Question about Motorola Mobility PEBL U6 Cellular Phone
Almost dead phone
Phone got slightly wet when a bottle of water leaked into a handbag. Sceen blank, lights on keypad go on when button pushed and blue light shows on outer screen turns green when being charged. Help please.
  • psasho Jul 05, 2008
    I have the same problem..phone was exposed to some condensation. It will turn on and even make calls, but the main screen will only turn white while booting up, then go blank. Outer screen works while charging. Is this a power issue?
  • inuyasha812 Jul 26, 2008
    I also have had this problem except mine doesnt turn on at all, no lighting up or anything except when its closed and charging. When charging the white spot glows a blue light instead of green and it says T-Mobile on the outer screen
    Brigadier General:
  • 7,752 Answers
YRAG - take the phone and have the flexcable replaced as well as fully service
inuyasha - the lcd needs replacing
psasho - no, replaced the battery as well as replacing the lcd
Posted on Oct 01, 2008
All of a sudden my keys on blackberry curve will not work, side buttons (camera, etc) ) WILL NOT RESPOND, all it will do is boot up, i can scroll up and down but cant click on anything....i didnt get it...
Hi
sinc your side key also not working seems like your phone is moisture damge from track ball area.
IF your keypad lights up that means the keypad is not loose.If not then your keypad connections are loose.
you may have use the track ball with your hand wet that cause this problem.
basically you need to clean your phone from inside.
thank you.
Sep 22, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
Phone got slightly wet. Now wont accept Pin Code.
You can try to replace the keypad because if it got slightly wet. most probably the keypad are sending erroneous data to the phone.
Feb 25, 2010 | Nokia 3120 Cellular Phone
Blank screen,i.e,white colour with some bluish dots on my mobile
if these blue marks are like ink and afer pressing it seems like it spreading then it means your main lcd is demage and you have to change it.
if its not the case and lcd is completely blue or black
then check the lcd connector if there is any wet, clean it i not, change your keypad flexi.
thank you
shakeel khan
south africa
Apr 28, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Software update on Env2
One of the biggest problems with this phone is the OK button not working, and the front keypad doing the same eventually. Everyone I know with this phone has the EXACT same problem.
Mar 13, 2009 | LG enV2 VX9100 Cell Phone Car Charger
Want to lock keypad on Nokia N73
press the top left button (above the green key) then *. that will lock the keypad. repeat to unlock.
Dec 31, 2008 | Nokia N73 Cellular Phone
Phone has been badly wet in bottom of handbag by leaking water bottle screen comes up bright orange and phone has no other response
* remove the battery first.
* keep your cell phone in a dry place atleast for 14-16 hrs.
* now put back in your phone battery.
* check whether its giving you the same .
Jun 18, 2008 | Samsung Cell Phones
Motorola v635 dead
you have a software problem. take your phone for flashing. but if there was water damage, then the phone might be dead.
flashing the phone replaces the phone's firmware with new firmware, making the phone brand new
Jun 13, 2008 | Motorola Mobility V635 Cellular Phone
My Z3 got wet...
can you send me a code so i can unlock my phone
Apr 25, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Keypad light
because your phone is grounded, maybe can off the light if you a tecnician or not only have to do is you can try hot air to remove the wet of cell phone board dont heat the c,p,u on the board because maybe dead your phone heat all board just count 7 then remove the hot air
Nov 18, 2007 | Nokia 6101 Cellular Phone
Motorola Mobility PEBL U6 Cellular Phone Logo
87 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
