Question about Acer Aspire 5600 Series 5630-6951 Laptop
ACER 7520 AFTER REMOVING THE FOUR SCREWS ON THE PANEL ON THE BACK OF THE COMPUTER FOR THEMEMORY COMPARTMENT HOW DO WE ACTUALLY GET THE BACK OFF WITHOUT FORCING IT AS WE WANT TO ADD MORE RAM
    Problem Solver:
  • 10 Answers
You will actually kind of need to force it. it's all like plastic clips that's holding it..
Posted on Jul 28, 2009
How do i open dv7-1451nr?
Instructions
Shut the Pavilion dv7 down and close the screen. After unplugging all cables from the computer, turn it over and remove the battery.
Unscrew the six Phillips-head screws holding the large T-shaped panel to the bottom of the Pavilion dv7. Remove the panel and set it aside.
Remove the keyboard locking screw--marked by a keyboard-shaped icon--from the top part of the compartment exposed when you removed the T-shaped panel. Reserve the screw.
Remove the black Phillips-head screw from next to the wireless adapter inside the T-shaped compartment. This screw holds the Pavilion dv7 optical drive in place.
5
Pull the Pavilion dv7 optical drive gently out of its bay, and then remove the two Phillips-head screws from inside the empty drive bay. Reserve the screws.
6
Remove the Phillips-head screw next to the circular intake fan vent in the corner of the Pavilion dv7.
7
Remove the five Phillips-head screws from inside the empty battery compartment. You should now have removed 16 screws in all. Turn the Pavilion dv7 over and open the screen.
8
Insert a spudger or other flat plastic tool into the seam between the speaker grille and computer casing on the right side of the Pavilion dv7. Gently pry up to begin removing the speaker grille from the computer. As you do this, move the spudger to a new location to pry different areas until the grille is completely disconnected. Mind the ribbon cable connecting the center of the speaker grille to the logic board, and do not lift the grille any higher from the computer than the cable allows.
9
Push both sides of the speaker grille cable lock forward until the cable slides easily out of the logic board connector. Set the speaker grille aside.
10
Remove the four Phillips-head retaining screws above the top row of the Pavilion dv7 keyboard. Lift the keyboard up and forward, and place it face-down on the palm rest.
11
Unlock the Pavilion dv7 keyboard cable connector using the same method as for the speaker grille connector. Slide the cable out of the connector, remove the keyboard and set it aside.
12
Place the new Pavilion dv7 keyboard upside-down on the palm rest. Slide the keyboard into the connector, close the lock and rotate the keyboard down into the computer. Replace the four Phillips-head screws.
13
Slide the speaker grille cable into the connector and close the cable lock. Push the speaker grille into its original position above the Pavilion dv7 keyboard. Press gently on all parts of the speaker grille until it is flush with the computer casing.
14
Close the screen and turn the computer over. Replace the five screws inside the battery compartment, the screw next to the intake fan vent, the two screws inside the empty optical drive bay and the screw inside the T-shaped compartment.
15
Replace the t-shaped panel on the bottom of the Pavilion dv7 and its six screws.
16
Slide the optical drive back into its bay and replace the securing screw.
Jan 10, 2013 | HEWLETT-PACKARD Hewlett Packard Pavilion...
Need a digram of taking a dashboard out of a 2005 impala
  • Turn the engine of the Impala off and open its hood. Use a socket wrench to remove the negative cable from the battery.
  • Remove the four screws securing the driver's side kick panel, using a Phillips screwdriver. Use a slotted screwdriver to pry out the kick panel. Remove the passenger's side kick panel the same way.
  • Remove the metal plate from the driver's side of the vehicle under the Steering wheel by detaching its two securing bolts with a socket wrench. Pull the plate off to reveal three electrical connections. Unplug the three connections.
Glove Compartment
  • 4 Open the glove compartment and empty its contents.
  • 5 Remove the two screws at the back of the glove compartment.
  • 6 Pull the glove compartment off of the dashboard.
Center Dash Panel
  • 7 Remove the two screws securing the radio and the two screws securing the A/C unit with a Phillips screwdriver.
  • 8 Remove the four corner screws of the center dash panel faceplate with a Phillips screwdriver. Pull the faceplate off.
