Question about HP LaserJet 1010 Printer
Paper torning my printer after printer torn the paper l sp plz help me
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Huh?
Posted on Aug 20, 2008
I can see the torn paper in my ESP3250 KODAK printer. Please help ,how to remove the torn paper.
Go to the back of your unit remove the cover and gently remove the paper and put the cover back. Your are good to go.
Oct 14, 2014 | Kodak ESP3250 All in One Printer
Samsung ml 1660
If you did not find torn paper, another thing to check is the sensor where your paper is placed. 2 things: is the sensor clean/void of debris? If so, could it be defective. Hope this helps!
Mar 08, 2014 | Office Equipment & Supplies
My kyosera mita 5035 it says tray its out of oder
This usually means that you have some torn paper jammed behind the cassette.remove the cassette and the torn paper.
Oct 05, 2013 | Kyocera Mita KM-3035 All-In-One Laser...
Torn paper- how can I disassemble epson workforce 610?
Before you do a complete teardown, use a flashlight to examine every possible point in the paper feed path where the paper is jammed. There may be an easier way to clear it. In some cases I have had to clear a paper jam bit by bit using tweezers.
Oct 15, 2012 | Epson Workforce 610 All-In-One InkJet...
Printer has stopped. Tape inside has torn so I cannot get anything printed.
Dear Sir,
Turn off your printer, open printer front cover and then slowly remove torn-jammed paper piece from printer roller. Then turn on printer. It will solve your printer Problem.
Jan 17, 2011 | Lexmark X1270 All-In-One InkJet Printer
I've cleared to paper jam. Paper was not torn so
you have take the ink cantainer out and disconect the printer for one min then reconnect
May 27, 2010 | Dell 1700n Laser Printer
Paper is jammed inside printer - part of paper torn off trying r
In the back of the machine, there is a door/hatch that you can remove. That might help you.
May 24, 2010 | HP DeskJet F4280 All In One Printer InkJet
Paper goes scew whiff when trying to print. Says there is a paper jam but none visible.
Smaller torn bits of paper may still be in the printer. Unplug the power, open the back access panel. Look for torn or jammed paper. Also check the ADF (auto document feeder) for a jam.
When you try it again, Dell recommends that you fan your paper. Fanning the paper helps break apart the bonds left by improperly cut paper which leaves the edges of the sheets interlocked.
Dec 05, 2009 | Dell 962 Photo All-In-One InkJet Printer
3210 paper wil not feed in the printer it not jam it just will not feed
  • Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
  • With the printer off, check for any obstructions such as torn paper or foreign objects.
If there is no torn paper or any obstruction then follow this
  • Place 20 sheets of paper in the printer ensuring none of the paper is torn .
  • Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
  • Try to feed paper manually .
If your problem is not solved yet then follow this
  • Uninstall the printer driver and restart the computer.
  • Re-install the printer driver
SAM ANDERSON
Sep 16, 2008 | Computers & Internet
Paper jam in 1120 hp printer
Hi there, Try printing again using heavier paper. Board types will likely push the torn papers out. Hope this solves your problem.
Sep 17, 2007 | HP DeskJet 1120cse InkJet Printer
HP LaserJet 1010 Printer Logo
24 people viewed this question
Ben Johnson
