Question about Microwave Ovens
KitchenAid KBMS1454R 1000 Watts Microwave Oven
For the last year or so the display crystals would come and go.today the right side of panel quit.if i tab cook time to over 90 min.and hit start it will work.no display code .there are a row of small triangels on top 775 in the display ,a couple of more triangle on the bottom.when i depress the start ,cancle ,add a minuite.basicly from the knob to right the triangle go out.so it seem it is the membrane and the display?
  • mikefoote Jul 06, 2008
    i went threw and tried that.i have a had a display problem for more than a year, but it had no effect on function.when this was sent in i had no function.today how ever it works?(heat only)
    when the clock set is held for 5 sec. and zeros apear.it will not set hour min .i unpluged the smaller center plug on the (i believe to be the register board)vertical board that conects the key pad and led display unit together interface board.at this time all key pad bottons chimed when depressed.i would think the membrane switch is good?i am thinking it would not be likly to have all the problems only beacause off a display?could it effect funnction some how?
    my wall voltage is 122vac,could this have an effect?
    thanks for the help,mike
  • William Miller
    William Miller May 11, 2010
    The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
    Let us know if the hard reset doesn't fix it.
  • Microwave Ovens Master
  • 9,086 Answers
Sounds like the keypad is okay, unless it might be intermittent.
Your wall voltage is within the proper range.
It sounds like it might be bad connections on the control board causing functional and display problems.
I work on control panels, actually, but I can't find any service data (yet?) on this model.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Did you find it?
Any chance you could scan and e-mail it to me?
Please feel free to contact me directly.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 06, 2008
How do I change out a bad control panel on Kitchenaid microwave KBMC147HSS0 ???
Please check this link and you will get a good idea of how the components works. The front panel can be removed once it is confirmed .
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Oct 27, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How to resolve the F6 E0 error code on the built-in Kitchenaid microwave oven? The unit was brand new and installed 2 and half years ago in my new house. One website mentions the description for this...
"F6" on a Whirlpool microwave means you have a shorted cook relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 26, 2017 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How do I unlock the key pad? The display shows locked and I don't know how it locked.
Here you go.
The Child Lock shuts down the control panel pads to prevent
unintended use of the microwave oven.
When the control is locked, only the Vent Fan and Light pads will
function.
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound
and a lock icon appears on the display. Repeat to unlock and
remove the lock icon from display.
May 10, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave will turn on by itself and display PAN on screen.
Does everything come on by itself or is it just a fan that comes on? If so, is it a convection oven?
Sep 12, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave starts running on it's own
There is a short in the cntrol board. I have seen problems arise like this from mice, spiders and other insects. Power fluctuations can also trick the control into activating. ERIC
Aug 15, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid built in Microwave model YKHMS155LSS-0 Starts by itself, displays PAN, beeps intermittently and sometimes displays an F1 error
Dougmcduff have you resolved this problem with you kitchenaid microwave turning on periodically??? I have the exact same problem. Any solutions? I called Kitchaide and no help there.
Mar 10, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
GE Microwave quit
Hats off to your 20 year old GE machine. That is the the longest lasting microwave I have heard of. When they finally go out, they are done, there is nothing left to even do with them. Most of the parts are obsolete. However you might find a appliance store that still has one similiar to yours in their backroom that they use for spare parts for those like you who might need it. You might take it to them to see if it is worth repair.
I can say this, after 20 long years, the machine will cost more to fix, and for what you will spend on repair, you can buy a different one that can also be energy effiecient.
Apr 15, 2008 | GE JVM1650 1000 Watts Microwave Oven
Kbms1454r
Your magnetron is leaking and needs to be replaced.
Oct 29, 2007 | KitchenAid KBMS1454R Microwave Oven
Microwave Ovens Logo
97 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