  • 9 Use a slotted screwdriver to pull the radio and A/C unit toward you.
  • 10 Reach behind the two devices and disconnect their connections. Pull them out of the vehicle.
Dashboard
  • 11 Remove the two screws underneath the steering wheel, using a Phillips screwdriver.
  • 12 Remove the two screws on the lower right side of the dashboard, using a Phillips screwdriver.
  • 13 Remove the 10 mm bolt from both side panels with a socket wrench.
  • 14 Remove the defroster grille by pulling it out. Remove the four screws along the top of the dash near the windshield.
  • 15 Pull the dashboard off the Impala and detach the two electrical connections. Lift up the dashboard and remove it from the vehicle.
Sep 22, 2012 | 2000 Buick LeSabre
Replacing the heater core i need to see where the screws are in the black box
Check this procedure for 1993 Ford Taurus 3.0L FI 6cyl REMOVAL & INSTALLATION
(see Figures 1 and 2)
Be sure to consult the laws in your area before beginning any procedure which requires servicing the air conditioning system. In some states, it is illegal to perform repairs involving refrigerant unless the work is done by a certified technician.
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
When removing the instrument panel, it may be beneficial to have a friend or assistant help you.
Without Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the instrument panel on 1986-89 vehicles as follows:
    1. Remove the four screws retaining the steering column opening cover, then remove the cover.
    2. Remove the sound insulator under the glove compartment by removing the two push nuts securing the insulator to the studs on the climate control case.
    3. Remove the steering column trim shrouds, then tag and disengage all electrical connections from the steering column switches.
    4. Remove the four screws at the steering column bracket to remove the steering column.
    5. Remove the screws retaining the lower left and radio finish panels, then remove the panels by snapping them out.
    6. Remove the cluster opening finish panel retaining screws. On Taurus remove the jam nut behind the headlight switch and the screw behind the clock or clock cover. Remove the finish panel by rocking the upper edge toward the driver.
    7. Disconnect the speedometer cable by reaching up under the instrument panel and pressing on the flat surface of the plastic connector. The panel can be removed with the cluster installed.
    8. Release the glove compartment assembly by depressing the side of the glove compartment bin and swinging the door/bin down.
    9. Using the steering column, cluster and glove compartment openings and by reaching under the instrument panel, tag and disengage all electrical connections, vacuum hoses, heater control cables and the radio antenna cable.
    10. Tag and disengage all underhood electrical connectors of the main wire loom. Disengage the rubber grommet from the dash panel and push the wire and connectors into the instrument panel area.
    11. Remove the right and left speaker opening covers by snapping them out.
    12. Remove the two lower instrument panel-to-cowl side retaining screws from the right and left side. Remove the instrument panel brace retaining screw from under the radio area. On Sable, remove the defroster grille by snapping it out.
    13. Remove the three instrument panel upper retaining screws, then remove the instrument panel.
  1. Remove the instrument panel on 1990-95 vehicles as follows:
    1. Position the front wheels in the straight-ahead position.
    2. Disconnect the positive battery cable.
    3. Remove the ignition lock cylinder and, if equipped, remove the tilt lever.
    4. Remove the steering column trim shrouds. Tag and disengage all electrical connections from the steering column switches.
    5. Remove the four bolts and opening cover, and the two bolts and reinforcement from under the steering column.
    6. Disengage the insulator retainer and remove the insulator. Remove the four nuts and reinforcement from under the steering column.
Do not rotate the steering column shaft.
    1. Remove the four nuts retaining the steering column to the instrument panel, disconnect the shift indicator cable and lower the column on the front seat. Install the lock cylinder to make sure the steering column shaft does not turn.
    2. Remove bolt at the steering column opening attaching the instrument panel to the brace. Remove instrument panel brace retaining bolt from under the radio area.
    3. Remove the sound insulator under the glove compartment by removing the two push nuts that secure the insulator to the studs on the climate control case.
    4. Disconnect the wires of the main wire loom in the engine compartment. Disengage the rubber grommet from the dash panel, then feed the wiring through the hole in the dash panel into the passenger compartment.
    5. Remove the right and left cowl side trim panels. Disconnect the wires from the instrument panel at the right and left cowl sides.
