Question about Garmin StreetPilot c340 GPS Receiver
Lost Memory and Map Data
MyGarmin GPS c340 worked perfectly well until the following:
After using WebUpdater to download 5.9 update and attempting to download the City navigator NT 2009 (failed), I lost all of my map data.
There are no maps on the GPS although everything else functions.
My questions are as follows:
1) How can I recover both the memory and my map data.
2) If the above requires a repair, is it worth it or should I scrap the unit and get a newer one.
Any assistance you can offer, will be most appreciated.
  • 1 more comment
  • Anonymous Jul 07, 2008
    i have the streetpilot c550 have same problem everything else still works when switching on says loading maps but no maps on? i was wondering same if to replace or is it worth sending off to be repaired for a rip off price? bob.
  • sssbkeeper Jul 09, 2008
    Help! I also attempted to download an update to my Street Pilot 340 and lost all my map data. It gives my a picture of the US map with it pointing to Kansas - and I'm about a thousand miles from there. Has anyone been able to resolve such an issue? It just seems to be frozen. Very frustrating.
  • amycraig Mar 10, 2009
    I have a c510 that has lost all maps
I just spoke with Garmin and they walked me through correcting the problem - very helpful. It is a matter of resetting the unit. Turn unit off, then press a finger tightly against the bottom right hand corner of screen, holding it while turning unit on. When screen comes up, let go of power button but still pressing bottom right hand corner of screen, answer question regarding deleting defaults. It is tricky and may have to be done a couple times. Then you will answer questions regarding time zones, etc. When finished with this, turn unit off and go outside in order for the unit to re-aquire satellites. When all four bars on upper right hand corner turn green, you're back in business - or at least it worked for me. Hopefully this will help, but you may want to call Garmin as they are really helpful and can explain it better than I can. Good luck!
Posted on Jul 09, 2008
How does the map update work? Do I download to my computer then connect the GPS to the computer?
with the unit Off......
connect your gps to your computer using the USB cable...... it will detect new hardware (usb)... minimise pop up box
next
go to www.mygarmin.com this site will detect your gps model...and let you update your map and software files..... you may be asked to register ..its free
it will say to download WebUpDater utility to transfer files to your gps....done
Nov 27, 2010 | Garmin GPS
I want to download update for my germin gps, what should i do?
connect your gps to your computer using the usb cable....( most are the same usb cable that cameras use to hook to computers)
your computer will detect new hardware (usb) minimise pop up box
next
go to www.mygarmin.com .... the site will detect your gps model and let you update or downloads map
once you register your unit for free...
it will tell you to download WebUpDater utility to transfer files to your gps
Nov 23, 2010 | Garmin nuvi 200W GPS Receiver
Ive had my garmin for over two years and need to update it.. what site will allow me to do it?
With your unit off
connect your gps to your computer using a usb cable......( same usb cable most cameras use to connect to a computer )
your computer will detect new hardware ( usb ) minimise the pop up box
next
go to www.MyGarmin.com this site will detect your unit and have you register your gps to unlock map or update map and firmware
you will have to download there WebUpDater utility to transfer the files to your gps
Nov 13, 2010 | Garmin nuvi 255W GPS Receiver
How do i update my garmin nuvi 250? it tells me it needs to be updated.
Garmin is telling you to update your Map, its wants you to buy a New Map which cost around 50 or 60 dollars.....your unit will work find for now unless you need the new map 2011 it just has the newer streets and highways. Anything over 2 years old should have a newer Map..
With the gps Off
plug in your gps to your computer using a USB cable (most cameras connect to your computer with the same usb cable)
your computer with detect new hardware ( usb ) a pop up box will come up, minimise it
next
go to www.MyGarmin.com the Garmin site will detect your pluged-in unit and let your update your Map
It will say to download WebUpDater utility to transfer your map to your gps
Make sure you register your unit with Garmin at that time
Nov 11, 2010 | Garmin nuvi 250 GPS Receiver
It needs to be updated, it dosen't know the new highways.
It all depends when you brought the unit if they will update the map for free if not you have to pay for the updated map, it cost around 50 or 60 dollars
to update .... with unit off
Using the USB cord connect your gps to your computer
your computer will detect new hardware USB
now go to www.MyGarmin.com
the site will also detect your model and let you know if updates are available
if there are updates it will tell you to download WebUpdater utility to transfer map to your unit
Nov 06, 2010 | Garmin nuvi 255W GPS Receiver
How can I update my map for GPS? Also where can I get one?
with the unit off
Plug your gps to your computer using the USB cable
once your new hardware is detected go to www.MyGarmin.com
you can now Register your new unit there and get all the updates
Garmin will detect your model and let you unlock maps
it will then tell you to download WebUpDater utility to transfer maps and update
Nov 03, 2010 | GPS
How to update my garmine nuvi
To update the maps you need first to register it. Connect it to your computer and go to www.garmin.com Select your country and then click on myGarmin. Then click on Register your Garmn Product. Follow the prompts. You'll be asked to create a username and password. Write them down and remember them as you'll need them anytime you update your maps.
After you've registered go into myGarmin and click on myMaps. Your maps will be shown and if there's an update it will show Update Available. Click on this and it'll bring you to the download site. You'll have the option to download if you have broadband or to buy by dvd if you don't. You'll need a credit card to pay.
To update your software: If you're updating the map it will normally first update your software but if you only want to update the software and not the map connect your satnav to your computer and download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and install it. When it's installed it'll look for updates to your software. Follow the prompts.
Aug 11, 2010 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 1340 freezes on start up
If your nuvi series device is freezing on the map screen but still providing voice prompts there are two steps you can try to resolve the issue including updating the software using WebUpdater* and performing a master reset.
To download WebUpdater and update the software:
  1. Go to http://www8.garmin.com/products/webupdater/howtoinstall.jsp
  2. Follow the on screen instructions.
To perform a master reset on your nuvi series device: CLICK HERE
Warning: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 18, 2010 | Garmin nuvi 1300 Car GPS Receiver
I tried to update my garmin. The screen doesnt move (or continue to download) I allowed for block ups.
You need to download and install the Garmin WebUpdater and Garmin Communicator Plugin both available from Garmin's website onto your computer. This allows updates to be installed directly to the 765T and provides the necessay USB drivers as well. The 765T must be connected to your computer when performing all updates or upgrades.
You may need to create a MyGarmin account and register your Nuvi 765T.
Resetting the 765T: with the unit off, press your thumb or finger in the lower right corner of the screen while turning the 765T on. This will clear all user data, base map software will remain intact. Connect 765T to computer and proceed with the Garmin WebUpdater.
Dec 22, 2009 | Garmin nuvi 765T GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
610 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
