A pair of yellow cotton pants absorbed color from a blue item that was in the wash. How do you remove the stain from the pants?
    Novelist:
  • 177 Answers
Did you dry them in the dryer? if you did then the stain is set, and it wont come out.
If they where line dried or ? Start by washing them again, with the hottest setting they can take, using detergent. It may just wash out.
If not Rit dye has a colorant remover available, try that.
Good Luck.
Posted on Jul 07, 2008
SOURCE:
The machine is doing yellow spots on several clothes and it is clean from inside and nothing could cause rust stains inside
Search Results
    Washing Machine Stains: Possible Causes And Cures
    www.stain-removal-101.com/washing-machine-stains.html
    Have you ever experienced washing machine stains, where your machine is the culprit for ... Just never put clothes in when doing this as it will discolor them. ... I get largeyellow spots on my Battenberg linens after washing, or maybe they ...
    Removing Yellow Stains from Washing ' Clorox
    https://www.clorox.com/...laundry/removing-yello...
    The Clorox CompanyFeb 4, 2010 - I do my laundry at a neighborhood laundry that has. ... into the machinefor the wash cycle but still get the yellow spots. ... Since you diluted it in a gallon of water, the yellow spots/splotches should not be from the liquid bleach. ... Rinse and air-dry to see if it has any effect before doing a large number of items ...
    Weird yellow spots on whites - Home Forums - GardenWeb
    ths.gardenweb.com > Home Forums > Laundry Room
    Jul 27, 2010 - I wash on warm/cold using powdered Tide and nothing else. The laundryemerges from the machine with yellow spots in places. Not pale ...
    Mysterious yellow spots on clothes, bedding, etc ..
Feb 03, 2016 | Washing Machines
Tip
Removing Crayon or Candle Wax from Carpets and Upholstery
<ul> <li>Firstly scrape as much of the wax from the upholstery with a plastic scraper, try not to rub it deeper into the material. </li></ul> <ul> <li>Place brown paper or other thick absorbent paper (not glazed) on the crayon. Using a clothes iron set to low heat setting, press down on the paper. Be careful or you may melt the upholstery. This will remove the excess wax. Keep checking the paper and replace it as it becomes saturated</li></ul> <ul> <li>Spray some WD40 on a paper towel , cotton wool or cloth and rub this into the stain. Repeat this with more towel until you have removed all the color.</li></ul> <ul> <li>Finally scrub the area with detergent and warm water to remove the WD40 and allow to dry</li></ul>
on May 08, 2011 | Washing Machines
How to unstick superglue
Try an acetone-based nail-polish remover.
Sep 05, 2014 | Elmer's Instant Krazy Glue
Remove a stain
Try goop hand cleaner
Rub/scrub it into stains wash in cold water
Jul 03, 2014 | Vineyard Vines Chino Shorts Mens 40
Whirlpool Cabrio gets unbalanced load at 7 minutes
Make sure load is properly sorted with like materials and paired up, do not mix things like towels with pants or shirts all together as different items absorb more water then others and can create unbalance when trying to enter final spin. If issue continues, it is very possible and item of clothing may have found itself stuck between spin basket and outer tub. This is very likely scenario due to design of this washer. If that is the case, spin basket must be removed then remove clothing to resolve issues.
Jun 02, 2014 | Whirlpool WTW6400SW Cabrio Washer
Black ink spill to my pants,.how can i remove the ink?so that i can still use my pants..
Hi from FixYa,
Sorry but this forum is to assist people in diagnosing problems and faults in washing machines rather than how to remove stains from clothes. Have a look at the label to see if that might help- and it depends on the colour of the pants. Otherwise I fear that the pants may have to be consigned to the bin ;-0(
John C
Sep 01, 2011 | Washing Machines
I washed some very dirty baseball pants on Whitest whites, with bleach and Tide detergent. Not only are the pants still "tan" from the dirt but all the other whites are also "tan." I ran them through a...
Try this: Soak the stained clothes in a solution of 1 quart of warm water, 1 teaspoon of liquid dish detergent and 1 tablespoon of white vinegar for 15 minutes. Then, rinse with water.
If this doesn't get everything out, then wash in warm water (or what the fabrics allow) using a color safe bleach and detergent.
The problem is that there was more dirt than what your detergent could handle. If you have a really dirty clothes item in the future, get as much of the dirt off using a vacuum or by soaking alone as you can. Then wash the item in warm water with detergent and color safe bleach.
Sep 28, 2017 | Kenmore Elite 45986 Front Load Washer
Yellow stains after machine washing
Sounds like rust stains, coming off the inside of the drum, you will need to find the source of the rust. Maybe a loose screw or something metal stuck inside the drum. Carefully run your hand around the inside of the drum and check for rough jagged edges to identify anything that should not be in there.
Aug 21, 2009 | Washing Machines
How can I get permanent black ink out of a white pair of pants?
Try spraying with hair spray or another spray product that won't stain. You are not using the product. The propellant is a good solvent. Hair spray and Lysol are my favorites as they don't seem to stain. RIT dye color remover may also work. If it is a large area your are probably out of luck.
Jun 30, 2008 | Washing Machines
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
