Question about Maytag Refrigerators
Trying to get handles off the doors - Maytag Refrigerators
  • 481 Answers
Sometimes the screws that hold the handles on are under plastic or metal trim. see if the ends of the handles slide off, or try to take any metal trim off with a butter knife.
let me know if you need more help
Posted on Jul 04, 2008
Passenger door handle broke of the outside of Nissan pathfinder, now the door wont open from the inside or out. how can we get the door open?
Remove the door's inner (interior) panel and inspect the trailing edge of the inside of the door. You should be able to see the door linkage from both the inner door handle and (what's left) of the outer handle (try moving the inner handle to see how the linkage is routed. I suspect that when the outer handle broke, its linkage dropped onto the inner handle's linkage and jammed it. With a long screwdriver, try moving the inner handle linkage to release the door latch and then replace the outer handle and its linkage (a salvage yard may be the best source and a Mitchell body repair manual should show hoe the linkage is routed and attached. Good luck.
Oct 10, 2013 | Cars & Trucks
Back door won,t open on my 02 avalanche
door handle broke depends on what door handle it is.if door cant be open on out side out side door handle broke.if cant open door on inside inside door handle broke.door handle clip that connects to latch rod broken.when you try open door handle not engage to latch rod.door not going open.have to replace door handle with new clip holds latch rod in place.
Jan 09, 2013 | 2002 Chevrolet Avalanche
Rear door on 06 jetta wont open
At a guess the outside handle has become detached from the linkage inside the door and you've got the child lock on as well.
Well to get the child lock off, you need a long fairly broad plastic strip, I've used the long side cut out of a plastic milk carton in the past.
Wind the window in the offending door down, then insert the plastic strip in the door gap underneath the handle, once in try the internal door handle, if it fails try again working your way down the door by widths of the plastic strip, trying the internal door handle as you go, with luck you'll have release the child lock by the 3-4th try.
Once open, its taking the inside door card off and re-attaching the linkage for the outside handle.
May 01, 2011 | Volkswagen Jetta Cars & Trucks
Need a new door opening handle?? the handle broke
You should be able to order one from Splendide. In the meantime, try using a screw driver to manually push the door release button.
Michael Lee
Thor Appliance Company
www.thorappliances.com
Sep 22, 2010 | Splendide 2000S Front Load Washer / Dryer
Broken door handle for 1990 subaru loyale.
There are a few after-market sellers who offer door handles for most cars on ebay, reasonably priced. Go to www.ebay.com and enter "Subaru Loyale door handle" in the search bar. Alternatively, you can order one from a salvage yard, try www.car-parts.com. And of course, if money is no object, you can check with your local Subaru dealer's parts department.
Replacement is not too hard. You may be able to do it without even removing the door panel. There is a screw that holds the handle in the door. Undo it, then slide the handle back and forth gently to loosen it from its set holes, and pull it away from the door panel. Then unfasten the door lock connecting rod/hook from the back side of the handle assembly. Fasten the new handle on the hook, re-insert into the door panel, set the handle in place, and replace the holding screw.
Mar 17, 2010 | 1990 Subaru Loyale
Ford explorere rear door will not open
check the door handle in side door panel there is a rod that goes into the door handle that might have fallen out of it or more likely broken the door handles at a junk yard are about 5 dollars if you take off make sure it function that none of the teeth of the handle are broken and and make sure you have the right or left door handle it will be marked on inside of interior door handle . this handle slides forward towards the front of vehicle for removal then turn to remove rod from handle.
Mar 07, 2010 | 1997 Ford Explorer AWD
How to replace a 2003 grand vitara's rear door handle
1. open the rear door
2. open the rear door sidings
3. try loosing the not of the handle
4. remove the steel wirings of the handle
5. install the new rear door handle
Jul 15, 2009 | 2003 Suzuki Vitara
BMW X5 2001 -DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR.
DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR. FROZE UP IN ICE STORM AND APPEARED TO BREAK WHEN TRIED TO OPEN DOOR. INSIDE HANDLE STILL WORKS. IS DIY REPAIR FEASIBLE?
Jun 23, 2009 | 2001 BMW 5 Series
Driver side interior door handle stuck open (not flush with door)
the only way to fix handle is to replace it.not to difficult.
Mar 17, 2009 | 1999 Lexus ES 300
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Refrigerators Logo
128 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
