Back to:
Tags:
1999 Jeep Grand Cherokee
Getting the headlight assembly out
posted by Kataplr on Jul 04, 2008
I need to replace the headlight assembly and can't get the old one out. what is behind the headlight assembly that I'm not seeing?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 15, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If your car is a 99 WJ the light assembly come out like this. Remove the long bolt located on top near the rear of the light assembly. This is the only thing you need to undo. Using a large flat blade screwdriver down the rear lever against the radiator cross member. The lamp is held in with a couple of ball-in-cup type of things that require a bit of effort to release. To refit, hold in place and give it a good firm shunt with the palm of your hand to refit the ball-in-cup do-dats. Refit long bolt.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on getting the headlight assembly out:
I don't want to Accept this solution
Can you Help with these Cars problems?
I saw your reply to a similar question w/ a jeep and...
when my gas tank gets low my jeep dont shift out of first...
The electric lock on the tailgate does not work. It won't...
My air conditioning unit is fully serviced but only blows...
tengo una grand cherokee apaece una llave encendida en el...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
