hotter than normal temperatures in our area. PLEASE, Make sure someone who knows how to handle a capacitor does the work, as they can give a fatal shock, even with power off, if not handled by someone who is experienced in that area. (technician, or electrician) New capacitors are about $20, and half hour max, to change.
Jun 26, 2010 | Dometic Rooftop RV Air Conditioner
How cold should it be in rv with two low orofile
Most AC units only change temperature approximately 20 degrees F from ambient.
Aug 17, 2009 | Dometic Rooftop RV Air Conditioner
Temperature goes up when air conditioning is turned on
your car has two electric cooling fans one is specifically for the added heat load the A/c puts on the system. . This fan isn't turning on...check your fuses and the fan relays
Apr 04, 2009 | 1999 Honda CR-V
Duro Therm air conditioner
Most likley this is caused by a pressure switch dropping out then making again after the pressure drops off. Try cleaning your coil on the outside on the roof as most likley it is a high pressure switch causing this problem.
Jun 30, 2008 | Dometic Rooftop RV Air Conditioner
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
134 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
