Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover steam cleaner F5805 no manual
Can anyone explain how to get the clear plastic cover off so I can clean out all the cat hair that has accumulated while sucking up water?
The plastic wand helps, but I have found that when I pick the entire unit up and take it to the sink and run water in the top of the plastic cover it cleans it out better than anything. I get alot of pet hair up also and it looks awful -- but the wand only cleans out the hair -- the dirt needs to be flushed out some time too
Posted on Oct 15, 2008
You need to buy a little gadget that will slide up in to clean it out you should be able to fine one at a vacuum store they are very inexpensive. its like a little wand
Posted on Aug 01, 2008
I have a Hoover V Steam Vac model F7412. The tank for the clean water and cleaner fluid leaked out the bottom. I purchased a new tank but something in that area is still leaking. I know it is not the...
My clean solution tank is leaking from the bottom, too. It is not a hose or a valve. The clean solution tank is leaking in-between the clear plastic walls of the solution tank & the grey plastic bottom that are connected, together. I was thinking of caulking it all around the bottom where the clear plastic sides join the grey bottom plastic. I can't get into ordering a new one (spending $) unless Hoover will send me a new one for free. Purchased at Kohl's in Massapequa, NY in June 2008. There's a one year warrantee AND the directions say to EMPTY the solution tank after each use. Which I normally do because the tank runs dry.
Aug 08, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
How do i clean my hoover steam vac
The recovery tank cover does not come apart. If it is rinse out, immediately after you use it, this should not be a problem. However, if it dries before being rinsed, the dirt sticks to the surface making it difficult to remove since the cover does not come apart. The easiest way, I have found to correct this, is to soak the cover in warm soapy water and then use long pipe cleaner or wire wrapped in pieces of paper towel. It is important to run clean water through the machine immediately after you use it. Not just for the recovery tank cover but also so dirt does not accumulate in the rest of the machine or hose. You can review the owner's manual at http://www.manualowl.com/m/Hoover/F5914-900/Manual/216537
Nov 16, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Please tell me how to clean underneath the clear plastic piece of the Hoover steam cleaner.
on my steam cleaner there are two small screws that hold it on take those out and wash then replace.
Nov 19, 2010 | Hoover Vacuums
Brushes won't rotate on hoover steam vac. I have removed them and cleaned.
The brushes turn by the airflow from the vacuum suction turning a turbine motor to spin the brushes. First try to spin the brushes by hand. If they won't turn it usually means the brushes are clogged with hair and debris or need replaced or the turbine could be seized up. If the brushes won't spin reach under the brushes and push the little tabs and remove the brush block asssembly from the machine. If the brushes spin freely after you remove them from the machine then that means that most likely the turbine is seized and will need to be repaced. If the turbine is not seized you may simply just have a clogged filter screen. Most steam vacs have a red screen filter either on top or underneath the machine. On the top it is under a little clear plastic cover that you have to pry off before you can pull the screen out to clean it. If it's underneath you can pull it out and clean it.
Jul 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Need instructions for filling the Hoover Steam Vac Spot with cleaning solutions
Hi There,
Here's a link to the owners manual for your Hoover F5505 Steam Cleaner that will explain step by step how you can add water & cleaning solutions and carpet shampoo. I hope that this was helpful to you. If it did help you, please be so kind and follow the Fixya model and rate the repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair.
Hoover F5505 SteamVac Spot Vacuum Product Manual:
http://www.hoover.com/pdfs/manuals/F5505.pdf
Thank you, this is really appreciated.
Chris J.
GoVacuum.com
Apr 06, 2010 | Hoover F5505 SteamVac Spot Vacuum
My brushes wo't spin on my spin vac dual v carpet cleaner
Solution: Remove the clear plastic cover located in front of the brush control switch (I used a butter knife). Locate the small screen and remove the dirt and hair from it with your fingernail or an old tooth brush. Restore the cover and you should be good to go.
Nov 22, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover f5915
Since the Steam Vac does not have any belts... the logical issue is Switch setting (Hi, Low, Off) on the base cover. The only other is dirt collection on the air intake for the brushes (unit uses air passing over plastic fan blades to spin the brushes). To clear the dirt problem, remove the clear plastic cover located just in front of the brush Switch. You can now use your finger nail (or an old tooth brush) to clean the filter screen located just below the Switch. Don't tear it, just gently remove the accumulated dust/hair.
Brushes should spin once you reassemble and power it up!!
Aug 14, 2009 | Hoover F5906-900 Upright Steam Vacuum
Hoover steam cleaner wont pickup water
in the front on top the cover that curves down to the floor is where the suction is .it should be plastic you can see into.its probably clogged with hair and dirt.you need tro take that top off and it comes apart in two sections .the middle seperates from the outer part.once apart you can clean it with soap and water.after you get that off you will see on your left side a long square port that needs to be cleaned also.please leave feedback.i hope i was of some help to.pete
Apr 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How to clean clear plastic thing in front of Bissell ProHeat?
you may have to run it to soften the hair, then you should be able to go under it with a rag to clean it.
Apr 29, 2009 | Bissell 1699 ProHeat Clear View Upright...
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
261 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
