Question about Toshiba Office Equipment & Supplies
I can not print tables from one computer but can print them from another
  • Toshiba Master
  • 691 Answers
This is software related and not a problem with your printer.
Check that you have the latest driver for the printer on both machines. Also check the printing options in the software you print the tables from.
Posted on Jul 04, 2008
Fat alloc error
> FAT ALLOC ERROR
FAT == File Allocation Table (like a 'Table of Contents' in a printed book)
ALLOC == Allocation
ERROR == ERROR
Some of the contents of that 'Table of Contents' are invalid.
So, copy all the files from the Memory Card onto your computer, to save a copy of those files.
Burn a CD/DVD disk with a copy of those files.
Then, "reformat" the Memory Card, to write a "new" and "empty" 'Table of Contents' onto the device.
Then, copy all the files back onto the Memory Card.
Jun 01, 2011 | SanDisk 2GB microSD Memory Card
We have a Laserjet P2050dn that is experiencing a problem with printing. If you print out an excel document titled 'ABC invoice', the 2050 will print the invoice. If you then print another document...
Hi
Clear the pending jobs on print spooler
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Mar 21, 2011 | HP Office Equipment & Supplies
I have a workio 2330 when i copy from the tray or table its fine but when i print from my computer the holes are on the wrong side. Its like it prints on the back of the page. How can i fix this? Thanks.
one of the settings in your print driver is wrong, try print without duplexing. i always recommend printing by default single sided and then select duplexing per print job.
Mar 31, 2010 | Panasonic Workio DP-2330 Printer
My printer will not print Excel worksheets, charts, or Access tables. It will only print Word documents from the XP,2003 computers in my class. It prints fine from my new computer Vista, 2007. What can I...
Try to do a print preview from excel.
What you see is what you should get since word is working properly.
If the print preview is leaving stuff out, you need to modify the page layout in page setup
Mar 24, 2010 | Brother HL 5170DN Laser Printer
When I print color, the page has a lot of extra toner.
Start with this
  1. Make sure to set the Print Quality mode in the print driver to "Standard" and the TekColor Correction to "None" before performing the next step. This will allow the job to purge only the problem color. Other settings may cause the printer to use a percentage of the other ink sticks.
  2. Print approximately 50 - 100 pages of the document, as necessary, until the printed color returns to normal.
Next. This is on xerox.com downloads and drivers.
The updated sRGB Display and sRGB Vivid color tables for the WorkCentre will help with the following issues that have been found with the original factory color tables.
  • RGB images contain too much yellow.
  • RGB image red shades are too orange or too light.
  • RGB object blues are too dark or aqua.
  • CMYK objects use the sRGB Display color table when the Automatic TekColor correction is used. After the updated color tables have been downloaded to the WorkCentre, the CMYK objects will use the Commercial Press TekColor correction when Automatic is used as the TekColor correction.
    NOTE: The new color tables will only take affect when using the Enhanced or High Resolution / Photo print quality mode.
To update the RGB color tables:
  1. Click on the [Drivers & Downloads] link under the Product Resources menu on this window to download the updated color tables to a known location on the computer's hard drive. The color table update file is located under the Color Profiles section on the Drivers and Downloads page.
  2. After the file has been downloaded to the computer, send the file to the WorkCentre. See the Related Items below for additional information.
Jan 07, 2010 | Xerox WorkCentre M-24 Color Copier
In a table, I have dates underlined. On the
Without actually seeing how your table is set up, I would suggest you check the following properties. Check to see if the height of cell is adequate for the size font you are using and that the text is horizontally centered within the table cell. It is possible that the underline is printing in the same location as the gridline.
Apr 07, 2009 | Microsoft Office Word 2007 Upgrade:...
Printing off receipts so the table is clear to use again
You need to print a receipt off when the customer pays. You can if you like, clear all tabs off and start again, in z mode, select open check z to clear ALL tabs off.
Mar 23, 2009 | Casio QT 6000 Point of Sale Terminal
How to print only selected fields in ms access.
open your table in query, follow steps to do this...
1. open new query in access
2. locate the table
3. once table selected, select field name in selected table you only want to include in query
3. once finished selecting the field save the query
4. you can now view selected field in your table and print as well
5. you can edit the query anytime if you want to add or remove field
6. query will not affect your table since this is only query.
hope this will help you....
Oct 22, 2008 | Microsoft Access 2002 for PC
29 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
