Question about E-Machines M5310 PC Notebook
When you turn it on nothing happens
I have a e machines m5310 that a couple of years ago qiute and we decided to get it out again. When you push the power button everything lights up but nothing happpens. No sound no picture but the cd drive sometimes works. And yes i have plugged it into an external monitor what should i do I have an e-machine M5310 laptop. It will no longer turn on when I try to power it up, even with a AC adapter plugged in. Could it be the battery, the power supply or both? It also used to run rather hot. It has an Athlon XP-14 processor and runs Windows XP home edition. I know the battery is no good, but would replacing that alone fix it?
  • scottiebmu Jul 07, 2008
    I will consider the solution and see whether it works. Thanks.
  • 689 Answers
Probably there is lockup. release the battery and disconnect the power cord press and the power button for 7 seconds to perform component discharge. Connect power and test.
Good Luck
Posted on Jul 04, 2008
    Genius:
  • 2,028 Answers
Try starting without the battery. Then try alternating the memory, a bad battery or memory chip can cause this.
    President:
  • E-Machines Master
  • 1,314 Answers
No, replacing the battery alone will not fix it. This sounds like the motherboard will need to be replaced.
  • lyn505 Dec 19, 2010
    Try to replace the AC Adapter or the battery. If that doesnt work out bring it to a Geek Squad like at Best Buy.
  • Kevin Shafer
    Kevin Shafer Dec 19, 2010
    Do NOT under any circumstances bring it to Geek Squad. You will get it back in worse shape. Go to ripoffreport.com and check it out for yourself. I make a lot of money fixing geek squad's screwups.
    Genius:
  • 3,422 Answers
HI,
I strongly suggest you to replace it with a new battery.
My Dryer will not turn on. I push the Power button and nothing happens. The dryer is getting power as the interior light still comes on. My washing machine leaks copious amounts of water during the wash...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 20, 2011 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
I started at the edge of fabric but ended off the fabric.Now E-1.
Check the bobbin area to be sure there aren't any thread tangles that may be causing the jam.
Take it back to the dealer and show them what is happening.
It sounds like the timing might need adjusting.
Apr 20, 2010 | Janome Memory Craft 4800QC
1991 Toyota SR5 won't start when the weather is very hot
I checked the gages of the wiring which went into the battery, as suggested by another person on the site, but nothing looked out of place. I then proceeded to check wiring connections throughout the vehicle and found there were 2 sets of wires on the driver's side which were not attached to its counterpart. I remember the mechanics disconnecting those a few years ago, as they stated it was causing the problem. I decided to re-establish the connection for both sets of wires and the truck started immediately with out any further problems.
Jul 09, 2009 | 1991 Toyota Pickup
Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
May 18, 2009 | Maytag Dependable Care LAT9416
Won't power up
Did you install correctly the cables?
Did you move any card or memory?
Check it out again!!
The fan of the motherboard is working?
Hit the reset buttom and see what happen
If doesn't work is a bad motherboard
Oct 03, 2008 | E-Machines eMachines Desktop PC
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. arnold@supportsave.com
Jun 04, 2008 | E-Machines eMachines Desktop PC
I just bought a lap top and no nothing about them it is a hp compaz nx 5000 I turned it on and the screen is still black don't know how and where to turn the monitor on
Apr 05, 2008 | E-Machines M5310 PC Notebook
Need help fixing
I had the same problem a couple years ago with mine. After letting it set for several months, I tried to plug it in again after moving into another house. All of a sudden, it started working again. That was 1 year ago, but just last week...it did it again. I noticed that it does this if it is left on for an extended amount of time (my wife goes to bed at night and leaves it on). I cannot find anything on how to fix it, and no warranty assistance from RCA. I'm purchasing a Sony today, but will hold onto the RCA in case it decides to work again.
Sep 29, 2006 | RCA RT2380 System
E-Machines M5310 PC Notebook Logo
181 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
