Question about Konica Minolta magicolor 2400 Laser Printer
Fusion unit well done for the tips great got it out! But... the fuser unit is quite dirty so ive tapped out most of the dirt and wiped what i can reach. now there is a white roller at first glance that you see in what i would call the front of the unit, this is covered in what looks like hard ink tried to scrape with finger but dont come off? is this normal for this roller? or do i need to clean it. also why cant i touch the red roller its attracted a bitof dust and durt can i wipe gently? thanks quick reply would be much appreciated. mike
  • mikew6
    mikew6 Aug 01, 2008
    please help no one got any answers or im gonna throw the thing out! seems its only any good for a paper weight...
  • 210 Answers
Hey Mike,
It is normal for these rollers to become dirty. Be very careful not to scratch it, you will have to replace the whole fusing unit and not only the roller and the whole unit it's not cheap at all.
Reset your Toners and Imaging units for Bizhub and CF series.
Posted on Sep 03, 2009
Hi this is irfan i have canon ir 3300 last 2 day it show this error code repeat when i clear the error code the comes back that error code. i replaced fuser fixing film and pressure roller Please help
Re: E000 Canon IR3300
The fixing film unit is faulty. The main thermistor has an open circuit. The fixing heater has an open circuit. The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution To reset the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR
Secondly Irfan, keep in mind, if you changed out the fixing film inside the fuser unit, then more than likely you did not reassemble the fuser unit while making sure the sensors were "EXACTLY" the required depth from the fixing unit.
When those sensors are even SLIGHTLY off, it will code out because they cannot read the temperature correctly when they are too close or too far away.
And when I say they have a very STRICT tolerance, I mean you actually need to get a depth gauge and check to ensure they are perfect.
I'm a copier technician, and quite honestly I rarely do a rebuild on Canon fuser units because they are so strict on these sensors.
I can also recommend a GREAT company that does nothing but rebuilds for fuser units. And they specialize in Canon models!
I'm not sure if they deal with the general public, or just dealers, but you can certainly call them and find out. They are called "Fusion Image Technology - Their website is - Hope that helps.
Aug 24, 2014 | Office Equipment & Supplies
Printer leaving black smudges and streaks
Could be bad cartridge leaking. Drum is in the cartridge and if the drum wiper is not doing a clean wipe toner will drop onto paper. Take out cartridge and over a sheet of white paper tap the cartridge with you hand, if toner drops you have a leaking cartridge. Also could be fuser area, they get dirty and leave lines or the teflon coating wears through and leaves a line, depending how old this unit is.
Aug 18, 2014 | Samsung CLX-3175FN Color Laser All-in-One...
Canon photocopier ir3570 paper is jamming in the fuser unit what could be a problem please help ray
Hi! There is a lot of things that can happen near the fusion stage.
1- the paper is curled due to damp and hits the fusion block.
2- the fusing unit is lacking traction due to damaged gears at the rear end
3- the paper hits a broken scraper (in a set of 3,4,5, or 6), being this the most comun cause
4- The pressure betwin the pressure roller and the fuser roller is weak
5- the paper sensor is broken or damaged, being this one a comun cause too
Now, if the paper goes trough, must be the sensor failure
If the paper gets curled or crumpled BEFORE fusion, then a scraper (or more) is broken
I could be here forever giving other tips, but this are the main ones
I hope it was helpful.
Sorry my english...
Apr 09, 2014 | Office Equipment & Supplies
"Dirty" could be one of 3 things... Transfer belt, Imaging unit and fuser unit. Make 5 copies in jam the machine by opening a cover. remove pages and see where the "dirt" originates from.
Jan 08, 2014 | Konica Minolta bizhub Office Equipment &...
Using my unit (owned about 6 years - great service so far) it suddenly quit ... no wind down or 'prelude' like whine - growl - etc. -- it just quit running ... suggestions? clear filters?...
I agree with you having great service because mine only lasted two years. It sounds like the motor just worn out. If you don't smell any burnt electrical then replace the bushing for the motor. Good Luck
Jan 07, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
Afico 2015- i am getting lines on the copies... optic are clean
Cleaned optics means the three mirrors in the scanning section and the laser **** glass right? This can be done by removing the platen glass.
Aug 28, 2009 | Ricoh Aficio 2015 Copier
Copy with dirty paper
This machine sounds like it needs a service. Is the paper dirty before it reaches the fuser unit? You can check this by opening the door while the machine is printing (if you're quick), if the dirt is on the copy before it is fused to the paper then the origin of the dirt is in the process area - clean the area particularly check the cleaning assembly and clean the transport bed (the assembly that pulls out with a green handle been turned to the left). If it is after fusing then your fuser roller and/or cleaning web (roller) is worn and/or dirty. Some techs wind back the cleaning web to buy more time - good luck
Canon Copier Service Manuals
Jun 08, 2009 | Canon NP 6050 Copier
MY brother HL-5140 quits printing,and also has a black vertical line down the page before it quits. After a while, say 30 to 45 minutes, it will start printing again. But there are black smudges on the...
Sounds like a fusing error ... If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit) If toner is sticking to paper but the print quality is poor , replace the drum unit  (PCU)  good luck
Feb 21, 2009 | Brother HL 5140 Laser Printer
your fuser rollers are dirty and tracking the image
unplug the machine open the fuser area wait until they cool down
take fuser oil(silicone lubricant) and wipe the rollers
while you are at it remove the glass and clean the reverse side and clean the mirror and lens
take a q tip and ubbing alcohol and clean the charger wire
Dec 30, 2008 | Canon ImageRUNNER 1670F Copier
Sony KP-61HS10 61 in. Rear Projection Television, dirty innerscreen
The important thing here is cleaning the refelective mirror inside you tv .We have noticed in dirty areas the dirt on mirror makes blurry picture.THerefore you have to open back cover and than tp cover to clean mirror and also dont forget to claen c.r.t lenses ,sisnce they are mounted facing upward ,lot of dust sit on c.r.t lens there fore clean 3 of them r.g.b..And you will notice on picture diffrence.
Dec 18, 2007 | Sony KP-61HS10 61" Rear Projection...
Konica Minolta magicolor 2400 Laser Printer Logo
95 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
