Canon pc 720
Copier will not take paper to print. The copier shows the symbol for paper jammed but nothing is jammed. When button is pressed you can hear the copier not picking up the paper to copy...Help!!
  • 1 more comment
  • Anonymous Jul 13, 2008
    Have the same problem.
  • jkags Jul 13, 2008
    Same problem as crprod. My Canon PC720 will not take paper to print. The copier shows the symbol for paper jammed but nothing is jammed. When button is pressed you can hear the copier not picking up the paper to copy...Help!!
  • 970CseFix Aug 01, 2008
    Have the same problem today, 10 years no problems until this phantom jam when there is no jam!
    Paper is not jammed, lamp is turning on and moving when the power button is pressed, toner is not empty, paper feeds by manually rolling the little roller inside the side panel but not automatically when the button is pressed. I find it very interesting that there are 3 posts within 30 days on this same problem, however, I don't know how old the copiers are in the other post.
    Do we spend money to try to get it fixed, it's been good for a decade already, hate to lose it.
Also it could be a burned out expsoure lamp.
Posted on Jul 21, 2008
    Sniper:
  • 57 Answers
Check if you have any matter that is blocking the paper path, also try to clean the rollers that picks up paper. If you happened that copier is in a dusty enviroment, dust could deposit on rollers, and rollers when picking up paper will start slipping. Try to clean with alcohol.
Posted on Jul 14, 2008
  • iblah Aug 03, 2008
    Most probably the pick up clutch is not working. The thing is to inspect this clutch you have to dismantle some things from the machine.
Paper outray is showing closed however its open, in Canon mp287 printer
For Paper Output Tray error
Paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
or
look for buttons or such things on the part that has blue rectangle below.. check inside if theres piece of paper or any object.
Jan 30, 2015 | Canon Office Equipment & Supplies
Copier is Canon PC 720 Copier turns on, but makes
You said you unplugged your copier, did you unplug it for 10 to 15 minutes before plugging it back in, plug it into a differed
outlet that you know works and plug it directly into a wall outlet instead of a power strip. Check to see if your copier reaches stand-by mode then make a test sheet.
If this does not work then you have probably have an internal processing component which requires attention.
Apr 02, 2017 | Koutech Systems PC720 (IO-PC720) (IOPC720)...
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Shows paper Jam on Canon 720 PC photo copier
Sounds funny but this model shows a jam when the exposure lite goes bad. Turn on the copier and watch the exposure lamp, should lite up and not flicker. Lamp is still available.
Nov 16, 2009 | Office Equipment & Supplies
Auto Feed doesn't work. When I press the start button I get an error to open the copier and remove the paper. There is no paper above the glass. The symbols showing are LIFT and PAPER JAM.
There is a mircoswitch which may become slightly bent. The microswitch rides on the left hindge of the feeder inside the covers. When the start button is pressed the feeder may move upward slightly causing the miroswitch to loose contact with the hinge. You can usually reform the arm of the switch and make it work.
Jul 16, 2009 | Canon NP 7130 Black and White Copier
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Power problem
the left side door is open
Dec 26, 2007 | Canon PC-400 Color Copier
Printer will not print
Try Closing and opening the paper output tray then press resume button on the printer while the printer is powered on,check the paper feeder ensure that there is nothing jamming up,if this doesn't work then let a canon technician have a look at it, the problem is minor.Hope you succeed
Nov 27, 2007 | Canon Pixma iP6000D InkJet Photo Printer
259 people viewed this question
jasbo
jasbo
