Question about Whirlpool Dryers
Whirlpool awz3413 tumble dryer, when I switch it on nothing not even the green indicator lights come on. I checked fuse in the plug and the power supply these were ok, not sure where to go next. the machine is 2 years old and worked well until yesterday.
  • 76 Answers
SOURCE: Dryer runs, tumbles clothes, but does not heat
PSUinNC The first thing you have to do is to check in what position is the temperature switch . If the temperature switch is in the "air fluff" position, then the heater will stay "off". If this is not an issue, reset the circuit breaker. The motor needs only 120V to run, but the heater needs 240V and if one of legs is missing, the dryer would not heat. If it did not solve the problem, you have to perform full diagnosis. You will need some simple hand tools and a meter to check a continuity. If you are fillng you can handle it, let me know and I'll give you the step by step instructions. Gendos...post back
Posted on Feb 26, 2007
the dr
  • 447 Answers
SOURCE: dryer won't tumble
Check thermal fuse located behind rear panel mounted on dryer (depending on model of the dryer) duct. Fuse is the component with 2 blue wires and is white in color. Try jumping 2 wires together or OHM out fuse. Fuse being bad is a sign that either
a) Dryer vent is clogged ..... If dryer takes any longer than 1 60 min cycle to dry loads than the vent IS CLOGGED!!
b) Dryer thermostat (next to fuse with 4 wires 2lg red and 2sm)
is not cycling proper
c) some other electrical short causing element not to cycle proper
Check Temp of discharge air with thermometer
on High should cycle on somewhere around 120
and back off at no higher than 170 no less than 155
Posted on Jan 18, 2008
futureloginn
  • 734 Answers
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
localwonder
  • 6784 Answers
SOURCE: our whirlpool 6th sense dryer model awz3413 will
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Posted on Jul 21, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool WED5300VW0 dryer--gets hot, tumbles,
If you are experiencing longer dry times and poor drying efficiency, the following link can give you some things to check before assuming you have a malfunction with the dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If the dryer can't breathe it will not dry efficiently and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This can also become a fire hazard if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call.
Posted on Jan 04, 2010
Bosch Tumble Dryer WTE84308GB/17 will not switch on
Complete power failure such as this would indicate a surge or burn out on the electronic unit. I would have a technician look at this one.
If you are really keen, unplug the machine and take the lid off. Have a look at the cabling and front module to see any signs of moisture or burn marks. It may show something obvious.
My advice though, call a technician or take it to an appliance workshop.
Apr 05, 2014 | Bosch Dishwashers
Clean Lint Filter Light Keeps Dryer from starting
Evidently the fuse blew for some reason.
Keep the dryer unplugged from power for one hour or so. If it still does start, you will have to take apart the dryer, check the fuse, check the thermal fuse, and test the wirings inside.
If you need to call arepairman use the number listed on the owner manual.
Oct 06, 2008 | Frigidaire FGQ1442ES Gas Dryer
Have a Whirlpool AWZ3413 tumble dryer that will only run for a few minutes before the filter light goes on and the heat stops. The filter isn't clogged, but if I scrape off the tiny amount of fluff...
Here are more possible routes:
Duet Dryer Moisture Sensor Bar part WP3387223 How To Replace (See the KENMORE note below)... You MAY want to try cleaning the Sensor with a Q-Tip and alcohol! Not too much though... just a dab.
more from the Internet...
"This is most likely due to the vent being clogged between the back of the dryer and where ever it exits the house! This accounts for the light and the long drying times. A dryer not only relies on heat but also air flow to dry. if air flow is restricted, drying times get much longer since the moist air can not exit the dryer."
whirlpool awz3413 filter light keeps coming on even though
Here is a VIDEO for a similar KENMORE (Whirlpool). IF you suspect the SENSOR is bad and HOW to replace it:
Whirlpool Kenmore Duet HE3 Gas Dryer Moisture Sensor Bar 3387223
Be SURE and read the Comments below this VIDEO for more help!
Anthony
Dec 20, 2017 | Whirlpool Dryers
My Whirlpool Ultimate Care II dryer does not heat up, however it does tumble. Any help would be greatly appreciated. Thanks.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Whirlpool Dryers
White knight 44aw not spinning and no heat
3. Thermal fuse
4. Timer
Jul 26, 2009 | Dryers
Our whirlpool 6th sense dryer model awz3413 will not turn on
3. Thermal fuse
4. Timer
Jul 21, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool GEW9200LWO Elec Dryer
just check the fuse and plug pin connection in it
Jul 18, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer problem
Heating element
Thermal fuse
Wiring
Mar 11, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
202 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
