Question about Kenwood eXcelon KDC-X769 CD Player
My KDC-X79 Has gone crazy to!
Everytime I turn my car on my Deck keeps opening and closing and wont stop. Unless i take off the Face Plate it keeps doing this. Its driving me nuts! Just wondering if the if u tried replacing the Ribbon Cable and if so, did it work? Please let me know.
Duncan
  • 218 Answers
SOURCE: My display has gone crazy
You might have a break in the flat ribbon cable that connects the faceplate to the mother board. Those types of cables often get a break in one or more to the traces (wires) that they are made of.
Posted on Jun 30, 2007
ttech
  • 139 Answers
SOURCE: No Power to face plate
Hello James,You missing a Major supply to the Face,Take a Test lite and Ck to see if your getting voltage on the Memory wire Also ck Fuses ttech
Posted on Jul 20, 2007
robotek
  • 1512 Answers
SOURCE: Kenwood KDC-322
If you have the remote control for the unit, or can buy one then you can reset the code. Just ask me how...
Posted on Feb 08, 2008
  • 105 Answers
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
Posted on Jul 15, 2009
SOURCE: Face plate will not light up
my problem as i think was same..
..problem actually not plate...it something inside...
repair guy just fixed something inside...as i understand some condinsators heats and after some pereod of time its broked by himself..so he first was thinking that it was plate but after it he foung the problem in this condensators....actually problem in tape and not in plate...
Posted on Nov 27, 2009
The radio opens with lights and lsights go out and immediately closes. Keeps opening and closing with no sounds. After doing so for a bout a year... radio came on. However did not come back on when I...
It sounds like it could be a bad ribbon cable. There are two ribbon cables in the deck, so it could be either one, or both. There is also a face position sensor lever inside the deck that goes bad.
Jul 22, 2011 | Kenwood KDC-MP822 CD Player
Faceplate wont work
the new face plate needs to be coded to the deck. with the face on you need to press and hold presets #1 and #3 at the same time. keep on holding and press reset continue to hold #1 and #3 until the unit is in all lighting mode. press AM button one time. p-rom ok will display. press and hold #6 and reset at the same time. continue to hold until display comes on.
Jul 18, 2010 | Kenwood eXcelon KDC-X879 CD Player
When i turn the car on the control panel on the Kenwood excelon KDC-X769 jus starts on opening and closing but never stays opens
you may have a bad face position sensing lever inside the deck, or bad gears. it could even possibly be bad flexible cables.
Jun 20, 2010 | Kenwood eXcelon KDC-X769 CD Player
Display on kdc-mp638u not working
These units are pretty cut, and dry.. Basicly the only thing you can check for yourself is connection. If the connection between the face plate, and the deck is good, and tight then you have one of 2 problems.
1) Bad face plate. Fix= $90-$130
2) Bad connection to the board on the radio Fix $60-$120
There is however a VERY off chance the processor is jumbled up, and wont cost you a dime to do a cold reset, so give it a shot.
To reset this unit simply remove the face plate, and locate the rest button. It is very small, but easy to find. Just use an ink pen or something of similar size to push the button.
Aug 07, 2009 | Kenwood KDC-MP638U Car CD/ MP3 Player
Wont stay open
I had load of these units and the cure is simple. You need to replace the ribbon to the faceplate as these get damaged due to wear and tear. Every unit i had with this fault, i fixed by replacing this ribbon. Buy the ribbon and surround as the new surround is a modified one to give extra life to the ribbon. Hope this helps, good luck!
May 25, 2008 | Pioneer DEH-P9600MP CD Player
Face plate will not close, retract into dash,radio plays!
Get your Shifter shortened, it will give you faster more controlled shifts, and keep your knuckles out of the dash.
Nov 18, 2007 | Kenwood KDC-MP628 CD Player
Will power up,will hide, will open on igntion start
yup.. needs a new face plate ribbon cable.. just like mine :-(
Sep 24, 2007 | Kenwood KDC-716S CD Player
Jun 29, 2007 | Kenwood eXcelon KDC-X769 CD Player
Kenwood KDC-715s problem.
the kenwoods with the motorized face platesdevelop one problem with time. the flexable ribbon cable between the main unit & the face plate. as the face open & closes, over time wares out the cable. problem consists of face plate not opening/closing, display missing & and/or some or all buttons not working. note these can also be intermittent problems. typically the part number is located on the cable itself on the side where it pluggs into the main board. since you have a service manual, you should verify it in the manual. good luck.
Dec 03, 2006 | Kenwood KDC-715S
Kenwood eXcelon KDC-X769 CD Player Logo
108 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