    6. Remove screw each from the left and right side retaining the instrument panel. Pull up to unsnap the right and left speaker opening covers and remove.
    7. Release the glove compartment assembly by depressing the side of the glove compartment bin and swinging the door/bin down.
    8. Using the steering column and glove compartment openings and by reaching under the instrument panel, tag and disengage all electrical connections, vacuum hoses, heater control cables, speedometer cable and radio antenna cable.
    9. Close the glove compartment door, support the panel and remove the three screws attaching the top of the instrument panel to the cowl top and disconnect any remaining wires. Remove the panel from the vehicle.
  1. Drain the coolant from the radiator.
  2. Disconnect and plug the heater hoses at the heater core. Plug the heater core tubes.
  3. Disconnect the vacuum supply hose from the inline vacuum check valve in the engine compartment. Remove the screw holding the instrument panel shake brace to the heater case and remove the shake brace.
  4. Remove the floor register and rear floor ducts from the bottom of the heater case. Remove the three nuts attaching the heater case to the dash panel in the engine compartment.
  5. Remove the two screws attaching the brackets to the cowl top panel. Pull the heater case assembly away from the dash panel and remove from the vehicle.
  6. Remove the vacuum source line from the heater core tube seal and remove the seal from the heater core tubes.
  7. Remove the four heater core access cover attaching screws and remove the access cover from the heater case. Lift the heater core and seals from the heater case.
To install:
  1. Transfer the three foam core seals to the new heater core. Install the heater core and seals into the heater case.
  2. Position the heater case access cover on the case, then install the four retaining screws.
  3. Install the seal on the heater core tubes, then install the vacuum source line through the seal.
  4. Position the heater case assembly to the dash panel and cowl top panel at the air inlet opening. Install the two screws to attach the support brackets to the cowl top panel.
  5. Install the three nuts in the engine compartment to attach the heater case to the dash panel. Install the floor register and rear floor ducts on the bottom of the heater case.
  6. Install the instrument panel shake brace and screw to the heater case.
  7. Install the instrument panel by reversing the removal procedure.
  8. Connect the heater hoses to the heater core. Connect the black vacuum supply hose to the vacuum check valve in the engine compartment.
  9. Fill the radiator and bleed the cooling system.
  10. Connect the negative battery cable and check the system for proper operation.
continue...
Feb 08, 2011 | 1993 Ford Taurus
1990 taurus steps to replacing heater core
Heater Core REMOVAL & INSTALLATION NOTE: Be sure to consult the laws in your area before beginning any procedure which requires servicing the air conditioning system. In some states, it is illegal to perform repairs involving refrigerant unless the work is done by a certified technician. CAUTION
When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old. NOTE: When removing the instrument panel, it may be beneficial to have a friend or assistant help you. Without Air Conditioning
  3. Remove the instrument panel on 1990-95 vehicles as follows:
    6. Disengage the insulator retainer and remove the insulator. Remove the four nuts and reinforcement from under the steering column. NOTE: Do not rotate the steering column shaft.
    7. Remove the four nuts retaining the steering column to the instrument panel, disconnect the shift indicator cable and lower the column on the front seat. Install the lock cylinder to make sure the steering column shaft does not turn.
    8. Remove bolt at the steering column opening attaching the instrument panel to the brace. Remove instrument panel brace retaining bolt from under the radio area.
    9. Remove the sound insulator under the glove compartment by removing the two push nuts that secure the insulator to the studs on the climate control case.
    10. Disconnect the wires of the main wire loom in the engine compartment. Disengage the rubber grommet from the dash panel, then feed the wiring through the hole in the dash panel into the passenger compartment.
    11. Remove the right and left cowl side trim panels. Disconnect the wires from the instrument panel at the right and left cowl sides.
    12. Remove screw each from the left and right side retaining the instrument panel. Pull up to unsnap the right and left speaker opening covers and remove.
    13. Release the glove compartment assembly by depressing the side of the glove compartment bin and swinging the door/bin down.
    14. Using the steering column and glove compartment openings and by reaching under the instrument panel, tag and disengage all electrical connections, vacuum hoses, heater control cables, speedometer cable and radio antenna cable.
