Question about Epson EMP-S3 Multimedia Projector
Projector problem image is flickering constantly and the colour is turning pink
  • Anonymous Aug 18, 2008
    Had the same flickering with pink tint problem with a Toshiba TDP-T99 DLP projector.
    The projector's startup screen and white areas (buttons, text, etc.) in the projector's onboard menu all looked normal.
    When connecting the projector to a laptop, the projected image flickered slightly and any white areas (that looked normal on the laptop screen) were very pink (magenta) on the projected image.
    Tried adjusting the projector's image colors with no joy.
    Borrowed a VGA cable from a working Dell 17" LCD monitor, connected it to the laptop and projector and all whites looked normal again.
    Reconnected the projector's original VGA cable to the laptop and projector (making sure cable was tightened down) and all works OK: there's no flickering and whites are normal.
Change your VGA cable, one of the wires inside the VGA cable is faulty
Posted on Jul 23, 2008
My optoma projector has a green tint
it may just need a service, as all DLP projectors need to be cleaned internally as well as LCD.
DLP projector images will flicker and lose colour also may shut down if it is very dusty inside.
Jan 28, 2013 | Optoma Office Equipment & Supplies
Projector flickering and giving a pink colouring
that's the bulb inside the projector needs replacing
bulbs only last like 700 to 1200 hour before they need replacing
Jul 04, 2008 | Office Equipment & Supplies
My projector is flickering?
I have about 10 of these in the school I work in, most of them have gone mental flickering, my solutions has been to open the covers remove the bulb and carefully using a compressor blow all the dust out..This has worked and cured them in about 6 out of 8 cases
Nov 20, 2011 | NEC NP200 Projector
Projector image has a pink tint to it
Usually colour problems like this are due to one of two things:
1. poor connection at either end of the cable, or
2. a damaged connecting cable between projector and computer.
Check these first before getting the projector to a technician.
Aug 16, 2011 | Vivitek H1080FD DLP Projector
Lamp is projecting pink
are you saying that all the images now have a pink colour to them. does the menu come up pink as well
Jul 07, 2011 | InFocus ScreenPlay 4805 Multimedia...
Picture colour is wrong. Too much green and pink.
first reset the settings to factory default. then swap out the cable. if you still have trouble, replace the colorwheel.
Mar 27, 2010 | InFocus ScreenPlay 4805 Multimedia...
Flickering image
Have you check your cable? Are you using the component(RGB) to vga cable? Your vga to vga cable may be defective.
Dec 12, 2008 | Sharp Notevision PG-M10X Multimedia...
Infocus x2
first try another computer cable. if same results, press the "auto image" button on the projector. if that doesn't work, press menu, select settings, then factory reset, and "yes". if you still have the same problem, the eca (main board) is bad.
Sep 01, 2008 | InFocus X1 Multimedia Projector
Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
Sep 10, 2007 | Sanyo PLC-XU47 Multimedia Projector
Epson EMP-S3 Multimedia Projector Logo
277 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