    15. Close the glove compartment door, support the panel and remove the three screws attaching the top of the instrument panel to the cowl top and disconnect any remaining wires. Remove the panel from the vehicle.
  4. Drain the coolant from the radiator.
  5. Disconnect and plug the heater hoses at the heater core. Plug the heater core tubes.
  6. Disconnect the vacuum supply hose from the inline vacuum check valve in the engine compartment. Remove the screw holding the instrument panel shake brace to the heater case and remove the shake brace.
  7. Remove the floor register and rear floor ducts from the bottom of the heater case. Remove the three nuts attaching the heater case to the dash panel in the engine compartment.
  8. Remove the two screws attaching the brackets to the cowl top panel. Pull the heater case assembly away from the dash panel and remove from the vehicle.
  9. Remove the vacuum source line from the heater core tube seal and remove the seal from the heater core tubes.
  10. Remove the four heater core access cover attaching screws and remove the access cover from the heater case. Lift the heater core and seals from the heater case. To install:
  11. Transfer the three foam core seals to the new heater core. Install the heater core and seals into the heater case.
  12. Position the heater case access cover on the case, then install the four retaining screws.
  13. Install the seal on the heater core tubes, then install the vacuum source line through the seal.
  14. Position the heater case assembly to the dash panel and cowl top panel at the air inlet opening. Install the two screws to attach the support brackets to the cowl top panel.
  15. Install the three nuts in the engine compartment to attach the heater case to the dash panel. Install the floor register and rear floor ducts on the bottom of the heater case.
  16. Install the instrument panel shake brace and screw to the heater case.
  17. Install the instrument panel by reversing the removal procedure.
  18. Connect the heater hoses to the heater core. Connect the black vacuum supply hose to the vacuum check valve in the engine compartment.
  19. Fill the radiator and bleed the cooling system.
  20. Connect the negative battery cable and check the system for proper operation. Fig. 1: Location of the vacuum source line 86876016.gif
    Fig. 2: Heater core cover location 86876017.gif
Jan 30, 2011 | 1990 Ford Taurus
Where is the heater core located
Dec 19, 2010 | 1987 Ford Taurus
I need to try to replace my cooling fan and heat sink, I have tried to get the back of the computer off, I have removed the HD and battery and all the screws, but it still seems to be held by something...
Actually there is a lot yet you have to open. Check the battery compartment for hidden screws, also there should be a cover near the top by the screen that will come up. You are going to have to remove that and then remove the screws holding the keyboard down and the Hinge Screws. After that most likely you will need to remove the screws holding the motherboard down so you can lift the motherboard out so you can access the cooling fans and coils. Acers like to use built in clips that are molded into the body of the laptop as well, look for some of those.
Jul 20, 2010 | Acer TravelMate 2480 Notebook
I need a diagram on how to remove a heater core in a 1994 mercury villager
big job. entire heater plenum has to come out. 6 hour job.
http://groups.yahoo.com/group/villagerquest/
Instrument Panel Removal
  1. stv~us~en~file=ani_caut.gif~gen~ref.gif WARNING: THE BACKUP POWER SUPPLY ENERGY MUST BE DEPLETED BEFORE ANY AIR BAG COMPONENT SERVICE IS PERFORMED. TO DEPLETE THE BACKUP POWER SUPPLY ENERGY, DISCONNECT THE BATTERY GROUND CABLE AND WAIT 10 MINUTES.
    Disconnect the battery ground cable (14301).
  1. Remove the access cover from the bottom of the steering wheel (3600) and disconnect the driver side air bag module electrical connector.
  1. Open the glove compartment, then pull the access panel from the top of the glove compartment. Disconnect the passenger side air bag module electrical connector.
  1. Remove the four console compartment plastic screws or C/D changer cover plastic screws (if equipped) and the console compartment door (045G36) or C/D changer cover.
  1. Remove the two LH inner instrument panel lower cover screws and the plastic nut.
  1. Remove LH inner instrument panel lower cover (044L97) and disconnect the foot lamp electrical connector.
  1. Remove the two RH inner instrument panel lower cover screws and the plastic nut.
  1. Remove RH inner instrument panel lower cover (045G22) and disconnect the foot lamp electrical connector.
  1. Remove the plastic screw, two lower screws, two center bolts, two upper screws and the screw at the instrument panel bracket, then separate the glove compartment from the instrument panel (04320). Disconnect the glove compartment striker plate catch electrical connector.
  1. Remove the two instrument panel to passenger side air bag module bracket bolts.
  1. Remove the four passenger side air bag module nuts and the passenger side air bag.
  1. Remove the RH instrument panel screw.
  1. Remove the four C/D changer screws.
  1. Remove the C/D changer and disconnect the C/D changer electrical connector.
  1. Remove the instrument panel ash receptacle (04810).
  1. Remove the two upper center instrument panel finish panel screws and the two lower center instrument panel finish panel screws.
  1. Remove the center instrument panel finish panel and disconnect the cigar lighter socket and the cigar lighter illumination lamp electrical connectors.
  1. Remove the two instrument panel ash receptacle bracket screws and the instrument panel ash receptacle bracket. Disconnect the instrument panel ash receptacle lamp electrical connector.
  1. Carefully pry the center A/C register from the instrument panel.
  1. Remove the hose from the ambient temperature sensor and disconnect the ambient temperature sensor electrical connector (if equipped).
  1. stv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result. Refer to Module Service Procedures in Section 18-01 .
    Remove the four radio chassis bracket screws and pull the radio chassis (18806) and climate control assembly from the instrument panel.
  1. Disconnect the three radio chassis electrical connectors, the antenna lead, the three climate control electrical connectors and remove the radio chassis and climate control assembly.
  1. Remove the plastic screw, the two instrument panel steering column cover screws and the instrument panel steering column cover (04459).
  1. Remove the four LH instrument panel reinforcement bolts and the LH instrument panel reinforcement. Disconnect the diagnostic electrical connector.
    Remove the instrument cluster (10849). Refer to Section 13-01A (electronic cluster) or Section 13-01B (conventional cluster) for the removal procedure.
  1. Disconnect the seat belt warning chime electrical connector. Remove the two seat belt warning chime screws and the seat belt warning chime.
  1. Remove the four steering column nuts and lower the steering column assembly.
  1. Remove the two LH instrument panel screws.
  1. Remove the center instrument panel screw.
  1. Remove the LH inner duct screw and the LH inner duct.
  1. Disconnect the power outside rear view mirror control switch electrical connector.
  1. Pull off the upper portion of the LH inner door opening weatherstrip. Remove the windshield side garnish moulding (03598).
  1. Pull off the upper portion of the RH inner door opening weatherstrip. Remove the windshield side garnish moulding.
  1. Remove the instrument panel upper moulding (04268) and disconnect the sun sensor electrical connector (if equipped).
  1. Remove the light sensor amplifier from the top right side of the instrument panel and disconnect both light sensor amplifier upper and lower electrical connectors (if equipped).
  1. Remove the instrument panel center nut.
  1. Remove the two instrument panel upper bolts.
  1. Remove the instrument panel from the vehicle.
May 20, 2010 | 1994 Mercury Villager
My Acer 7520 won't power up - no fan - just blinking light
I would check the power supply. Remove it and try it in another PC if possible.
Aug 29, 2009 | Acer Aspire 5720-6661 Notebook PC
Hard drive removal? Satellite 1405-S151
How to Add or replace your Hard Drive
1. Turn off the notebook, remove the power cord & battery
2. Use a screwdriver to remove the two screws that hold the hard drive compartment panel in place. (on the bottom of your laptop)
3. Gently lift the panel and slide it out.
4. You'll discover that the hard drive is bolted to the panel with four screws. Use the screwdriver to remove the screws. Separate the hard drive from the panel.
5. Slip the new hard drive into the panel and align the screw holes. Replace the screws.
6. Put the panel back into place and make sure it locks
in securely.
7. Replace the two screws that hold the compartment panel in place.
Oct 10, 2008 | Toshiba Satellite 1405-S151 Notebook
Acer Aspire 7720 notebook memory
all u need is a flat screw driver or a knife.now u need to apply some force on it with the screw driver i promise u it wont break its just a plastic. now take a bold step n try it.
May 30, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
